Mulenga Posted August 11, 2019 Share Posted August 11, 2019 Hello folks. I have a 1999 GT B Etune Legacy with 150,000 kms. Recently whenever I drive it hitting 120km/h the temp gauge rises, it starts overheating. What could be the problem? It doesn't overheat when driving below 120km, could it be the clutch? I recently serviced the radiator n replaced the thermostat Sent from my H4233 using Tapatalk Link to comment Share on other sites More sharing options...
RumbleRumble Posted August 15, 2019 Share Posted August 15, 2019 What coolant and what kind of thermostat did you use? Sounds like a air flow issue maybe even water pump. Make sure the cooling system is burped full then go from there. Link to comment Share on other sites More sharing options...
Mulenga Posted August 19, 2019 Author Share Posted August 19, 2019 Thanks buddy, will diffinately do that & give an update Sent from my H4233 using Tapatalk Link to comment Share on other sites More sharing options...
ace2 Posted August 20, 2019 Share Posted August 20, 2019 I've just done my fourth EJ206 cam-belt, water pump etc and it took me ages on the previous ones to properly refill cooling system. This time I made a 'burper tank' from an empty 1 litre Kikoman soy sauce bottle. Saved me hours. I think you can buy properly made ones in US but not NZ. My kludge worked fine. Link to comment Share on other sites More sharing options...
KermitDrivesASubbie Posted September 12, 2019 Share Posted September 12, 2019 Burping is rather important for these pressure systems. I had an issue after a thermo swap, would get hot sitting, then cool as I drive, I'd pull over, make sure resevior is full, undo rad cap about 1/4 turn and let Er rip. Don't open to much or you will suffer extreme burns. I promise you this! Link to comment Share on other sites More sharing options...
KermitDrivesASubbie Posted September 12, 2019 Share Posted September 12, 2019 Why don't these have a bleeder valve? Link to comment Share on other sites More sharing options...
