Deer Killer Posted November 21, 2011 Share Posted November 21, 2011 Strap against pitch stop arm takes place of Subaru special tool to keep the engine aligned. Floor jack works just fine using the center of gravity of the transmission. There's a tab under the case so it can't slide off the pad either. Came out and went in smooth as butter. I see everyone complains about this part. Tried to get engine/transmission balanced before pulling it out, and I measured the alignment when the transmission was going back in but 2-3" out and corrected it via the jack and the ratcheting strap attached to the pitch stop arm until it was parallel. Of course you have to be careful. Don't ham fist it and blame me when you drop the tranny Link to comment Share on other sites More sharing options...
Swansack Posted November 21, 2011 Share Posted November 21, 2011 Wow, that's impressive. I replaced my clutch last weekend with a lift, tranny jack and a extra set of hands and I still ran into every problem possible. Props. I have an addiction Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 Good Job, I notice you have the same crappy floor jack I bought years ago. I have had it rebuilt once but a year or so later it started leaking again. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Deer Killer Posted November 21, 2011 Author Share Posted November 21, 2011 Good Job, I notice you have the same crappy floor jack I bought years ago. I have had it rebuilt once but a year or so later it started leaking again. Oh yeah, it leaks.. so much for craftsman, that's actually a warranty replacement on the old one too. Link to comment Share on other sites More sharing options...
Deer Killer Posted November 21, 2011 Author Share Posted November 21, 2011 Good Job, I notice you have the same crappy floor jack I bought years ago. I have had it rebuilt once but a year or so later it started leaking again. BTW is there a rebuild kit?? I could do with less hydraulic fluid on my garage floor. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 21, 2011 Share Posted November 21, 2011 I have 5 other floor jacks that I can use, I just bought one (blue and silver) from Harbor Fright. I have the old black Sears steel jack that I bought in 2003 that still works great and is my first choice to use. I bought a silver one from HF in early 2010 that works well too. I also have the HF tranny jack. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 21, 2011 Share Posted November 21, 2011 Ive used a LOT of rachet straps for a lot of things but thats just balls. Thanks for posting pics. Link to comment Share on other sites More sharing options...
Luka Posted March 25, 2016 Share Posted March 25, 2016 Anyone have any clue where the other end of the strap is attached to in the third picture? Is the purpose to tilt the engine down towards the transmission, when you're trying to connect them back together? Link to comment Share on other sites More sharing options...
apexi Posted March 26, 2016 Share Posted March 26, 2016 I've never removed a transmission before, but if you are trying to tilt the engine down luka, you can try some of the things he mentions in the video below. At about 16:05, he mentions putting a block of wood, foam, etc. between the front of the engine and the radiator. He also mentions a jack with a block of wood under the crank pulley too. Link to comment Share on other sites More sharing options...
WahooNo2 Posted April 13, 2016 Share Posted April 13, 2016 when i did mine, i removed the pitch stop and hooked a ratchet tie down where the pitch stop was on the firewall and a lift point on the engine, it holds the engine tilted rearwards while the transmission is out. i got a harborfrieght trans jack for the job. you can do the job with one person but if you have a friend that can hand you tools and maybe help with certain alignment tasks like holding the crank while you tighten flywheel bolts it makes the job easier. also you need to get the car very high in the air to be able to clear the car attached pic is putting it back in. Link to comment Share on other sites More sharing options...
