SneakyFast Posted November 8, 2008 Share Posted November 8, 2008 Last night when I was driving home I had both of my headlights go out on me. Thankfully I was on a well lit offramp and very close to home. When I got it home I checked the fuses and everything seemed to be fine. I have an Apexcone HID retro (with battery harness) that has been installed for about 6 months now with no issues. The DRLs have been disabled. Neither the fuse on the battery harness or the 20 amp "lighting" fuse in the under hood fuse box were blown. The high beams, fogs, parking lamps and turn signals all work. I'm pretty confident that I wired the HIDs correctly as they worked with no issues for months. What else should I check? I'm hoping I don't have to rip out my HIDs and go back to replacing light bulbs every 6 months... Help... Link to comment Share on other sites More sharing options...
SneakyFast Posted November 8, 2008 Author Share Posted November 8, 2008 I went through and double check all of my connections. Everything is good and still no lights. Anybody have any ideas before I pull out the HID kit? Link to comment Share on other sites More sharing options...
CRAZY KEN Posted November 8, 2008 Share Posted November 8, 2008 ...dont check your fuses by just eyeing it use a fuse checker...second unplug your ballast from oem connection and power the kit straight from the battery. The passenger side should be easier for you to do this test, especially if you have a CAI! If the HID powers up: its not you ballast, igniter or bulb! It could be a number of things: fuse, relay, short, switch, ect. If it doesnt turn on: it could be you ballast, igniter or bulb! Hope this helps, CRAZY KEN Link to comment Share on other sites More sharing options...
SneakyFast Posted November 8, 2008 Author Share Posted November 8, 2008 I don't have a fuse checker but I have replaced both fuses with new ones. I thought the battery harness gave the kit power straight from the battery. Am I wrong? Link to comment Share on other sites More sharing options...
CRAZY KEN Posted November 8, 2008 Share Posted November 8, 2008 ...I want you to go direct...so it will bypass the oem wiring, fuses, relays and what nots. It will basically tell you if the problem is your hid kit or your oem wiring! CRAZY KEN Let me know what you find out! Link to comment Share on other sites More sharing options...
SneakyFast Posted November 9, 2008 Author Share Posted November 9, 2008 I got tired of tinkering with it and just pulled the HID kit and put stock bulbs back in. It works now thankfully. I'm glad I got the lifetime warranty. Thanks for your help Ken. Link to comment Share on other sites More sharing options...
CRAZY KEN Posted November 9, 2008 Share Posted November 9, 2008 ...both hid assembly are bad...ouch...I have them on my car now! WORRYING!!! CRAZY KEN Link to comment Share on other sites More sharing options...
SneakyFast Posted November 11, 2008 Author Share Posted November 11, 2008 ...both hid assembly are bad...ouch...I have them on my car now! WORRYING!!! CRAZY KEN Yeah, it was a little crazy. I'm not sure I'm going to reinstall another kit. I'm just lucky the lights went out on a well lit offramp and not the dark mountain highway I commute 5 days a week. Link to comment Share on other sites More sharing options...
