Elliottlj Posted May 15, 2008 Share Posted May 15, 2008 somebody explain to me the function of a grounding kit.. and is it worth the money Link to comment Share on other sites More sharing options...
Hugo L. Posted May 15, 2008 Share Posted May 15, 2008 I'm no expert, and I'm a n00b here, but a grounding kit's purpose is to centralize all grounding points to a single one in an attempt to «clean up» the electrical flow in the car. It's supposed to give a cleaner electrical input to spark plug wires, therefore a truer, better spark, in turn delivering better ignition. fact or fiction? Some claim as much as 6 rwhp on 350Z. Cars with an electrical throttle body (as opposed to the classic, cable-operated one) report better throttl response by grounding that single component. I had started installing one in my Z3 back in the day, but nevr got around to running the wire from the rear mounted battery to my front mounted grounding point, so... Link to comment Share on other sites More sharing options...
robinlsb Posted May 15, 2008 Share Posted May 15, 2008 Waste of money "Belief does not make truth. Evidence makes truth. And belief does not make evidence." Link to comment Share on other sites More sharing options...
danthemantran Posted May 15, 2008 Share Posted May 15, 2008 expensive engine dress up Link to comment Share on other sites More sharing options...
EquinnoxX Posted May 15, 2008 Share Posted May 15, 2008 expensive engine dress up +1. Don't pay for it if you don't have to. Link to comment Share on other sites More sharing options...
Elliottlj Posted May 16, 2008 Author Share Posted May 16, 2008 lol thats what i thought Link to comment Share on other sites More sharing options...
CapnJack Posted May 17, 2008 Share Posted May 17, 2008 Before I had my Legacy, I owned a 2001 Integra GSR. I made a grounding kit myself using 4 ga wire and installed it on my GSR. I noticed about a 2MPG increase in fuel mileage, the head lights were much brighter and the engine turned over much faster when starting. Before I sold the car, I pulled all the grounding wires out for my next car. I installed the ground wires on my Legacy and noticed NO difference at all over the stock grounding system. Link to comment Share on other sites More sharing options...
Ferenczy33 Posted May 17, 2008 Share Posted May 17, 2008 Before I had my Legacy, I owned a 2001 Integra GSR. I made a grounding kit myself using 4 ga wire and installed it on my GSR. I noticed about a 2MPG increase in fuel mileage, the head lights were much brighter and the engine turned over much faster when starting. Before I sold the car, I pulled all the grounding wires out for my next car. I installed the ground wires on my Legacy and noticed NO difference at all over the stock grounding system. Similar story here. Used grounding wires on previous vehicles, last one being a Hyundai Elantra GT (I know , but it was actually a great little car) that had a small but annoying dip in the powerband. I did the same and made my own grounding kit using 4 ga wire. It cured the hesitation, and did give me a few extra mpgs. Overall it completely smoothed out the motor. The whole premise is to give the motor a cleaner and stronger ground which seemed to work especially well when the grounds were placed around the distributor or coil packs. One thing I learned about the LGT though, everything I used to know about tips and tricks to mod an N/A motor went totally out the window. For example, first thing I thought about getting for my LGT without doing any research was a cold air intake. Boy was I wrong. I think the ground wires are the same in this instance. Something that may have worked on other vehicles, doesn't appear to have any use for the LGT. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 17, 2008 Share Posted May 17, 2008 It cost $30, I made one for my 2005 Impreza RS. It helped keep the headlights from dimming at least, and I felt like it smoothed idle & revving just a little.. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
Prime Power Posted May 17, 2008 Share Posted May 17, 2008 My car before this was a hyundai elantra gt also. The hatchback. It got totalled either wise I would still be driving it. Good car. Link to comment Share on other sites More sharing options...
