John M Posted October 21, 2009 Share Posted October 21, 2009 That's right, put a 70mm MAF housing on your car for a whopping $12 at any AutoZone, Advance Auto Parts, or anywhere else that sells Spectre brand parts. You can also get it online on Amazon.com. It's chromed plastic but how much force are you putting on it anyway? It includes rubber gaskets to go between the housing, adapter, and sensor for an airtight fit. Fits w/ WBR FMIC piping and that's an APS intake pipe in the pic (the rubber coupler between the MAF housing and metal intake tube comes with the APS pipe). Still a "short ram" that happens to reach into the fenderwell without having to worry about puddles or heavy rain. Yes, that's a Spectre brand filter too, just to irritate the air filter purists out there http://moojohn.com/subaru/intake1.jpg http://moojohn.com/subaru/intake2.jpg Scaling: [Table2D] 0.90 0.94 0.98 1.02 1.05 1.09 1.13 1.17 1.21 1.25 1.29 1.33 1.37 1.41 1.48 1.56 1.64 1.72 1.80 1.88 1.95 2.03 2.11 2.19 2.23 2.34 2.42 2.54 2.66 2.77 2.89 3.01 3.12 3.24 3.36 3.48 3.59 3.71 3.83 3.95 4.06 4.18 4.30 4.41 4.49 4.57 4.61 4.65 4.69 4.73 4.80 4.88 4.96 5.00 1.56 1.80 2.05 2.30 2.57 2.88 3.23 3.62 4.05 4.49 5.00 5.67 5.94 6.57 7.95 9.44 10.51 12.24 14.09 16.19 18.53 21.16 24.06 27.24 29.00 34.56 38.65 46.49 54.22 62.62 71.79 81.79 92.34 103.77 116.19 129.69 144.28 159.94 176.70 194.69 214.03 234.95 257.49 281.73 298.89 317.11 326.62 336.36 346.35 356.56 377.37 399.03 421.57 433.31 Note that I have NOT finished checking this with the wideband for open loop fueling but the closed loop is within +/- 4 grams. The 40+ correction on Learning View is within .2 grams. I'm sure you'd want to do your own fine tuning anyway. 99% of the work is done with this table. Credit for the original makeup of this table goes to NSFW, who had input from Sponaugle at NASIOC. Link to comment Share on other sites More sharing options...
John M Posted October 22, 2009 Author Share Posted October 22, 2009 I see -- if something's cheap, nobody's interested. Same silence on the WRX board. If someone decided to slap a logo on it and call it a "kit" and it would suddenly become Product of the Year. I'm sorry to have killed the Cash Cow but people have paid triple-digit prices for an 8-inch section of pipe for too long. It's always been a case of "what else can you do" -- well now there is an option. I guess I should have bought them in bulk, re-packaged them, and sold them for $100 each. Link to comment Share on other sites More sharing options...
mattg Posted October 22, 2009 Share Posted October 22, 2009 If it works well that's all that matters. Good stuff! Link to comment Share on other sites More sharing options...
Guest Posted October 22, 2009 Share Posted October 22, 2009 Nice, thanks for sharing! Link to comment Share on other sites More sharing options...
rao Posted October 22, 2009 Share Posted October 22, 2009 I have submitted you for the Nobel price in physics! Great idea. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
mattg Posted October 22, 2009 Share Posted October 22, 2009 ^ he's a shoe in. Link to comment Share on other sites More sharing options...
brooklyngenius Posted October 22, 2009 Share Posted October 22, 2009 I always hated how much these companied charge for intakes. useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
spec.B Dream Posted October 22, 2009 Share Posted October 22, 2009 Looks great. I'll keep this in mind when I get itsme's FMIC. Link to comment Share on other sites More sharing options...
jfg22557 Posted October 23, 2009 Share Posted October 23, 2009 70mm providing enough headroom with that fp green? dont know how cold it gets near you, but I had to ditch my typhoon and get a prototype (if you want to call it that) 73mm avo style intake with an aem filter from KS tech to suite my hta68. Link to comment Share on other sites More sharing options...
John M Posted October 23, 2009 Author Share Posted October 23, 2009 Only running a peak of 15 psi right now since I haven't got the fuel mods in yet. Max airflow I've seen is around 290g so far. I need to check the AFR in open loop before swapping injectors and the weather just hasn't cooperated the past two weekends. Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 23, 2009 Share Posted October 23, 2009 70mm providing enough headroom with that fp green? dont know how cold it gets near you, but I had to ditch my typhoon and get a prototype (if you want to call it that) 73mm avo style intake with an aem filter from KS tech to suite my hta68. that depends on how much you want to pull out of the fp green. i am running a ks tech 83mm maf pipe because of my fp green. your maf sensor will max you out depending on how much boost you want to push. i believe it's around just over 21 psi. after that it will be your map sensor that will max you out at 22.3-22.5 psi Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 23, 2009 Share Posted October 23, 2009 Is this it? http://www.spectreperformance.com/#CATALOG.8705 Another question, is it better to have the MAF right after the filter vs. away from the filter? Seems to me the best MAF location is as close to the turbo inlet as you can get it. I might make a custom CAI using this and some tubing when I go to fab my FMIC pipes. Link to comment Share on other sites More sharing options...
John M Posted October 23, 2009 Author Share Posted October 23, 2009 That's the one. The hose comes with the APS intake pipe but Spectre also sells silicone couplers in that size. Note that the official size is actually 73mm internal diameter. The flow is very close to another vendor's 70mm pipe with adjustments made by me. Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 23, 2009 Share Posted October 23, 2009 i would imagine that the maf sensor being closer to the filter would be better as you are reading the temp of the air coming right in as opposed to the maf being closer to the engine and reading possibly heated up air because it's closer to the block Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 23, 2009 Share Posted October 23, 2009 i would imagine that the maf sensor being closer to the filter would be better as you are reading the temp of the air coming right in as opposed to the maf being closer to the engine and reading possibly heated up air because it's closer to the block but wouldn't that be more accurate / "real" ? IMO the best place to measure incoming air would be just prior to the TB, but of course that is not an option. Link to comment Share on other sites More sharing options...
LGTspecB1657615261 Posted October 23, 2009 Share Posted October 23, 2009 ha... just noticed the location of your overflow tank. Did you have to move it to get out of the way of the FMIC cold-pipe? I have been considering moving the washer fluid tank and going that route with my FMIC piping (similar to the hot side), but I guess the overflow tank is a little easier to move. Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 23, 2009 Share Posted October 23, 2009 yeah, that has been moved because of the cold pipe. Link to comment Share on other sites More sharing options...
John M Posted October 24, 2009 Author Share Posted October 24, 2009 The overflow is easy to move. The washer reservoir gets rotated a little (drill a new hole in its plastic mounting area) and would be a huge PITA to relocate. As far as air temps go, it matters only at the point it's being measured. In other words, the temp is vital to the mass sensor's accuracy but as long as both samples are happening at the same spot the resulting airflow reading will be the same. Link to comment Share on other sites More sharing options...
pre-dent Posted October 24, 2009 Share Posted October 24, 2009 I used one of these when messing with a custom intake on my 2.5i... I made a dumb mistake though and installed the MAF in the wrong direction. The car would instantly die after starting so I thought it was just an incompatible part. I put everything back to stock and figured out my mistake the next day. Haven't had the desire to re-try, but I may try to use it again with my K&N cone filter. You do get what you pay for, small plastic adapter pieces and an overall cheap feel to this part. Link to comment Share on other sites More sharing options...
sleeper8406 Posted October 24, 2009 Share Posted October 24, 2009 Great idea ....kudos sir....kudos Link to comment Share on other sites More sharing options...
John M Posted October 24, 2009 Author Share Posted October 24, 2009 I also had the sensor backwards the first time It's plastic, that's true. It's also not under any stress (assuming you don't try to use it in a blow-through setup) so that doesn't really matter. Your stock part was plastic too. I certainly hope that if you were going to put it on any Legacy, GT or 2.5i, you'd tune for it because the airflow readings will be WAY different than the stock setup -- off far enough that it will cause driveability problems at the least and engine damage at the worst. The sensor adapter pieces are very well made, with rubber gaskets for each step to ensure an air-tight seal. I found nothing lacking here at all. I bought this car new so I'm not about to jeopardize a $35k (car + mods) investment by using something I wasn't comfortable with. At the same time, I refuse to pay anyone $100-200 for a piece of pipe with a hole in it just because it's metal. If you're not looking for a setup that puts the filter where the fog light is, this fits the bill nicely. You can't tell it from the pics but my filter is so big it almost touches the outside wall of the fender, giving me plenty of fresh air without worrying about water getting in. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted October 24, 2009 Share Posted October 24, 2009 Did you buy the filter from the same place? Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
John M Posted October 25, 2009 Author Share Posted October 25, 2009 Yeah, it's the biggest Spectre air filter they sell. It'll fit up to a 4-inch intake but the supplied adapter works fine to connect it to the 3". The MAF housing is part of their "universal intake kit" line that you can extend further into the fenderwell if you wanted. Each piece has a locking gasketed connector for a solid leak-proof connection. I just went the plain & simple route. Link to comment Share on other sites More sharing options...
NJLGT Posted November 26, 2009 Share Posted November 26, 2009 is this possible to run without tuning right away? Link to comment Share on other sites More sharing options...
John M Posted November 27, 2009 Author Share Posted November 27, 2009 I wouldn't run it without at least copying the MAF table I posted. The tube is too much larger than stock for the ECU to compensate on its own but the MAF values I gave are perfectly safe to drive on. Link to comment Share on other sites More sharing options...
