radioflyer2006 Posted January 12, 2012 Share Posted January 12, 2012 I'm sure we have all made mistakes, but hey, we all learn from them, right? Up until last year, I had never changed the oil in anything besides a go-kart. In the photo below I was changing the oil... tell me what is wrong with what I had actually "changed". (I've since learned from this mistake and I don't even get a drop of oil on the ground.) http://i20.photobucket.com/albums/b241/RadioFlyer1998/Subaru/IMG_0179.jpg Hint: Where is that drain pan located? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted January 12, 2012 Share Posted January 12, 2012 Id be way more interested to see a photo of the look on your face when you popped the oil filter off Link to comment Share on other sites More sharing options...
el5y Posted January 12, 2012 Share Posted January 12, 2012 Not on my lgt but on my old 240 I changed the oil but didn't tighten down the new filter completely. Talk about bathing in expensive mobil 1 oil... Link to comment Share on other sites More sharing options...
TRSCobra Posted January 12, 2012 Share Posted January 12, 2012 ^^^ I did that on my old jeep cherokee several years ago, only I forgot to put the drain plug back and I lost 6 quarts of castrol syntec. What a mess! On my LGT, I messed up the chrome rings around the projectors when I blacked the headlights out. I ended up painting over everything in black. Link to comment Share on other sites More sharing options...
2.5GT_dude Posted January 12, 2012 Share Posted January 12, 2012 Installed new brakes and rotors on the Legacy one night....forgot to install the rear pads. I don't know how or why, exhaustion? Link to comment Share on other sites More sharing options...
FiberglassCustoms Posted January 12, 2012 Share Posted January 12, 2012 Over tightening the ACVS Banjo Bolt & snapping it off after waiting 2+ Months to get My Vehicle Running Again-Thank You Mike @ Infamous! Running Non Synthetic-Sure came out like Water Buying the Legacy that I did-Auto Not doing More Research on the "Turbo Issue." Link to comment Share on other sites More sharing options...
DRoc7822 Posted January 12, 2012 Share Posted January 12, 2012 When I went to install the exhaust...I had tried to put the midpipe on every single way except the right way. Didnt realize it till the next day. Either that... or I ordered an Afta Maf from Mike... and somehow AVO sent me the Throttle hose instead. I spent the next 1/2 hours trying to fit the throttle hose onto either the intake or the inlet. Only to come and realize it was the wrong part. Link to comment Share on other sites More sharing options...
jcraw84 Posted January 12, 2012 Share Posted January 12, 2012 When I pulled my downpipe out I was having trouble pulling it out from underneath. I pulled on it for about 30 mins before it finally came out. Only to have broke a seal and push the "half moon" seal (don't know the real name) that is near the heads into the engine causing an oil bath. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 12, 2012 Share Posted January 12, 2012 forgot to plug in the MAF after installing the intake not completely heated up the headlight before trying to crack it open Link to comment Share on other sites More sharing options...
radioflyer2006 Posted January 12, 2012 Author Share Posted January 12, 2012 Id be way more interested to see a photo of the look on your face when you popped the oil filter off If you think that would have been good, then you would have loved to see my face when I suddenly realized that I hadn't emptied my oil at all. What I had done was empty out the entirety of my transmission fluid... Link to comment Share on other sites More sharing options...
Grrupt Posted January 12, 2012 Share Posted January 12, 2012 forgot to plug in the MAF after installing the intake not completely heated up the headlight before trying to crack it open Lol I just did that last week. Forgot to plug back in my MAF. Link to comment Share on other sites More sharing options...
chutrain Posted January 12, 2012 Share Posted January 12, 2012 On another car, but was working on the rear brakes and trying to get the rotor off, but it wouldn't budge at. Turns out I left the hand brake up. Link to comment Share on other sites More sharing options...
soloz2 Posted January 12, 2012 Share Posted January 12, 2012 I purchased a used starter here as mine was giving the dreaded squeal on cold mornings as it wasn't releasing from the flywheel as it should. I took the starter apart, cleaned and greased it up then installed. Car started up and I drove home. (was at a friends as I don't have a garage) I didn't go anywhere the next day, but at about 8:30pm I went into my office and stepped on something... It was the spring that goes on the plunger... Was a simple fix, but I fixed it out in the cold in the dark. Thankfully, I replaced the two philips screws with bolts so I could remove the selinoid without removing the starter! Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
CL21376 Posted January 12, 2012 Share Posted January 12, 2012 Replacing the water pump on my f-body and I failed to drain the coolant. Got a nice antifreeze shower when I disconnected the coolant line. Link to comment Share on other sites More sharing options...
ShadowImg Posted January 12, 2012 Share Posted January 12, 2012 Mine was the first time I tried to change oil using a lift. I failed to realize that when you are laying down and removing an oil filter your arm is at a very different angle. When standing up, you get a nasty lesson in fluid dynamics when you pop the filter off. Link to comment Share on other sites More sharing options...
Code Posted January 12, 2012 Share Posted January 12, 2012 On my old Taurus SHO. I changed the front brakes and drop it off the jack-stands. I started my test-drive in reverse but never pumped the brakes to re-establish pressure. So I rolled backwards, put the brake pedal all the way into the firewall with no result and BAM! smacked into my dads 1984 f250. Broke my tail light. Pops thought it was hilarious. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
frank_ster Posted January 12, 2012 Share Posted January 12, 2012 this happend next town over customer took his car backed out of the garage rolled right onto the street and got hit by a semi going 50 mph Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Turkeylord Posted January 12, 2012 Share Posted January 12, 2012 Ouch! On my old 2000 LGT I had a remote starter. One night I must've left it in reverse after I backed into my old condo's garage. Started it the next morning and it backed right into my workbench and pushed the back wall of the garage off the foundation. I tried in vain to fix it myself but eventually had to go fess up to the building manager. On my Altima before that, I lifted the hood too high and the back corners hit and cracked the windshield. Not much so far on my wagon, probably the most embarassing things so far are that I missed a couple things on my pre-purchase inspection - Invidia UP and aftermarket grill... Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 12, 2012 Share Posted January 12, 2012 Put the clutch disc in backwards. In my defense Spec labeled it backwards. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted January 12, 2012 Moderators Share Posted January 12, 2012 Putting a short shifter in my last legacy...I set the basket bushing that sits at the bottom of the lever on the ground and eventually stepped on it like an idiot. Car ended up sitting while I waited for the dealership to order a part, find out it was the wrong part, and then order the right part and get it sent to me over the next two weeks. All because I stepped on a little tiny $5 plastic part. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
alegend90 Posted January 12, 2012 Share Posted January 12, 2012 first time ever doing front brake pads...looking back, i was entirely too noobish to do the job based on my troubleshooting techniques. I was doing the fronts, and found a walkthrough on this site. i did the drivers side with no problems one night after i got home from work, and finished it with no issues (besides trying to slide up the rusty caliper). The pistons were easily able to be drawn in on the drivers side...I got up at the crack of dawn to do the passenger side before heading into work. getting to the pads on this side was a breeze, and literallty took a third of the time because i was familiar from doing the other side the day before. the pistons on this side would not press in no matter what. so being the noob i am, i thought maybe pumping the brakes would help get it back in...instead, it forced the pistons way too far out due to the pressure, and when i tried pushing them in again, i got a brake fluid facial. not a good way to start the day. luckily a shop down the road was able to tow me and replace it and i was only out of a ride for the day. i did get a relaxing day off work though! Link to comment Share on other sites More sharing options...
01rs25 Posted January 12, 2012 Share Posted January 12, 2012 Put the clutch disc in backwards. In my defense Spec labeled it backwards. Wasn't my legacy nor my RS but rather a friends car. Completed a realitivley demanding swap. WRX motor, transmission into an RS completely by ourselves. Wiring and everything. Car starts up on the first try, when we went to back it out of the garage nothing. We look over to the work bench to see the brand new Act clutch still in the box. Completely forgot to install the clutch. We still laugh about this. Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted January 12, 2012 Share Posted January 12, 2012 Nothing you can do but just laugh about that! Link to comment Share on other sites More sharing options...
spec.B Dream Posted January 12, 2012 Share Posted January 12, 2012 Too many to list, but I'll try any way Filling the oil after forgetting to re-install the drain plugBacking out of the garage, hitting the side breaking the passenger side mirrorInstalling FMIC without getting a clamp tight and having a friend come over at 10:30 PM to help diagnose why the car was running like crapShortly after buying the Legacy attempting to refill the washer reservoir but getting the coolant one insteadSwapping the turbo without draining the coolant/clamping the linesGetting sprayed with fuel while finding out that you cannot use the factory fuel rails and bypass the factory fuel pressure regulator I'm sure there's many more Link to comment Share on other sites More sharing options...
gcoonley Posted January 12, 2012 Share Posted January 12, 2012 Putting sway bars on my 74 Vette. I tried to do everything perfectly. I misread the instructions and tightened the bolts down for Foot Lbs. The instructions were in inch Lbs. I kept thinking the bolts were defective when they would just snap off. Link to comment Share on other sites More sharing options...
