Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Basic Operation & Maintenance
Reload this Page Front Wheel Bearing -- DIY Walkthrough
Page 1 of 14 1 2311 > Last »
Thread Tools
04-25-2008, 05:35 PM
 derffred
derffred's Avatar
Title: Woohoo
Car: 07 Yamaha R6, 05 LGT, & '10 MB E350
Send a private message to derffred Find all posts by derffred
Diagnosis:
So, last week while driving to work I heard a humming type noise from the front of my car from 40MPH and got louder as the speed increased. Being a Technician, I immediately assumed it was a wheel bearing and decided after work to put my car on the lift, have a co-worker drive my car to 50 MPH and I put a stethoscope on each steering knuckle near the axle on each wheel and confirmed the Right Front was faulty.
Cost:
I picked up a front wheel bearing (complete hub assembly) from Subaru with a new Axle Nut for about $140 after tax.
Replacement (took me about 20 minutes with a lift and air tools):
Raise the vehicle, remove your front wheel (5- 19MM nuts), take a screwdriver and softly pry between your brake pad and your rotor to compress your brake caliper to the point of where it can easily slide off. Remove your brake caliper (2- 14MM bolts), remove your caliper bracket (2- 17MM bolts) and remove your rotor. You can use two M8 bolts in your OEM rotors to "press" your rusty rotor off the hub. Once your rotor is off, look behind and you'll see a sensor going through the spindle near the axle, that's your wheel speed sensor and you should remove it so you don't damage it when replacing the wheel bearing (1- 10MM bolt). Once your wheel speed sensor is off, remove your axle nut (1- 32MM nut) and push the axle in just so it isn't "seized" in your hub. Once that's loose, look behind the wheel where your axle slides in the hub and you'll see 4- 14MM bolts in a tapered square pattern; those bolts hold your hub on the steering knuckle (remove them). Once they're removed, chances are you'll notice it should come off, but it doesn't. I took a small ball peen hammer and smacked the back of the hub until I was able to wiggle it off. Once it's off, you'll have to swap over your backing plate (sits between the hub and the spindle) Clean all the rust and dirt inside where the bearing race sits, use a silicon lubricant to coat the surface and evenly tighten the hub bolts. Reinstall everything, triple check your work, and don't forget to pump your brakes before you start driving!
Click image for larger version
ID:	51977   Click image for larger version
ID:	51978   Click image for larger version
ID:	51980   Click image for larger version
ID:	51981   Click image for larger version
The Following 2 Users Say Thank You to derffred For This Useful Post:
capitan4eto (03-28-2012), pfrancz (03-14-2013)
derffred
Find More Posts by derffred
04-26-2008, 01:05 AM
 underpowerd
underpowerd's Avatar
Title: HEET Miser
Car: 05 OBP LGT 5EAT UL +PE1818F/20 +HFS-6
Send a private message to underpowerd Find all posts by underpowerd
good write/contrib, dealer invoice for this is criminal.
underpowerd
Find More Posts by underpowerd
04-26-2008, 07:06 AM
 derffred
derffred's Avatar
Title: Woohoo
Thanks, I should've taken pictures of the actual install, but I forgot to bring my camera to work
derffred
04-29-2008, 09:43 AM
 welby
welby's Avatar
Car: '05 sedan, 5spd, Stg.1
Send a private message to welby Find all posts by welby
Good write-up, thanks. I had a '97 Jetta that ate front bearings like crazy. That car was a PITA to change. You basically had to rip the entire spindle off and press them in/out. So the Suby's are basically a bolt on deal, no pressing involved, huh? That's good to know.
I'd assume that the rears are basically the same procedure?
I'm getting a loud humming at around 60-70 that definitely doesn't seem like it'd be the tires. I'm gonna jack it up and check for play in the next few days. I bought the car two months ago with 30,600 miles on it, and have about 32,800 right now. The bearings should be covered under the warranty, right?
One more question, do I need to call Subaru to get the warranty transferred to me, or is it basically automatic?
Thanks
welby
Find More Posts by welby
04-29-2008, 05:00 PM
 derffred
derffred's Avatar
Title: Woohoo
Thanks
Yea, the procedure on your Jetta is the same as a Mercedes-Benz, doing those a few times a month, it's cake . I don't know if the rear wheel bearings are the same as the front but I'll assume it is. As far as your noise, I would rotate the tires first to see if the noise moves to the front.
Hub bearings (Wheel bearing with an axle going through it) normally don't contain "play" when they're faulty.. You're thinking of a standard wheel bearing found on front and rear wheel drive cars (on the axle that isn't being driven) which are adjustable with the nut on the spindle.
derffred
05-01-2008, 01:44 PM
 welby
welby's Avatar
I checked them yesterday, and like you said, there was no play anywhere. The one's on my Jetta definitely had play in them when they got bad. Thanks for the info. I will say that I don't think it's normal that my LGT is hummin almost as loud as the '00 Jeep TJ I had on 36" Super Swampers .
Gonna call the dealer next week sometime
welby
05-20-2008, 04:34 PM
 Underdog
Underdog's Avatar
Title: Wrench for Hire
Car: The Crimson Dynamo
Send a private message to Underdog Find all posts by Underdog
I need to pull the rear hubs this weekend in order to replace the trailing arms. What's the best way to remove the axle nut lock? Last time I had it in the air I tried prying back the dent/lock on the nut and it wasn't going anywhere.
My best guess was take off the wheel centercap with the car still on the ground (parking brake set) and use a breaker bar & cheater pipe to break the nut loose, then lift the car, remove the wheel, and fully remove the nut.
10% Off DeatschWerks and Injector Dynamics!
Underdog
Find More Posts by Underdog
05-20-2008, 04:39 PM
 derffred
derffred's Avatar
Title: Woohoo
Yea, if you don't have access to an impact gun, the breaker bar is pretty much the only way to go
derffred
05-20-2008, 04:44 PM
 Underdog
Underdog's Avatar
I do have a corded Milwaukee Impact (300ftlb), but no 32mm 1/2" drive impact socket. :*(
Underdog
05-20-2008, 04:47 PM
 derffred
derffred's Avatar
Title: Woohoo
I'd lend you mine if you're in the area.. North Jersey..
If not, you can pick one up for a few bucks at any tool or parts store. You're going to need one regardless.
derffred
05-20-2008, 04:48 PM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao
I suspect that the axle nut will laugh at any electric impact.
Nice write-up
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
05-20-2008, 04:52 PM
 derffred
derffred's Avatar
Title: Woohoo
Thanks.
It should be fine, his main problem is that he doesn't have a socket lol.
derffred
05-20-2008, 04:56 PM
 rao
that will definately make it hard. Most auto parts places have those csockets pretty cheap.
I have seen those things go both ways - wither they spin off with your hand or you need a huge breaker bar or real impact.
Rob
rao
05-20-2008, 05:24 PM
 Underdog
Underdog's Avatar
Yeah, I have a 1 1/4" (31.75mm) socket which fits fine, but is not impact rated. Since the electric impact would most likely not work anyway (couldn't budge the lower rear shock bolt), I will try to use the 1-1/4 with the breaker bar. I would normally be hesitant to use the english equivalent rather than the proper metric socket, but in this case it should be okay since it is slightly smaller than 32mm.
Now my only fear is snapping the breaker bar, it is a cheapie craftsman POS.
Underdog
05-22-2008, 09:00 AM
 Underdog
Underdog's Avatar
Went to Sears yesterday and replaced the 18" 1/2"-drive breaker bar (the pivot pin kept falling out) and picked up a 32mm socket and 6" extension. Hopefully combined with a cheater pipe, that should do the trick.
I was ready to drop some coin on a 18" 3/4"-drive breaker bar and socket, but they weren't in stock. I will continue to shop around until Sunday... then it's on!
Underdog
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATTN: New Members! Look here first. BDII New Member Introductions 60 04-29-2013 12:13 PM
Tear Down Manual for 2005 Legacy GT NoblePrawn Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 194 10-25-2010 10:47 AM
body roll TJF37 Suspension/Brakes 12 04-05-2009 08:43 PM
2005 USDM Legacy & Outback Info (Including Official Pric Tide Fourth Generation Legacy (2005 - 2009) 141 11-26-2007 02:22 PM
Wheel Super Sales !!! ( 5 Zigen, WORK, VOLK, GramLight) RavSpec Vendor Classifieds 63 08-09-2006 03:13 PM
