g2redgsr Posted June 16, 2010 Share Posted June 16, 2010 hey guys, my step dad wants me to help him recharge his AC in his 2004 Legacy, first this is does the 2004 require r12 or the newer 134a, second, any tips on how to do it, thanks a lot! Link to comment Share on other sites More sharing options...
Osei Posted June 17, 2010 Share Posted June 17, 2010 R134A. You refill through the low pressure side. IIRC the port is close to the passenger firewall. It has a grey cap with an L on it. If you just want a one time time refill, any auto place has the can with hose attached. Instructions should be on the can. If you want to do multiple vehicles at different times, buy the hose kit and then the separate cans of R134a. Procedure is you turn on car and AC to Hi connect refrigerant and open valve it will only accept until full, or the can empties. Some have a purple dye and you get a little kickback to let you know that is is done. In either case, close valve on can and remove hose. A very simple op really. The ports are different sizes so you can't mistakenly attach to the hi side. O. Link to comment Share on other sites More sharing options...
g2redgsr Posted June 17, 2010 Author Share Posted June 17, 2010 Awesome, thanks a bunch, the shop said it had a leak but i found a loose connection, so i think thats where it is, hope thats all it is, if not ill be reposting on diagnosing a leak lol, thanks again! Link to comment Share on other sites More sharing options...
g2redgsr Posted June 17, 2010 Author Share Posted June 17, 2010 Im at autozone right now it says 10lb of pressure, guess the can empty, any idea how much pressure i need? Its not blowing cold yet, thanks Link to comment Share on other sites More sharing options...
Osei Posted June 27, 2010 Share Posted June 27, 2010 sorry been away for a while. If you had a loose connection, you were probably empty and need more R143A. Just fill until it stops accepting. Either return unused cans or save for next year. O. Link to comment Share on other sites More sharing options...
