Jolbaru_LGT Posted May 19, 2022 Share Posted May 19, 2022 So, I just completed the struts all around, and 1/2" saggy butt spacers. But my butt is still saggy. So, I looked at my trailing arms, and the bushings in front of the arm look shot. Now, my question is, it looks like there are a couple of options. I see pretty Spec B Trailing Arms, but the prices range between 600-1k for a complete set, even used. I'm not liking that. I know Aluminum is lighter, but the advantage to the steel ones? Not sure if it's worth all that labor. I see there's a method where you torch out the old ones and put in new ones. How's that work for anyone who's tried it? I had a Volvo 240 where you could make a tool to press out the TABs and it worked decent. Not sure if anything like that is available DIY or otherwise. Finally, poly or OEM rubber? Thanks a million in advance as usual. -Joel Link to comment Share on other sites More sharing options...
blackobxt Posted May 19, 2022 Share Posted May 19, 2022 Torch them and cut out the sleeve, use a hole saw and cut out the sleeve both these options work. Or just take it to a shop and have them pressed out. Sometime they will even do it for free Link to comment Share on other sites More sharing options...
boxkita Posted May 19, 2022 Share Posted May 19, 2022 take it to a shop. so much less hassle and abuse of your parts Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Jolbaru_LGT Posted May 20, 2022 Author Share Posted May 20, 2022 Thanks! Poly or Rubber? Link to comment Share on other sites More sharing options...
