Mr.RMFC Posted September 12, 2018 Share Posted September 12, 2018 Hey Guys, on my 05 Legacy GT I am getting -1.75 degree of camber on the rear and it looks like there is a bit of a sag (more so on one side than the other). Any thoughts on what the cause could be? I have had some people say its the shocks/struts and others saying it could simply be the matter of a bushing that is gone. A mechanic friend of mine said the shocks and struts looked fine on a quick look but he didnt get into it. Thoughts? Link to comment Share on other sites More sharing options...
whitetiger Posted September 12, 2018 Share Posted September 12, 2018 well sag can really only be spring related since its springs and springs alone that hold the weight of the car up. if a rear spring has cracked or worn out, then the car will have a lower ride height and negative camber will increase due to the lower ride height. bushings and shocks can contribute slightly, but id be looking at your springs first. Link to comment Share on other sites More sharing options...
Mr.RMFC Posted September 12, 2018 Author Share Posted September 12, 2018 So going with the assumption that it is the springs. Aside from other Legacy's, What other subaru's could I take the springs from and use if any? (WRX/Outback/Forester ect) Link to comment Share on other sites More sharing options...
zaso Posted September 12, 2018 Share Posted September 12, 2018 If my memory serves me right, no other springs will work outside of Legacys. Outbacks will be too tall, and I dont believe WRX/Forester springs are compatible. Link to comment Share on other sites More sharing options...
whitetiger Posted September 12, 2018 Share Posted September 12, 2018 finding a pair of oem rear springs for a LGT shouldnt be a chore. (you should replace them in pairs) Link to comment Share on other sites More sharing options...
Mr.RMFC Posted September 12, 2018 Author Share Posted September 12, 2018 whitetiger I live in Canada and Haven't seen parts for my car come up on any classified near me for almost 2 years. Link to comment Share on other sites More sharing options...
jrho Posted September 12, 2018 Share Posted September 12, 2018 whitetiger I live in Canada and Haven't seen parts for my car come up on any classified near me for almost 2 years. Noticed you're in Saskatchewan. Have you checked kijiji? I took a quick glance for there's a few Legacy's being parted out and even a set of 2005-2009 legacy tein coilovers for sale listed there. Another possibly is to get in touch with auto wreckers as well. I would confirm that there is something wrong with your springs before getting a replacement pair though Link to comment Share on other sites More sharing options...
Mr.RMFC Posted September 12, 2018 Author Share Posted September 12, 2018 I have looked on kijiji. And I have already talked to the guy with the Tein Coils. taking it in for diagnosis before I buy anything. All the legacy's being parted out seem to be the base model which has a different suspension than the gt Link to comment Share on other sites More sharing options...
jrho Posted September 12, 2018 Share Posted September 12, 2018 I have looked on kijiji. And I have already talked to the guy with the Tein Coils. taking it in for diagnosis before I buy anything. All the legacy's being parted out seem to be the base model which has a different suspension than the gt Someone will probably correct me if I'm wrong, but the normal Legacy's and the Legacy GT share the same suspension. The spec B has different suspension so there shouldn't be an issue getting a pair of springs from a 2.5i Legacy Link to comment Share on other sites More sharing options...
nevets27 Posted September 13, 2018 Share Posted September 13, 2018 I'm sure you could buy new from a dealer. I know I got springs for my 1994 and they were surprisingly reasonablely priced. Link to comment Share on other sites More sharing options...
relative4 Posted September 13, 2018 Share Posted September 13, 2018 Post a WTB in the marketplace here. Plenty of people have them, hardest part is international shipping. Link to comment Share on other sites More sharing options...
JmP6889928 Posted September 13, 2018 Share Posted September 13, 2018 Springs are cheap, especially for 13 year old cars. You can find new from a lot of sources and make sure you have good parts then. If you go with used, you run the risk of doing the work and ending up with the same result you have now. Link to comment Share on other sites More sharing options...
chhrisd Posted September 14, 2018 Share Posted September 14, 2018 i'd recommend checking the rear front trailing arm bushing. the rubber bushing will separate from the sleeve over time, and could put the knuckle on a tilt. if you notice that the rear of your car rocks side-to-side when you go over bumps, this is why. it's circled in red in this diagram. Link to comment Share on other sites More sharing options...
Mr.RMFC Posted September 24, 2018 Author Share Posted September 24, 2018 Just an update. I took it to a buddy who is a subaru tech. He said on a quick look it would probably be the springs going out. Link to comment Share on other sites More sharing options...
whitetiger Posted September 24, 2018 Share Posted September 24, 2018 5 points for me! Link to comment Share on other sites More sharing options...
Ilubeyousubaru Posted September 26, 2018 Share Posted September 26, 2018 How bad is the rebound on the shocks? I have similar issues with sagging but I don't have another legacy to compare it with. If I hold the rear end down and with my body weight and let go, it doesn't bounce. But if I jump on it with my arms, it bounces one round. Link to comment Share on other sites More sharing options...
edgemoulic Posted September 29, 2018 Share Posted September 29, 2018 I replace mine with a new one a year ago, spring was twisted both of the shocks and got an aftermarket so far so good. Link to comment Share on other sites More sharing options...
Mr.RMFC Posted October 3, 2018 Author Share Posted October 3, 2018 So on that note. Anyone selling coilovers for a good price?? Link to comment Share on other sites More sharing options...
