Lobster Boat Posted December 9, 2015 Share Posted December 9, 2015 Hi all, Just recently picked up a 2005 LGT Wagon with only 64k on the clock. While it is at the shop being once-over'd, I have been purchasing parts. I'll start a build thread within the coming weeks. Anywho, I am looking for wheels to replace the OE's (they're really beat up). I've grown partial to "classic" wheel designs on the LGT, like BBS LM's and OZ Futura's. Sounds like I answered my question, no? Why not just buy those? Two things: First, I can't afford $4,000/set, especially on a DD. Second, the replicas I've found only offer (for subaru's) extremely low offsets of 35 >. I am looking for a 45 or 48 (I am not the biggest fan of low-life and do not want to run excessive neg. camber to tuck the wheel). So what direction can you guys provide to me? Here's some pics for inspiration: http://i68.tinypic.com/97lk7s.jpg http://i68.tinypic.com/2ltljcj.jpg Link to comment Share on other sites More sharing options...
fedaykin Posted December 10, 2015 Share Posted December 10, 2015 What about these? http://fifteen52.com/collections/cast-wheels Link to comment Share on other sites More sharing options...
Drift Motion Posted December 10, 2015 Share Posted December 10, 2015 35 is extreme low offset? what world are you living in... Link to comment Share on other sites More sharing options...
Lobster Boat Posted December 10, 2015 Author Share Posted December 10, 2015 35 is extreme low offset? what world are you living in... I may be wrong but I thought our stock wheel offset spec is +55? The rule of thumb I was always exposed to was anything +15mm over OE spec is considered extreme. Link to comment Share on other sites More sharing options...
asianrage Posted December 12, 2015 Share Posted December 12, 2015 If you do go 35, on even regular 215/45/18, you will need to roll your fenders. Unless this isn't true.... Sent from my Nexus 6P using Tapatalk Link to comment Share on other sites More sharing options...
Drift Motion Posted December 12, 2015 Share Posted December 12, 2015 I may be wrong but I thought our stock wheel offset spec is +55? The rule of thumb I was always exposed to was anything +15mm over OE spec is considered extreme. please do more research offset doesn't mean everything, it's nothing without width of wheel Link to comment Share on other sites More sharing options...
Lobster Boat Posted December 14, 2015 Author Share Posted December 14, 2015 please do more research offset doesn't mean everything, it's nothing without width of wheel You are correct! I assume you think my concerns of "extreme" are in regards to mechanical stress? In this instance, I am apprehensive to use a "low" offset wheel (low in this case) is in regards to fender-to-wheel proximity. In almost any circumstance, adding +15mm of offset to an OE spec will, given the vertical distance of the hub to the chassis is decreased under load, require body modification. I don't want to roll fenders, is all! Link to comment Share on other sites More sharing options...
Drift Motion Posted December 14, 2015 Share Posted December 14, 2015 go with what you want, and most likely the next thread you start will be something like "why doesn't my car look like the pictures I posted before" It's like saying you want all the visual stuff, but don't want to modify anything Link to comment Share on other sites More sharing options...
Lobster Boat Posted December 15, 2015 Author Share Posted December 15, 2015 go with what you want, and most likely the next thread you start will be something like "why doesn't my car look like the pictures I posted before" It's like saying you want all the visual stuff, but don't want to modify anything I don't follow... did you read my original post? I am inquiring about any wheels that look like those featured in the pictures I originally posted. I specifically mentioned that I don't plan on slamming the car... that is the whole point of the post. I didn't say I wanted my car to look like the pictures... I am simply asking for input on wheels that look like those OZ's/BBS's that fall within my target offset. I came to this forum for advice, since my searching turned up few results. ... so do you have any ideas? Link to comment Share on other sites More sharing options...
fedaykin Posted December 20, 2015 Share Posted December 20, 2015 http://www.rotawheels.com/wheels.php Link to comment Share on other sites More sharing options...
s2baru Posted December 23, 2015 Share Posted December 23, 2015 http://legacygt.com/forums/showthread.php/idaho-o-z-racing-leggera-hlt-wheels-248077.html Link to comment Share on other sites More sharing options...
