jasejase Posted October 8, 2012 Share Posted October 8, 2012 Hey Mike... Im looking to order one of your saggy butt kits. My newly installed pinks have a SLIGHT sag in the rear. WOuld you recommend ordering the precise size you need to raise it? Or is there some math involved? I've been told by a couple ppl, that if you wanna raise it up 3/8", order the 1/4" kit, as the suspension load lessens... Looking for your rec before i order! Thanks Link to comment Share on other sites More sharing options...
m sprank Posted October 8, 2012 Share Posted October 8, 2012 Order the shim you need in the size you need. The shims are placed on top of the top hat. Essentially thickening it. They do not preload the springs at all. If you want to go up 3/8" use 3/8" spacers. Link to comment Share on other sites More sharing options...
jasejase Posted October 8, 2012 Author Share Posted October 8, 2012 Thanks mike... How long do you recommend letting this thing settle before taking the final assesment for spacer sizing? its been just about 2 days now. Also, im thinking the easiest way to do this is, just to take out the entire rear strut so im not fighting it the entire time, even if i dont have to replace the studs.... ? Link to comment Share on other sites More sharing options...
m sprank Posted October 8, 2012 Share Posted October 8, 2012 I would wait 2 weeks. Easiest to just drop the rear strut out, slap on the shim and put the strut back in. Link to comment Share on other sites More sharing options...
jasejase Posted October 8, 2012 Author Share Posted October 8, 2012 Thank you sir... Two weeks huh? Maybe the front will continue to drop during that time, and i wont need em... here's to hoping! oh well, i will push the alignment off a bit. Thanks Link to comment Share on other sites More sharing options...
