__raj Posted February 8, 2012 Share Posted February 8, 2012 Our 05 LGT has started to occasionally have difficulty (eg 3 mins crank and but no fire) starting up. We have 125k on it. Unfortunately no check engine light or other symptoms as once it starts it runs like normal (well). Any thing to check out? My wife is nervous now driving her car understandably. Link to comment Share on other sites More sharing options...
joop1987 Posted February 8, 2012 Share Posted February 8, 2012 How is your battery? Old? If the ECU loses power and resets, it takes much longer to crank over the first time. Link to comment Share on other sites More sharing options...
__raj Posted February 8, 2012 Author Share Posted February 8, 2012 Battery replaced in the last 3 yrs. The only change electrically was 4 months back we had alternator issues (spiking voltage). Link to comment Share on other sites More sharing options...
Max Capacity Posted February 8, 2012 Share Posted February 8, 2012 Spiking voltage may have damaged the battery. Take the battery to a auto parts store and have it tested. Or for $80.00 go to Walmart and buy a Maxx everstart. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rob-2 Posted February 9, 2012 Share Posted February 9, 2012 Spiking voltage may have damaged the battery. Take the battery to a auto parts store and have it tested. Or for $80.00 go to Walmart and buy a Maxx everstart. I agree. If battery is not a problem I would consider injector cleaner to rule out bad flow as a problem. I suspect battery though. FYI OP never just hold the starter over on a car that won't start for 3 minutes. If it doesn't fire up to life normally <20seconds something is wrong and that something is not fixed by holding the starter longer. Link to comment Share on other sites More sharing options...
