AidanLGT Posted January 31, 2020 Share Posted January 31, 2020 I think I blew my rear diff, what other Subaru’s used the same rear diff and axles. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted January 31, 2020 Share Posted January 31, 2020 Everything but the Spec B uses the same rear axles. You'll want a rear diff from an lgt or obxt to keep the limited slip. Wrx and sti are different. Not sure about forester xt. Some 3rd Gen outback have limited slip rear but you have to look at the markings on the diff because it was an optional equipment item. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AidanLGT Posted January 31, 2020 Author Share Posted January 31, 2020 Does it matter if it’s the five speed or auto, I found an 05 lgt part out and wondering if the diff is different Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted January 31, 2020 Share Posted January 31, 2020 Nah should be the same R160 LSD on the auto and manual. Difference of length is made up with the drive shaft. *length of transmission. Transmission and drive shaft are different. Mounting and rear lsd should be the same. Link to comment Share on other sites More sharing options...
whitetiger Posted January 31, 2020 Share Posted January 31, 2020 I think I blew my rear diff, what other Subaru’s used the same rear diff and axles. Sent from my iPhone using Tapatalk what makes you think you blew the rear diff? just for clarification. Link to comment Share on other sites More sharing options...
AidanLGT Posted February 1, 2020 Author Share Posted February 1, 2020 I thought it was my axle but I pulled the plug out and metallic liquid came out. I found an 05 lgt auto someone is parting out and it looks like the rear differential is different(it have the fins on the back plate) could I still use that or do I have to get a different one Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2020 Share Posted February 1, 2020 http://people.csail.mit.edu/ilh/vacation/ The service manual will have the answer. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
AidanLGT Posted February 1, 2020 Author Share Posted February 1, 2020 Thanks, but is there a chance you have the 07 manual or maybe I could look it up. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted February 1, 2020 Share Posted February 1, 2020 No difference 05-09 on rear diffs except spec b or non turbo. I don't think any of the lgt have the fins on the back. Maybe they've got it mislabeled as lgt which is common on used parts sites. Unless it's on here then maybe I'm just wrong. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
AidanLGT Posted February 2, 2020 Author Share Posted February 2, 2020 Ok but how do I know if I have the 4.11 ratio or the 3.9. I’ve looked everywhere for the answer but I can’t find one for an 07 gt 5 speed Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Nonamedude Posted February 2, 2020 Share Posted February 2, 2020 (edited) You know what. I apologize. I forgot they made that difference. The outback are all 4.44. Edited because I was giving terrible information. Edited February 2, 2020 by Nonamedude Link to comment Share on other sites More sharing options...
AidanLGT Posted February 2, 2020 Author Share Posted February 2, 2020 Don’t I have to get a center diff also? Sorry I’m new to all this and haven’t figured things out yet. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted February 2, 2020 Share Posted February 2, 2020 From https://www.rallispec.com/downloads/Transmission%20ID%20Chart_Public.pdf Looks like you have a 3.9 rear diff. If you are just in need of a rear diff, then it looks like the 08-10 WRX or 08-09 LGT rear diffs should work. The center diff is typically within the transmission housing for manuals. The rear diff ratio needs to match the tranny. You can't just put a 4.44 or 4.11 rear diff on a tranny that's built for a 3.9, it'll eat itself. You can swap both tranny and rear diff if they match. I have an outback 4.44 5sp and rear diff in my '05 LGT because they had less than half the miles of my stock tranny. Hope that helps. Link to comment Share on other sites More sharing options...
Nonamedude Posted February 2, 2020 Share Posted February 2, 2020 Don't listen to me. I apologize. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Infosecdad Posted February 2, 2020 Share Posted February 2, 2020 Don't listen to me. I apologize. Sent from my iPhone using Tapatalk No worries, I learn new stuff every time I read through the forums. Link to comment Share on other sites More sharing options...
AidanLGT Posted February 2, 2020 Author Share Posted February 2, 2020 Thanks for the help. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
