drdex337 Posted July 15, 2012 Share Posted July 15, 2012 So when doing the work on my car I was out of money but had a problem with my rear diff "knocking" under acceleration (meaning the rear diff bushing had failed). So here is a creative method my buddy used to fix it and after driving it for months I must say it works great: I basically cut some slices off a hockey puck and installed them in the free space in the diff bushing, the top and bottom. I installed a piece in the top, then jacked the diff up which compressed that piece and forced another piece in the bottom. I did this with both bushings and when I was done the thing was not moving at all even with the weight of the car on the diff. I then bought and used some of this 3M window polyurethane sealer which gets really hard when it dries and filled in all of the other gaps. I then covered it all up with some large washers. When it dries it should be firmer than stock (STI time). I got the idea for all of this reading a bunch of forums. I guess the 3M stuff is really popular for making more ridged engine/trans mounts and stuff and is really durable. People have also used it to stiffen the diff bushings. Pictures attached. Link to comment Share on other sites More sharing options...
compsurge Posted July 15, 2012 Share Posted July 15, 2012 Honda-tech to the rescue. Glad to see it works! Link to comment Share on other sites More sharing options...
