Official jdm conversion/aftermarket body thread
  • 1 month later...
  • Replies 2.6k
  • 3 months later...
Hi guys,
I've noticed our name mentioned a few times on this thread, here is what we have in stock and ready to ship - thanks for everyone's support !!
Spec B Front Conversion w/ Fogs and more
http://www.hkc-speed.com/wp-content/uploads/2016/03/10.jpg
Details here: http://legacygt.com/forums/showthread.php/fs-jdm-spec-b-front-bumper-conversion-others-250921.html
K2 Front Conversion w/ Fogs and brackets
http://www.hkc-speed.com/wp-content/uploads/2015/09/k2gear-blbp-front-bumper-conversion47227a-1.jpg
Details here:
http://legacygt.com/forums/showthread.php/fs-jdm-k2-front-bumper-conversion-247983.html
Here it is...
Most Complete Retrofit List:
Sedan 05-07 (Rev A-C)
JDM Bumper
Bumper Beam (or cut USDM beam)
Bumper Brackets
Shock Absorber
Fender Liners (or cut original liners)
Fog Lights (JDM brackets, DIY brackets, or entire assemblies cut out of USDM bumper.)
Sedan 08-09 (Rev D-F)
JDM Headlights (Optional: Headlight leveling switch and plugs. Plugs available at Toyota or Lexus dealer.)(Requires rewiring and soldering skills depending on which lights you want to use and because the JDM headlight wiring connectors are different from USDM.)
Fenders
Bumper
Bumper Brackets
Shock Absorber
Fender Liners
From Leke on the Rev D-F headlight wiring:
For the Rev D-F lights, the best thing to do is to take a battery harness and use the OEM (USDM) plugs as your means to activate the relay. The other (the wires that run to the headlights) terminals can then be modified to include the JDM plugs.
This method requires more work, but the overall result is much cleaner. You could easily permanently modify your stock wiring to work with the JDM lights. But doing this will make life difficult if you ever want or need to go back to a USDM setup.
The other part that requires thinking is the parking light and turn signal. On the JDM light they're different bulbs, but the USDM turning/parking light socket is integrated into one plug. Easiest thing to do here is to use the USDM plug as it is, but solder new wiring to the terminals where the bulb would sit. This requires a steady hand, as there is visually no space to work with. But, your parking light and turn signals would function as they would on the stock car. If you ever want to go back to a USDM setup, all you need to do is source a new turn signal/parking light socket.
Someone please add this to the first post!!!
In respects to 08-09, is it 100% confirmed that the USDM hood works?
I understand that an OBXT will also need a LGT aluminum hood.
For reference.
http://i672.photobucket.com/albums/vv87/JoshEAllen/968AAF61-BE81-4195-9123-F4BA898BEE56.jpg
this is home made , when i did the extension i also shaped the lip , but i m not decided yet i wil use this lip .
i can seperate the lip from the extension side , was more easy to mold all one piece at the time
  • 3 weeks later...
http://uploads.tapatalk-cdn.com/20160417/f8b4a59606b67b26043996f62c90c6dc.jpghttp://uploads.tapatalk-cdn.com/20160417/34d64a50c8729c5a526c29098cd434ae.jpg
Will eventually order fenders and headlights so I can install this one.
