ralphyralph5 Posted May 31, 2005 Share Posted May 31, 2005 I was installing my turbo timer yesterday and when I got to the part that tells me to connect the brown wire(from timer) to the parking brake wire(the wiring diagram says P i believe thats purple) that shows 12v when the brake is down, I couldn't find it. I could only find the gray one in front of the p. brake. Can anyone direct me as to where this other wire might be? Link to comment Share on other sites More sharing options...
Xenonk Posted May 31, 2005 Share Posted May 31, 2005 That gray wire at the parking brake is your ground wire, that is what you tap it to. There isn't a 2nd wire that you are referring to. You can verify that the gray wire is a ground by using a voltmeter to double check it. I didnt bother to tap my turbo timer to that parking brake wire when I had my WRX.. I just grounded that brown wire wherever.. yea, I know, not safe, but it's my car and I can wire it however way I want it. Keefe Keefe Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 1, 2005 Author Share Posted June 1, 2005 thank you very much Link to comment Share on other sites More sharing options...
NutBucket Posted June 1, 2005 Share Posted June 1, 2005 Does the fact we have the transponders in the key make any difference in the operation of a turbo timer? Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 1, 2005 Author Share Posted June 1, 2005 not at all ..................i installed mine yesterday and it works great except for the fact that i can't figure out how to get the parking brake safety feature to work. i guess that the transponders only work in preventing the engine from starting and do nothing after it's already running. Link to comment Share on other sites More sharing options...
NutBucket Posted June 1, 2005 Share Posted June 1, 2005 Ah, that makes sense. How much of the car did you have to take apart to get to all the wires and which TT did you use? Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 1, 2005 Author Share Posted June 1, 2005 I used the GREDDY unit.........it was super simple as soon as you figure out what wires do what. i took 3 pieces off of the under dash on the drivers side. unscrew the one screw under the steering column that allows the bottom plastic piece of the steering column to come off(this gives you access to the ignition wires[they are on the left hand side of the column]). take the bottom plastic covor off. then you pull off ( not completely) the under dash . simple pulling will do it. then use a voltometer to check which wire does what, follow the instructions provided with your tt Link to comment Share on other sites More sharing options...
NutBucket Posted June 1, 2005 Share Posted June 1, 2005 Cool. May have to look into this. Link to comment Share on other sites More sharing options...
alpinefun Posted June 1, 2005 Share Posted June 1, 2005 Any purpose of this mod since TT is not required by design? If honestly, I've got so sick from my Audi A4 turbo timer so I would never install it on my LGT unless it striclty required. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 1, 2005 Author Share Posted June 1, 2005 definately..............very easy............less than an hour...........i got my tt from this seller on ebay- http://motors.search.ebay.com/_W0QQfgtpZ1QQfrppZ50QQsassZmrQ2ewurks if you do get a greddy unit and you want to know what wires connect to what, pm me or leave a message here. i would tell you now but i don't remember. Link to comment Share on other sites More sharing options...
NutBucket Posted June 1, 2005 Share Posted June 1, 2005 I don't really buy into "not required by design". Personally after driving I sit for a minute or so and let it idle before turning off the car. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 1, 2005 Author Share Posted June 1, 2005 me too.........it'll never hurt Link to comment Share on other sites More sharing options...
AWDxBOOST Posted June 1, 2005 Share Posted June 1, 2005 just ground the tt parking brake wire and itll bypass it...easy itd be hard to steal seeing as the remote still works to lock it and the steering wheel is locked Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 2, 2005 Author Share Posted June 2, 2005 what i don't understand is why this "ACC" is displayed on the clock screen during countdown? Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 2, 2005 Author Share Posted June 2, 2005 it still works without the parking brake wire connected but i would love the extra safety Link to comment Share on other sites More sharing options...
AWDxBOOST Posted June 2, 2005 Share Posted June 2, 2005 i dont know what acc is either, doesnt bother me Link to comment Share on other sites More sharing options...
NutBucket Posted June 3, 2005 Share Posted June 3, 2005 You guy mind posting up a wiring guide for this so I don't have to spend time probing the various wires? Thanks! BTW, where did you guys mount yours? Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 4, 2005 Author Share Posted June 4, 2005 i mounted mine with the provided 2 sided tape, under the driver side dash, next to the fuse door. Link to comment Share on other sites More sharing options...
NutBucket Posted June 4, 2005 Share Posted June 4, 2005 Did you bother hooking up the speedo lead? Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 5, 2005 Author Share Posted June 5, 2005 according to other posts we don't have a single speedo lead(that's how i understood it). Apparently there are 4 sensor(one at each wheel) that provide the ecu with speed info. if i'm wrong please forgive me but that's how i understood what was posted about it. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 5, 2005 Author Share Posted June 5, 2005 i'll get you the wiring info tomorrow. Link to comment Share on other sites More sharing options...
NutBucket Posted June 5, 2005 Share Posted June 5, 2005 Thanks man, I appreciate it. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 6, 2005 Author Share Posted June 6, 2005 Here it is: The green wire is "ON" The blue wire is "ACC" The solid white wire is "12v constant" Don't use the white wire with the black stripe, it's the starter signal. Link to comment Share on other sites More sharing options...
ralphyralph5 Posted June 6, 2005 Author Share Posted June 6, 2005 I used self tapping connectors instead of soldering(much easier). especially if you're leasing. Link to comment Share on other sites More sharing options...
NutBucket Posted June 8, 2005 Share Posted June 8, 2005 Final question. I was reading about installing a TT in a WRX and the guys there are cutting acc power to the remote lock and alarm modules in order for them to work while the car is runing. Any issues with remote locking/arming the alarm with the car running? Link to comment Share on other sites More sharing options...
