lanceth101 Posted February 24, 2013 Share Posted February 24, 2013 i have a 2009 subaru legacy 2.5i special editon.. i jus recently bought this air intake http://www.cosmoracing.com/productinfo.asp?cid=150&pid=1950 .. is this intake a bad idea?? i see mixed reviews for CIAS on naturally aspirated subarus... it is not installed yet.. any opinions?? Link to comment Share on other sites More sharing options...
ehjhey Posted February 25, 2013 Share Posted February 25, 2013 Now you won't hear ME say this is a bad idea, but what's probably going to happen is that people will tell you that the stock intake is your best option. I'm actually curious if it will actually net a 7 HP gain..... If you DO end up installing it, I'd be curious to find out Link to comment Share on other sites More sharing options...
bomberlegacy Posted February 25, 2013 Share Posted February 25, 2013 Won't help. Our intakes are cold air intakes anyway, and the panel filter flows fine. Changes in airflow needs a tune for optimization. Even then you won't notice it. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
lanceth101 Posted February 25, 2013 Author Share Posted February 25, 2013 Now you won't hear ME say this is a bad idea, but what's probably going to happen is that people will tell you that the stock intake is your best option. I'm actually curious if it will actually net a 7 HP gain..... If you DO end up installing it, I'd be curious to find out ill let you know.. seems like a good quality product... its hard to believe that stock intake would draw in colder air then a pipe located outside of the engine bay but im a newbie when it comes to this anyway... Link to comment Share on other sites More sharing options...
bomberlegacy Posted February 25, 2013 Share Posted February 25, 2013 The stock intake also draws air in from outside the engine bay. It pulls from right above the radiator. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
lanceth101 Posted February 25, 2013 Author Share Posted February 25, 2013 The stock intake also draws air in from outside the engine bay. It pulls from right above the radiator. i see what u mean.. i took a look at my car and it does seem to pull air right from the grill from the outside.. but it seems with the piping it would flow much better... sound right?? idk ill let u guys know im going to keep the stock as well after i remove it. Link to comment Share on other sites More sharing options...
sanchitosonria Posted February 25, 2013 Share Posted February 25, 2013 Pretty sure it was here or naisoc where someone did the dyno and the stock setup with a hi flow panel filter was best. search and I'm sure you can find... I would link but on my phone... Link to comment Share on other sites More sharing options...
pansontw Posted February 25, 2013 Share Posted February 25, 2013 For all the NA intake system mod. Only one I can physically felt is Throttle body spacer. For intake, I suggest you keep the stock torque box (one in front of Throttle body) This will hold your low end torque. And then custom made CAI to connect to torque box. For the cone filter, remember not go too big. Otherwise you will lose low end torque again . This setup is by far the most balanced (keep low end torque and smooth on high speed) Link to comment Share on other sites More sharing options...
