iaacek Posted January 3, 2017 Share Posted January 3, 2017 I am in the process of changing the clutch on my 2008 2.5i Legacy Wagon - the TOB started to squeak at ~200kkm. I ordered the Exedy clutch kit KSB04 and also new flywheel EXEDY FWSBL02FF and it arrived in mail today. I checked the flywheel, it's flat but the surface is not smooth: it's circle ground. Check the pictures, is it ok to put it on? It doesn't feel rough but it's not as smooth as the outside of the flywheel... Link to comment Share on other sites More sharing options...
Max Capacity Posted January 3, 2017 Share Posted January 3, 2017 That's called, Fly Cut. My buddies machine shop also Fly Cut brake rotors so they give a better bite. It's fine. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
iaacek Posted January 3, 2017 Author Share Posted January 3, 2017 Awesome, thank you, that's what I needed to hear =) Link to comment Share on other sites More sharing options...
FJuan Posted January 3, 2017 Share Posted January 3, 2017 Yup, I'm with Max, perfectly fine. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
compsurge Posted January 4, 2017 Share Posted January 4, 2017 It's not fly cut, but this was from how it was machined at the factory (either a lathe or a vertical turning center). It is not a problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 5, 2017 Share Posted January 5, 2017 You don't want a friction surface to be smooth, the surface has to grip the clutch disc. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
