Wooosh Posted March 4, 2019 Share Posted March 4, 2019 Can I use an OBD2 to usb to run to the tablet and use btssm? I wanted to keep this on a budget and $150 for the tactrix cable isn’t in it. Link to comment Share on other sites More sharing options...
Infosecdad Posted March 4, 2019 Share Posted March 4, 2019 Can I use an OBD2 to usb to run to the tablet and use btssm? I wanted to keep this on a budget and $150 for the tactrix cable isn’t in it. Yes, there are specific $15 cables you can get to USB to an OTG cable to the tablet. I need to go see if I can find the one I have. Or someone else may chime in before I find it. Link to comment Share on other sites More sharing options...
solidxsnake Posted March 4, 2019 Share Posted March 4, 2019 Look in the BtSsm thread for that info. Anything that supports K-line comms should work fine. Link to comment Share on other sites More sharing options...
Wooosh Posted March 4, 2019 Share Posted March 4, 2019 Ok will do. Thanks again Link to comment Share on other sites More sharing options...
Wooosh Posted March 5, 2019 Share Posted March 5, 2019 Yes, there are specific $15 cables you can get to USB to an OTG cable to the tablet. I need to go see if I can find the one I have. Or someone else may chime in before I find it. I emailed btssm.com (heiche) to see if he still has/makes the KKL cables with OTG adapter. Wanna keep it as cheap as possible but would rather support the community if it’s a matter of a few $ difference. If you can find out where you got yours in case he doesn’t get back to me I’d appreciate it. I was looking on google and eBay and they have the vagcom KKL OBD2 to USB for like $7 and the OTG adapter for like $3-5. Curious if these will work if he doesn’t get back to me Link to comment Share on other sites More sharing options...
solidxsnake Posted March 5, 2019 Share Posted March 5, 2019 Yeah, those should work fine. Link to comment Share on other sites More sharing options...
Ahmed Shawky Posted March 6, 2019 Share Posted March 6, 2019 I used to use the N7 in my LGT for logging and real-time gauges with BtSsm. Things I used in my install: Nexus 7 2013 Tablet4-port USB hubTactrix OpenPort 2 (I also opensource tune my car, so I already had it)RS232-USB serial converter for my wideband O2 (could also just get it from ECU but wanted the digital connection offered by my Innovate LC-1 and BtSsm) Besides that, the install is the same as all of your other media nexus7 installs (modified kernel to allow USB-OTG charging, and a USB-OTG charge/data y-cable). Shameless plug: I'm selling the JDM double-DIN vent/nav bezel from my LGT since it's been sitting for over a year now. Thanks for your reply So if i just need it to for bluthooth audio gps and usb connect All what i need is Tablet itself Usb hub Memory stick How can i connect the speakers with the tablet then Link to comment Share on other sites More sharing options...
funkycharms Posted March 6, 2019 Share Posted March 6, 2019 Thanks for your reply So if i just need it to for bluthooth audio gps and usb connect All what i need is Tablet itself Usb hub Memory stick How can i connect the speakers with the tablet then I bought my car with a Parrot Mki9100. The previous owner used that to connect the tablet to car stereo via bluetooth Link to comment Share on other sites More sharing options...
solidxsnake Posted March 7, 2019 Share Posted March 7, 2019 Thanks for your reply So if i just need it to for bluthooth audio gps and usb connect All what i need is Tablet itself Usb hub Memory stick How can i connect the speakers with the tablet then Behringer UCA202 is my USB sound card. I used the factory AUX in, which my LGT had since it was '07+. All of this stuff has been covered in this thread and the other main thread here: https://legacygt.com/forums/showthread.php/tablet-pc-carputeri-149420.html Read through them and try searching the forums on google using the "site:legacygt.com" modifier. Everything you want to know has already been covered in pretty extensive detail. Link to comment Share on other sites More sharing options...
Wooosh Posted March 21, 2019 Share Posted March 21, 2019 (edited) Got the 2013 nexus7 last wk, the vag Kkl cable and otg adapter. Looking to do this in the next day. Can anyone give a little help (maybe a how to vid somewhere online) with the Rom I need to flash (Timur rom I believe or somthn better if there is that anyone knows of) and any other bits of info, gesture apps for easy use etc that may be nice? Only using for btssm (maybe nav and possible backup cam in the future) Thanks Edited March 21, 2019 by Wooosh Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 I like the gmd gesture app. Paid app but worth it. Even better if you can get the steering wheel buttons to communicate with the app. btssm opens up literally at your finger tips I think I used a usb device called joycon exr. Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 I like the gmd gesture app. Paid app but worth it. Even better if you can get the steering wheel buttons to communicate with the app. btssm opens up literally at your finger tips I think I used a usb device called joycon exr. Thanks for the info. Do I need a specific Rom and if so do you know where I get it to run btssm in the vehicle or will it work on the rom that comes on the tablet? I want to make sure that’s all done and flashed before I start buying apps and setting it up for the car And please excuse. I’m a caveman with this stuff Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 BtSsm should not have any issue running on any Timur ROMS. I think Timur made his latest ROM available to the public. I have it on one of my tablets and it is stable. Here you should have all the info. Carefully study the steps and take your time. Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 BtSsm should not have any issue running on any Timur ROMS. I think Timur made his latest ROM available to the public. I have it on one of my tablets and it is stable. Here you should have all the info. Carefully study the steps and take your time. Thanks so much One last set of questions for you. I have figured out a very nice, clean way of mounting this without having permanence in the car. I can take it out and reinstall at the flip of a wrist basically. If I have access to my sleep/power buttons can I run btssm without any issues on the stock Rom? Is the Timur Rom necessary to run btssm or does it just give more convenience when the tablet is in a permanent state in the JDM cubby? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 No. Timur ROM is not necessary to run BtSsm. If you use the stock ROM, you will then have to make sure you use a charging cable which the tablet will be happy with (i.e. read fast charge). Also, you'd have to root the tablet if you want gmd gesture to work. Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 (edited) No. Timur ROM is not necessary to run BtSsm. If you use the stock ROM, you will then have to make sure you use a charging cable which the tablet will be happy with (i.e. read fast charge). Also, you'd have to root the tablet if you want gmd gesture to work. Ok cool. My plans as of now are to do that n run the stock Rom and save my old caveman ass alotta headache [emoji23]. I will have a charging cable accessible to it wenever necessary. It will only be for btssm so the gesture apps aren’t necessary either. I already have the JDM double din and HVAC setup with all entertainment amenities in it so this will be perfect Awesome. Thanks a lot XT2005bonbon. I appreciate it Edited March 22, 2019 by Wooosh Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 Just make sure it is a genuine Asus cable and/or a thick gauge cable. Or else, it'll charge slow and still deplete the battery as you are using it. You have the bluetooth dongle right? Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 Just make sure it is a genuine Asus cable and/or a thick gauge cable. Or else, it'll charge slow and still deplete the battery as you are using it. You have the bluetooth dongle right? It’s a brand new tablet and came with all the accessories (including charger). It will b removable from the car so I can charge it in home wenever necessary as well. My car doesn’t get road tripped or even driven any more than 50mi or so on any given day so I don’t think I’ll ever and if I do it’ll be rare that I have to worry about charging it I’ll be using the vag Kkl adapter not the BT dongle Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 Ah, if you use a vag com cable, then you need OTG capability as far as I know, which also implies that the tablet needs to be rooted. Others may correct me if I am wrong. Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 Ah, if you use a vag com cable, then you need OTG capability as far as I know, which also implies that the tablet needs to be rooted. Others may correct me if I am wrong. So the stock Rom doesn’t have otg capability? I have the Kkl to usb and then the otg adapter. Maybe I’ll buck up on the Bluetooth dongle n make my life easy Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 I don't think so. But you could always root your tablet while still using the stock ROM. Will require following some steps, bla bla, etc... Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 I don't think so. But you could always root your tablet while still using the stock ROM. Will require following some steps, bla bla, etc... Ok. Maybe I’ll just buck up for the BT dongle. That will work no problems, no rooting etc with stock Rom? It’ll make it even nicer aesthetically anyway the way I’m putting it in the car Thanks again man Link to comment Share on other sites More sharing options...
xt2005bonbon Posted March 22, 2019 Share Posted March 22, 2019 Yeah. no need to root. It's just pairing the tablet with the dongle, which you'll set up only once. Link to comment Share on other sites More sharing options...
Wooosh Posted March 22, 2019 Share Posted March 22, 2019 Sweet. Thanks again man Link to comment Share on other sites More sharing options...
solidxsnake Posted March 22, 2019 Share Posted March 22, 2019 The stock ROM has OTG capability, there's no problem using the VAGCOM cable on a stock AOSP ROM. It doesn't have OTG + Charging capability, which it seems is not a problem for you, Whoosh. Link to comment Share on other sites More sharing options...
