chaz517 Posted October 7, 2014 Share Posted October 7, 2014 Hey guys, installed my Innovative LC2 Wideband, and it reads 10.7 at idle, jumps around a bit, and 10.8 and 10.9 at wot. Is that accurate? At partial throttle on light loads, it drops to 7.8 and around there. That can't be right since that is soooo rich Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted October 8, 2014 Share Posted October 8, 2014 http://www.innovatemotorsports.com/support/manual/LC-2_Manual.pdf Have you done the free air calibration? Link to comment Share on other sites More sharing options...
chaz517 Posted October 8, 2014 Author Share Posted October 8, 2014 Unplugged it from the downpipe and let it run for 1 minute. No luck. Downloaded the logger and made sure it was set to gasoline as well. So frustrating! ughhhh. Thanks for the reply Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted October 8, 2014 Share Posted October 8, 2014 If that still doesn't work, maybe check your wiring? I don't have an LC2 but my LC1 gave some funky readings with a bad ground. Link to comment Share on other sites More sharing options...
chaz517 Posted October 8, 2014 Author Share Posted October 8, 2014 Thanks man, will check that out in the am! Link to comment Share on other sites More sharing options...
