Per-Gear Tuning
SeeeeeYa
While per-gear timing may not be available on LGTs, from what I know, per-gear boost tuning for many LGTs certainly is. My STi, as well as several other model ECUs, have the dormant ability for both per-gear boost as well as per-gear timing. Seems the provisions in the ECU, revealed not all that long ago, are leftovers from capabilities in JDM versions. Figures.
The thread I made on IWSTI has had but two people reply... one is LittleBlueGT. :lol: I don't expect many will undertake this, but this is to let you know it is possible. Apparently, people have yet to envision the possibilities. I can tell you this, without per-gear tuning you are missing out.
To begin per-gear tuning all one needs is an EBCS and the tuning software of choice. I use the Tactrix/Prodrive EBCS and ATR. The tuning, however, is arcane. There is virtually no direct information anywhere, with only hints here and there if you search.
I accidentally came across per-gear looking for a solution to a common, potentially destructive, result of a Stage2 tune... inadequate boost control at the uppermost limits, where the stretched OEM ability becomes inadequate. Many Subarus die on racetracks due to precisely this. Initially I bought an EBCS and a MBC, to implement "hybrid boost tuning" on my car, which would have been a solution. Along the way I was made aware there was a better solution, one where I could have safety in any gear and at any speed, PLUS more power and superior everyday performance to boot.
A short time later I had per-gear tuning, and a car with a difference in feel like it did going from stock to a good tune, only it already had a good tune. Something this rewarding to drive, that protects my valued Suby no matter the weather or driving extreme, should not remain a secret.
RomRaider has had a number of per-gear threads, and definitions that revealed pertinent tables. Some tuners have boasted about it, then kept understandably quiet. It has been incrementally revealed and has been promised in future tuning software revisions. Some esoteric tuning softwares have long embodied the ability. Per-Gear Tuning is coming, yet, at this time, there is no access for the bulk of the Community. Time to change that.
Here's that IWSTI thread I made:
http://www.iwsti.com/forums/ecu-tuning-performance-electronics/254298-power-safety-driveability-per-gear-boost-per-gear-timing.html
Here are informative threads:
http://www.airboytuning.com/archives/130
http://forums.nasioc.com/forums/showthread.php?t=2189089
Thanks, rtbrjason, for all your help and guidance.
I'll have to look into this when I have more time. The hybrid boost might work for rolling dynos but it'll overboost/boost spike in higher gears if you are shifting fast. Mine will hit 22-23psi going from 3rd to 4th(in Mexico of course); its supposed to only hit 20.5psi.
Seems like a reasonable idea. Load changes with respect to gear ratio, so it's logical that you tune for the load conditions each gear will ultimately result in. You can do a LOT with per-gear tuning, including developing a REAL snow mode (low boost and pulled timing with high throttle sensitivity in low gears, and low throttle sensitivity and higher boost and more aggressive timing in higher gears).
Big power, street-tire STi's could even benefit by mitigation of wheelspin off the line without sacrificing dynamic response or closing the throttle.
Question: How does the ECU determine gear?
[URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard
I had to find it again...
http://www.iwsti.com/forums/3258960-post6.html
You certainly get it, even adding to the list of potentials I've read about.
I've been running per-gear boost control on my WRX for a few years now, since Eric Minehart pioneered the definition of those tables. Everything you need to know is here: http://www.romraider.com/forum/viewtopic.php?f=25&t=7048
The ECU calculates gear position from engine rpm and vehicle speed via a 2D table of thresholds.
Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs.
Ding ding :)
So that causes some problems then. Gear changes would have to be interpreted quickly (especially for drag racers), and changes made accordingly. You'd have to give some thought to the gear transition (which wouldn't be as easy as having step-function changes). Things like FFS and LC would interfere.
You also can't compensate for clutch slip. Ideally, you'd know that clutch slip occurs and would drive responsibly. But the ECU wouldn't know that you are launching, or slipping the clutch intentionally in the dirt or snow. You'd have to account for that, and there's some different ways to do that (i.e. default to wastegate or low boost when gear position is undefined).
But you could also use that to your advantage, by retarding timing when road speed is greater than zero, and there is no matching ratio (i.e. during shifting). That, along with target wastegate boost, you could effectively build FFS into the ECU without having to rely on either clutch switch.
With a standalone, you could build a controller so the ECU would be able to predict the next gear change based on current gear and the lower clutch position switch (i.e. clutch starts coming out, feedback RPM:speed to determine if the next gear is above or below the current gear, and select that boost and timing map).
Yep, two years ago he showed the way and made per gear boost tuning possible.
In 2008 Airboy discovered the timing compensations, that has made per gear timing possible. Here: http://www.romraider.com/forum/viewtopic.php?f=25&t=3985
While I've often been outspoken in defense of the AP, versus OS, it is obvious that in doing so I've cultured a personal ignorance. Were it not for OS the abilities I post here may never have happened.
Now, isn't it time everyone, AP or OS, were made aware of their car's untapped potentials?
The gear determination thresholds are quite wide, so they allow for some degree of clutch slip or wheelspin, and they can be edited.
I will say the tables in the emineheart RR thread above are significantly different from what I have to work with in ATR. It would be nice to edit tables like that, but I have to do extra manipulations to get the per gear torque breakout I need.
Can someone look with OS to see if those tables are still the same in a 2011 STi? If they're the same then "someone" at Cobb made the job for ATR folk not only more difficult, but have less resolution as well. I have to wonder why they would do that... if they did.
I've been kicking myself for selling my Tactrix cable. I only did so because Cobb had it locked out. Then, shortly after I sold it, they made it possible to use it. :( It is time for a new one if those tables are as detailed in OS now for my STi as for the 08 WRX in the RR thread.
It may be up to a skilled OS user like fahr-side to take this thread where people can actually use it. It's been a fairly complicated job of tuning for me to get where I am. That has been complicated by adding in per gear timing, which made a huge difference but means log/tune/log/etc multiple timing tables. Per gear boost, which most can implement, was made more complicated for me because I added an EBCS at the same time, and tuned multiple boost tables in sub-freezing temps. I bet those with an EBCS already would be ahead of the game to start.
If that's the case, can you add columns to the table?
If so, you could build conditional boost/timing maps that would tailor those parameters based on what you are doing. Launching and shifting, namely.
No, it's a 2D table. Additional logic would need to be added to accomplish what you're suggesting.
A mate has already implemented LC/FFS on his standalone (works off the clutch switch as usual) but is working on an auto-blip function now. The trick to making that work is to monitor throttle pedal angle and the brake switch.
Gas pedal 100% and clutch down, ECU logic can determine you want LC or FFS based on vehicle speed. Throttle 0%, brake switch on and clutch down, you get a blip to rev match based on a table of rpm deltas between gears.
There are guys who could probably write a patch like this for the stock ECU but the place for that conversation in on Romraider ;)
Sadly, from my limited OS experience and resources it doesn't appear there are complete definitions for the 11 STi. With official releases stopped years ago the only ones added have been individually provided. The one I've used in RR to look at the 11 STi isn't part of the official definitions, and does not include all the tables necessary to implement per gear.
So, unless I'm wrong which is very possible, it looks like for some OS is the tool to use and for others ATR is.
However, the point of this thread isn't a how-to for implementing Per Gear Tuning, but more to bring awareness that the option exists and has proven, undeniable benefits. Those who have the desire to pursue such tuning will find a way. Obviously, one way is to get a pro to craft the tune... with one here, fahr_side, who already has years of experience at it. I'm sure there are others, but not all.
I've been so preoccupied getting my own tune off the ground and safe that my knowledge of who can and who cannot do what is poor. Some only have the possibility for per gear boost... perhaps the most important of the two because it provides for more power and more safety than any other option I'm aware of. Some have the option of both per gear boost and per gear timing... the later providing driving and performance enhancements.
In my opinion, anyone who values their motor and has gone past Stg1 should find a way to per gear boost tuning, at the least. Far too many of these engines fail just because of one high speed run. The records show that track days kill unprepared engines. Many people who believed, just because their tune was "safe" and worked fine day after day in normal use, was also safe at a track or a few high speed rolls in "Mexico" have lost motors.
Proper boost control that eliminates spikes in higher gears can be done other ways effectively. But, per gear provides not only that, it provides for even greater performance in the lower gears as well. No other method does that, to the best of my knowledge. With per gear you can truly have your cake and eat it too.
Subscribed, and reading all linked threads you provided. Would love to get per gear boost control working on my car. Getting kind of annoyed by what seems to be a fairly wide gap between 3rd and 4th required WGDC and ability to achieve my targets... I ended up tweaking things more onto the safe end, while sacrificing 3rd gear and consequently every gear below that as well. :(
The smart guys looked long and hard for this logic in the Legacy ECU but didn't find it.
For the earlier ones that's true AFAIK, too. But the person who got me off the ground has an 09 SpecB, and while he can't do p g timing he's had p g boost for some time. So there's hope for some Legacy owners at least.
Or, do as Scooby2.5 did, and have it all. :)
Hi all,
As some of you may know, I used to do reversing and table definitions for OS and was hired at Cobb years ago where I continue to do Subaru development to this day. The following is just my own personal opinion and should not be construed as a message or opinion from Cobb Tuning.
As far as whether Cobb or OS is on the cutting edge as far as new table development, keep in mind that a lot of the new table development in OS as of late has been cases of someone going through our Accesstuner software after we release new tables and then finding and defining the tables for OS. The table development for OS is discussed in this sub-forum at RomRaider:
http://www.romraider.com/forum/viewforum.php?f=25
Just looking at the first page only, the following tables or table groups were those that we added to the Accesstuner software and released and then someone specifically looked in our software and then found the same tables in the ROM (and only those tables) to define for some OS ECUs:
Deceleration Fueling / Overrun RPM cutoff threshold tables
AF#3 (Rear O2 sensor) correction limits
Rear O2 sensor closed loop fueling target limits
Idle Stability / Airflow Tables
Knock Sum Per Cylinder
AF learning A-D minimum and maximum threshholds
Fuel Pump Duty High and Medium Tables
Knock Sensor Calibration thresholds and noise filter
Misfire DTC and MAP thresholds
Cruise/Non_Cruise Map Switching Tables Parameters and Logic
Injector Scaling at low pulse width / non linear scale.
Those that do this aren't hacking our software, but they are getting the idea that certain logic and tables exists from looking at our software and then (presumably) using the table values seen in the software to locate the tables in the ROM and then define for OS (with the identical or nearly identical table name). Not every one with OS is doing this - there are some new table/logic discoveries for OS that don't have anything to do with our software. And those that are doing it do mention (occasionally) that these are tables that we have in our software. Not a big deal to us - imitation is the sincerest form of flattery after all, but important to note where the bulk of the discoveries are first made if you are considering tuning with one software or the other. Also keep in mind that if we uncover new logic, we add the tables for every ECU we support where that logic is applicable. Typically with OS, someone may find the tables for their ECU and a couple of others, but not define them for every ECU that it applies to (you may have to do this on your own or request that the person or someone else finds it for you).
As far as the per gear request torque tables - they were first seen in our tuning software in the massive Accesstuner software update back in Feb. 2011:
http://legacygt.com/forums/showthread.php/cobb-tuning-releases-major-update-subaru-accesstuner-race-155196.html
In this case, the discovery that something was up with a gear-based requested torque was first uncovered by someone logging an 08 WRX with RomRaider and noticing that req. torque was limited in 2nd gear (IIRC) and posting this at the RomRaider forums. This was when I was with OS - I found the logic but never got a chance to add the tables to the OS definitions as I was hired on at Cobb. However, I did work out the logic completely and add them to the Cobb Accesstuner software for the update released in Feb. 2011. OS later found the tables (in the thread that was mentioned started in March 2011). That wasn't a case of someone looking at our software to get the idea, but we were first to bring the tables to the tuning market with our software.
We have the per gear requested torque tables in our software for every ECU we support where these tables are applicable: 08-13 STi, 08-13 WRX, 10-12 LGT, 09-13 FXT, 09-10 2.5GT
Keep in mind that some ECUs (such as the STi) have a smaller 2 row table vs. the larger (more useful) 6 row per gear table (common on non-STis that support the table). Unfortunately, this is how they are set up from the factory for the STis and doesn't have anything to do with any changes that we've made. We are simply exposing the factory tables as is and they happen to be smaller for the STi than the other models.
Bill
Thanks Bill, the OS community is forever in your debt. I forgot for a moment these tables are indeed present in the '10~ LGT ECU. I don't tend to use them on stock-turbo cars.
As to the ATR vs. OS thing... competition is good for the tuning community as a whole, and that's all I care about. If Cobb would service the non-US market I might be more sympathetic. Currently for the rest of the world it's a choice between OS or Ecutek, who lock your ECU forever.
Thanks for being here. Your input is always illuminating.
Interesting, but perhaps over my head and confusing to me.:) I use a different approach that is more obvious and direct. That may or may not be because I use ATR instead of OS, but all will be better served by any input on this subject. The more the merrier.
I will be posting screenshots today to illustrate my ATR method.
While I can provide details for my STi I can only show what one member has done to enable per gear boost on his 09 SpecB.
The first pic shows changes that enabled his per gear to work after he had created columns in WGDC and Boost Targets. So this is first. There are three such tables to change.
The next step is assigning column headers for WGDC and Boost. The second pic is combined.
Then it is tuning. Boost control is tuned with an EBCS.
Between this and throttlehappy's input, whose OS knowledge vastly exceeds mine, one should be able to enable tuning for per gear boost in applicable vehicles.
Anyone with better details please comment.
Unsubscribed. I hate you all with per gear tuning. :p
Honestly, it only really becomes useful on bigger turbos when the difference in boost threshold between gears is much larger.
Feel better now? ;)
