Hmm, perhaps I will hold off on the steering rack bushings until I need another alignment. I saw your other posts in
this thread, and I've got two questions:
1) How long have you had the setup, and have you checked the endlinks recently to make sure the poly bushings haven't cracked or separated from the endlink? I had read about some people having this problem.
2) From your pictures, it looks like there are two washers supplied with each endlink. It seems you have both washers on the trailing arm connection, one on either side of the endlink. If you had one on the arm/link side and one on the bar/link side, would that make the endlinks vertical? I can do a quick paint sketch if necessary.
Lovin' the rhymnocerous avatar btw...
