gregrock1989 Posted October 29, 2018 Share Posted October 29, 2018 So I got my 05 Outback XT about a month ago. I've done 2 oil changes already. It has about 235k (KM). The previous owner used Rotella T6 and ive been using the same. The first time I changed the oil I noticed a small amount of metal in the used oil. Yesterday when I changed it again there seemed to be alot more, all very small flakes but can still be felt with my hand when wiping my drain pan clean. There was one peice however that was the size of a fingernail clipping. I've also noticed an intermittent sound at idle. It's only happened 2 or 3 times, but when I push the gas the rpm will shoot up as normal, but will drop down below 1000 and make this ticking sound which I recorded and will attach a link (https://youtu.be/rGUW1BelKIA). The sound always goes away once the idle goes back to normal. So what do you think the damage is gunna be? Link to comment Share on other sites More sharing options...
ehsnils Posted October 29, 2018 Share Posted October 29, 2018 First step - don't drive it anymore, metal flakes in the oil will find its way into the bearings. Maybe it's too late, maybe the previous owner did replace the turbo and didn't clean up the engine. It can also be a rod bearing that's spun. Link to comment Share on other sites More sharing options...
relative4 Posted October 29, 2018 Share Posted October 29, 2018 If you can already see metal, it's too late. For the turbo and the engine. Sorry dude. Link to comment Share on other sites More sharing options...
m sprank Posted October 29, 2018 Share Posted October 29, 2018 If you are panning for gold, your bearings are gone. Link to comment Share on other sites More sharing options...
whitetiger Posted October 29, 2018 Share Posted October 29, 2018 Ynansbat Link to comment Share on other sites More sharing options...
AWDFTW Posted October 29, 2018 Share Posted October 29, 2018 New engine time. Link to comment Share on other sites More sharing options...
gregrock1989 Posted October 29, 2018 Author Share Posted October 29, 2018 So when you guys say "too late" what do you mean by that? Too late to save the engine? I'm willing to rebuild it but not willing to get a used engine which is probably fubared too... Link to comment Share on other sites More sharing options...
ehsnils Posted October 29, 2018 Share Posted October 29, 2018 Every bearing surface is probably damaged, oil channels filled with metal and cam shafts uses the heads as bearings, not separate bearings. You'd got to replace a lot in the engine. Get a used engine and build from it. Just get it from a source that you can return it to or get money back. The old engine is good to donate sensors and some other uncontaminated stuff if needed. It's always good to have a backup donor unit for some minor parts that may be missing from a purchased replacement engine. Link to comment Share on other sites More sharing options...
AWDFTW Posted October 29, 2018 Share Posted October 29, 2018 ^^^ what he said. Link to comment Share on other sites More sharing options...
ttnio Posted October 29, 2018 Share Posted October 29, 2018 yes, all the above is true, use a heavier oil (20-50wt) for your next oil change. it could quiet or cut down your ticking and reduce your intermittent noise. Link to comment Share on other sites More sharing options...
gregrock1989 Posted October 29, 2018 Author Share Posted October 29, 2018 I've been looking and finding such a used motor would be incredibly difficult to find around here, especially an Ej255 and in a decent period of time. This is my only car unfortunately. So I shouldn't try and rebuild it? Link to comment Share on other sites More sharing options...
Tronic Posted October 30, 2018 Share Posted October 30, 2018 Buy a new car mate, its way less stress than trying to rebuild an engine. I don't think anyone tries to rebuild engines out here anymore, second hand cars are now so cheap. Get a decent car and look after the fluids. Link to comment Share on other sites More sharing options...
awfulwaffle Posted October 30, 2018 Share Posted October 30, 2018 FWIW, Millenium Auto Sales in the greater Detroit area will sell you a rebuilt long block with timing, oil pump, water pump and AVCS solenoids for $5300 USD. I came to realize that's not a bad price once you factor in machine work and cost of OEM parts. Not too far from you either, could definitely rent a truck and pick up a motor in a day. http://y2kimports.com/engines/ Link to comment Share on other sites More sharing options...
m sprank Posted October 30, 2018 Share Posted October 30, 2018 It may be usable for rebuild. But expect to pay in the 6500usd range depending on the damage. Link to comment Share on other sites More sharing options...
gregrock1989 Posted October 30, 2018 Author Share Posted October 30, 2018 What would make it unusable for a rebuild? Im not doing it myself. My mechanic said he can do it for about $4800 (CAD) Link to comment Share on other sites More sharing options...
Guest Posted October 30, 2018 Share Posted October 30, 2018 Procedure is simple: Use new shortblock (do not bother with rebuild, not worth it) Have a machine shop refresh the heads Buy new oil cooler (NEVER REUSE OLD ONE) Other parts (turbo) replace as needed. The work is easy if you have access to a garage and tools. Paying someone to do all that may not be worth it, but it depends on the condition of the car. Link to comment Share on other sites More sharing options...
Lewegee Posted November 1, 2018 Share Posted November 1, 2018 Just learned I've got the copper chunks of the bearing shells in my pan too...quote was similar to infamous plus some machining, etc. Def going for piston upgrades. Link to comment Share on other sites More sharing options...
05MNLGT Posted November 1, 2018 Share Posted November 1, 2018 Procedure is simple: Use new shortblock (do not bother with rebuild, not worth it) Have a machine shop refresh the heads Buy new oil cooler (NEVER REUSE OLD ONE) Other parts (turbo) replace as needed. The work is easy if you have access to a garage and tools. Paying someone to do all that may not be worth it, but it depends on the condition of the car. i'd say oil cooler and oil pump. Link to comment Share on other sites More sharing options...
05MNLGT Posted November 1, 2018 Share Posted November 1, 2018 i spent several days with subaru jdm techs over my failure. couldn't pin point the failure cause. they took the broken parts with them. normal start up, super cool out. 5 mins after drive, loud crack and engine light on. the belt wrapping around the crank saved the engine. gates looked over the belt and said it wasn't the cause. subaru agreed. all sprockets and gears were free moving. the scoring in the heads happened at the front, none towards the back. subaru was going to do forensics on the metals that snapped. Link to comment Share on other sites More sharing options...
Guest Posted November 1, 2018 Share Posted November 1, 2018 JDM techs? Link to comment Share on other sites More sharing options...
05MNLGT Posted November 1, 2018 Share Posted November 1, 2018 JDM techs? that's what i called them. they were from jpn here working with the dealership at the time. i guess they come over here off and on. Link to comment Share on other sites More sharing options...
Guest Posted November 1, 2018 Share Posted November 1, 2018 I had a similar mystery failure in similar conditions 10 years ago. Cold morning. Started. Got up a hill maybe 200 meters, engine dead. Timing belt jumped few teeth. Bent valves. Front passenger side cam journal and cam were scored, much like in your pictures. The cam could still freely move. That was not too long after a sketchy turbo install which sent shards of the compressor cover into the intake. But the root cause was never identified. Link to comment Share on other sites More sharing options...
m sprank Posted November 1, 2018 Share Posted November 1, 2018 Its what makes a Subaru a Subaru. Sharing the love translates to "buying an engine" in Japanese. Link to comment Share on other sites More sharing options...
