My 05 LGT Tell me what you think
My 05 LGT aka Legacsti
Follow me on IG @Legacsti
Exterior:
JDM Front Bumper
Ewg dump tube custom out the hood
JDM Grill painted Black with custom decal
Tinted Windows
6000k Hid's
Carbon Fiber Roof spoiler
Cleared Headlights
Clear Turn signal Bulbs
R-revv Carbon Fiber Hood Scoop
Hella Horns
Custom Legacsti badge
Hancook Tires
Eyelids V2
BBS Painted 03 Lambo Purple 04 STI rims
Rain X Wiper Blades
(2) Misimoto radiator caps
Meagan Racing Coil-overs
Front 05 Sti Black Brembo's
Front 04 Sti Rotors
upgraded Battery
Front & rear SS Brake Lines
Rear Brembo's
Rear DBA Conversion rotors
Custom brackets for rear brembo's
Black muteki Lug Nuts
R-rev spec D rear Lip spoiler
Custom cut Lower Bumper to fit Fmic
Custom made Whitey Cross Member
License plate delete
Hide away license plate kit
Whiteline Rear sway bar
Moog Front Sway Endlinks
Moog Rear Sway Endlinks
Moog Front lower ball joints
Rock auto Beefier front axles
Interior:
AEM Wide Band
Aem Boost Gauge
Glow shift Oil pressure Gauge
STi pink medal with black pedals
Upgraded Diamond audio interior speaker
Custom weighted shift knob
RTG AWD Battery tie down
All weather floor mats
Triple pod pillar
Greddy Oil Cap
Grimm speed Pitch stop mount
05 Sti Front & rear Seats
Blue Motor
Custom alternator brackets
Custom FPR bracket
After market Coolant over flow
Manual cluster, immobilizer, harness and ECU swap
Aftermarket Short shifter
Tranny painted purple
Intake manifold painted blue purple
Tgvs painted purple
Engine/Power:
Tuned by Tim @ Larsen autoworks T&W
Grimm speed electronic Boost Controller
Side Exit Exhaust Straight pipe by Whitey
Cherry bomb
Perrin 3” Inlet
Grimm speed Up pipe
Tial MVS 38mm External Waste gate
Cobb Down pipe
Grimmspeed 160 Thermostat
DW300 Fuel Pump
Blouch Dom 4.0
Impreza custom Intake Manifold Rotated
Tial BOV
5spd Tranny Swap 05 OBXT
Moore Blast plates
05 OBXT Rear Diff 4.44 gear ratio
OBXT Center diff
Custom 1 piece aluminum Drive shaft
ACT 6 puck Clutch with light weight fly wheel
Perrin FMIC with custom piping
NGK Iridium Spark Plugs
KStech 3inch intake
TGV Deletes
Rallispec Short Block
Manley 4340 steel H-beam conrods, Cosworth forged pistons, ACL main and rod bearings, Factory nitrided crankshaft
GT Spec Equal Length Headers
Aeromotive FP regulator
Upgraded steal braided fuel lines
FIC Top feed conversion kit and Rails
FIC 1680cc injectors
Crawford AOS
Agency Light Weight crank pulley
Gates Timing belt kit
GSC S2 Cams
BC Valve Springs & Retainers
Ported Cylinder Heads exhaust & intake
Ported intake manifold ports on top of the motor
Mishimoto Radiator
Mishimoto Lower radiator hoses
Sti Silicone upper radiator hose
Scott’s racing radiator fans
AC System Deleted
Shell Rotella 15W 40 Oil & 1 Qt of Lucas
Summit inline fuel filter
Edited by Legacsti11
05 Legacsti with toys, Efi Logics Tuned, Whitey Built
  • Replies 361
Looks good.
Pics of motor?
More pics are coming it just takes so long for them to upload on this forum. I will put one up of the motor the way it is now. I have a bigger turbo, intake and FMIC going in after I build the bottom end.
Nice. Clean. A little too low for my taste, I can't imagine what the ride feels like.
Definitely needs more wide.
Grill looks like it was done well, except a bit of filler and sanding could get rid of that center gap.
The rear end is my favorite shot, though... Good choice on the de-badge. Cans look good!
Not the tires, all LGT's need at least 17x7.5 with a +48 wheel in my opinion.
Your car looks great, just not a fan of the stock wheel size and offset. Needs more wide.
Oh ok I see what your saying. Idk I like to keep it a sleeper for the most part, plus the stock rims are pretty light enough believe it or not.
Thanks a lot man. I got another pic of the rear coming uploading it now. I like the stock rims cause there light and keep the sleeper status :) My brother plasti dipped the grill in black and did the whole custom look. Thanks bro :) I never thought to get rid of the center gap. Will probably just leave it or maybe do it in the future. Hmm something to think about. Got to debadge it to keep that smooth sleeper status lol.
STI swapped TMIC and IM
what else?
interior pics?
looks nice
I donated to LegacyGT.com which allows me to have this nifty signature. :p
If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire :lol:
Are your headlights blacked out? Hard to tell.
IMO Do the headlights, and plasti dip the fog covers black to match the grill and your front end will be as clean as the back!
The headlights aren't blacked out but I do want to take that stupid orange reflector out on both sides like it stole something from me lol. I might definitely have to take you up on the plasti dipped black fog covers. Just going to wait cause I am going to install my FMIC soon.
what else?
interior pics?
looks nice
Thanks man. I am going to have to take some interior pics soon untill I do I will be posting up my mods under the pics.
The fog covers are a piece of cake, but FMIC install would be a good time to do it since you'll be messing w/ the front bumper as it is.
The "cleared" reflector looks great on Silver, so you'd be headed in the right direction there.
Yea it would be a good time but can I put my fog covers back on? I ask this cause with my FMIC I'm almost positive I loose my fogs. Then again I heard it might be possible to flip the intercooler upside down and then the pipes would run above the fogs and then I could keep them? I def want to do the cleared reflector look as headed in the right direction makes me feel warm inside :)
Ha! Glad I can give you a warm n' fuzzy. I think most would agree, too.
I can't speak about the Godspeed FMIC fitment w/ fogs, but flipping the IC upside down is possible, assuming you can fit the puzzle pieces together and get the piping to fit.
I must say it is usually hard to give me a warm n fuzzy so cudoz's no homo lol hahaha. It will be tough on the fmic puzzle peices and fitting but friend who is my installer works some magic and is pretty good. He did my external WG custom job and it came out great. I have great confidence in him because of that and other jobs he has done for me and other friends in the past.
It could definitely use simple green lol one of these days I will get around to it. People see the plate and will still think ah it's just a legacy with a STI swap probably stock everything else mean while there are plenty of goodies and I am throwing in 4 parts, on top of a new short block with in these next 2 weeks :)
