custom exhaust project
ArcTec34
so I figured i'd start my own thread to update as i make more progress
I started out with a spare set of LGT mufflers. I knew i wanted more noise, and nicer looking tips.
Cut the cans open, removed most of everything (kept inlet pipe and middle baffle wall)
http://inlinethumb34.webshots.com/39905/2079694670090682233S600x600Q85.jpg
Provided a definite rumble, but above about 3500 rpms there was no difference between stock. I've been in a "hog-zawsted" car before, and the idle rumble wasnt quite that loud but in the ballpark. so i decided why not just make it better at all RPMS. i have some perforated stainless tubing on its way, and ill weld it in so it looks something like this.. so ALMOST muffler delete but not quite. should be good
http://inlinethumb31.webshots.com/18334/2410457210090682233S600x600Q85.jpg
next, have wanted to have dual tips. SO i thought about custom fabbing.. made these on solidworks
http://inlinethumb54.webshots.com/39861/2025273340090682233S600x600Q85.jpg
3 inch OD piping. needless to say, I was just about to buy the piping when i found an almost perfect match on the internet. They're staggered too! so they're on their way.. ill post more when everything put together!
http://inlinethumb01.webshots.com/41024/2024888840090682233S600x600Q85.jpg
  • Replies 118
  • Created
  • Last Reply
0 dollars for ripping stockers up and running perf tubing through them.. saved myself a boatload for not just buying perrin cans or something.. and ill get a nicer look =)
90 dollars for both sides.. thats fine with me
So it looks like you want to keep the stock cans run a straight though design and a new tip correct?
I was thinking about doing this as well but retaining the stock tips. But i would love to bypass the stupid baffles in the muffler...holy crap are they restrictive looks like the exhaust has to run through a machine gun barrel haha.
ha. yeah. im hoping that the straight through design with perf tubing will give me exactly what im looking for. and i just got the tips.. theyre beautiful and a perfect fit.. ill try to take a pic of them with the car even though i wont be able to weld them on until next week..
subscribe.
I've been looking for tips too. came across this link. they look great, but price is high:
http://www.techtonicstuning.com/showpart.asp?partnum=254.285
and here's their whole line:
http://www.techtonicstuning.com/images/interface/smalltt.gif Exhaust Tips
254.175 Stainless Oval Ex. Tip (4 in. X 2 in.) $50.00
254.180 Stainless Oval Ex. Tip (5.5 in. X 2 in.) $50.00
254.210 Stainless Tip Single Rolled Edge 3.5 in. X 6 in. X 2.25 in. $40.00
254.211 Stainless Tip Single Rolled Edge 3 in. X 6 in. X 2.25 in. $40.00
254.215 Dual 2.5 inch Outlets Stainless DTM Tip for 2.25 exhaust $140.00
254.220 Single Oval DTM-Polished Stainless (7in. long, 2.25in. inlet, 3in. X 4in.) $90.00
254.250 JRE Flaired Tip (3 in. X 2.25 in. X 6 in. Black Powder Coated) $45.00
254.260 Chrome Tip Single Oval Angle 4 in. X 10 in. X 2.25 in. $25.00
254.270 Chrome Tip Dual 9 in. long 2.25 in. inlet 2.375 ea outlets $35.00
254.275 Stainless Oval Ex. Tip (4 in. X 2.25 in.) $50.00
254.275C Stainless Oval Exhaust Tip (4in x 2.25in) Clamp-on $70.00
254.280 Stainless Oval Ex. Tip (5.5 in. X 2.25 in.) $50.00
254.280C Stainless Oval Exhaust Tip (5.5in x 2.25in) Clamp-on $70.00
254.285 Stainless Dual Angle Tip $110.00
254.285V Stainless 2.25 in. Dual Angle Tip with venturis $140.00
254.290 3in Stainless Dual Angle Cut Double Wall Exhaust tip for 2.25in exhaust $110.00
254.310 Stainless Steel Tip (single 3.5 in. x 6 in. long inlet 2.5 in.) $40.00
254.311 Stainless Steel Tip (single 3.5 in. x 4 in. long inlet 2.5 in.) $40.00
254.315 Dual 2.5 inch Outlets Stainless DTM Tip for 2.5 exhaust $140.00
254.320 Single Oval DTM - Polished Stainless (7in. long, 2.5in. inlet, 3in. X 4in. outlet) $90.00
254.330 JRE Flaired Tip (3.5 in. X 2.5 in. X 6 in. Black Powder Coated) $45.00
254.375 Stainless Oval Ex. Tip (4 in. X 2.5 in.) $50.00
254.375C Stainless Oval Exhaust Tip (4in x 2.5in) Clamp-on $70.00
254.380 Stainless Oval Ex. Tip (5.5 in. X 2.5 in.) $50.00
254.380C Stainless Oval Exhaust Tip (5.5in x 2.5in) Clamp-on $70.00
254.385 Stainless Dual Angle Tip $110.00
254.385V Stainless 2.5 in. Dual Angle Tip with venturis $140.00
254.390 3in Stainless Dual Angle Cut Double Wall Exhaust tip for 2.5in exhaust $110.00
This site hosted, designed and maintained by Merlyyn Web Services
yeah i spent about a hundred.. mine have double walled tips so i think that looks a bit nicer.. and theyre a bit bigger.. same idea though. i just didnt want to spend a lot of $$ on cans.. 100 on tips was reasonable as all my other perf. piping was really not any cost
  • 3 weeks later...
