boostedgrocerygetter Posted September 13, 2012 Share Posted September 13, 2012 Yea yea I know. Has anyone ran the Cobb Eco tune with a stg 2 setup. I drive 47 miles each way to work. And I'm not looking to race anyone to or from work. I just want to see a little bit better gas mileage. And yea yea buy a beater I know I have one I'm in the process of getting it back on the road. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted September 15, 2012 Author Share Posted September 15, 2012 Bump Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted September 15, 2012 Share Posted September 15, 2012 I don't see why you would need an eco tune. In cruising ranges, your car would target the same afr's. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted September 15, 2012 Author Share Posted September 15, 2012 The Eco tune doesn't allow the turbo to build any boost. Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted September 15, 2012 Share Posted September 15, 2012 That's impossible. Link to comment Share on other sites More sharing options...
meier motor sports Posted September 15, 2012 Share Posted September 15, 2012 just dont step on the gas as hard. its that simple. no tune required. or just get a vacuum gauge and keep it in as deep of vacuum as you can. thats getting good fuel economy Link to comment Share on other sites More sharing options...
Balrock Posted September 15, 2012 Share Posted September 15, 2012 Shift before 3K and go light on the throttle and stay below 70mph Link to comment Share on other sites More sharing options...
whitelightning Posted September 15, 2012 Share Posted September 15, 2012 I ran it on stage 2 and it sucked. Same MPG and no passing power. Not worth it at all. All it does is kill the boost. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted September 15, 2012 Author Share Posted September 15, 2012 That's impossible. Not impossible. Link to comment Share on other sites More sharing options...
boostedgrocerygetter Posted September 15, 2012 Author Share Posted September 15, 2012 I ran it on stage 2 and it sucked. Same MPG and no passing power. Not worth it at all. All it does is kill the boost. And thanks that's all I needed to know. Link to comment Share on other sites More sharing options...
iNVAR Posted September 15, 2012 Share Posted September 15, 2012 Not impossible. No, it actually is. If you understand how the wastegate system works, you'd understand this to be true. The only way the WG door can open to slow the spooling of the door is when there IS boost. And because the WG actuator is spring loaded, it won't open until you get to about 7 lbs of boost. You could disconnect the WG door from the actuator, thereby letting it just flap around, but even then, the turbo will still experience some spooling. Link to comment Share on other sites More sharing options...
meier motor sports Posted September 16, 2012 Share Posted September 16, 2012 ^^ sounds like the winning move to go with. flapping waste gate doors Link to comment Share on other sites More sharing options...
iNVAR Posted September 28, 2012 Share Posted September 28, 2012 Actually, you can stop the turbo from spooling... keep throttle angle low and there is not enough exhaust gas being generated to spool the turbo past against its inertial mass other than using the turbine for scavenging Heh, I guess that's true enough. You could mess with the throttle map but then your car would drive even worse than if you just dialed in 0% WGDC all around. You'd essentially be limiting yourself to < 25% throttle opening angle because boost can easily build at 25% throttle in 5th even under 3K RPM. That's not exactly a driveable car. Link to comment Share on other sites More sharing options...
