Reload this Page Post Spark Plug Change: Car will die occasionally when depressing clutch for a stop
#1: 04-14-2013, 03:45 PM
 fly_navy
fly_navy's Avatar
Car: 06 spec.B #64
Send a private message to fly_navy Find all posts by fly_navy Reply With Quote
I recently changed my plugs with stock replacement iridiums and everything seems peachy. I torqued them to the proper spec, coil packs seated properly, etc and the car starts and runs fine. There are no codes, misfires, or any lack of power (if anything it pulls harder). After an ECU reset however when coming to a stop and depressing the clutch pedal the car will literally drop rev's and die, no previous symptoms and it will start back up and drive away fine. Its happened a few times now after I had to pull the battery or reset via AP. The car is running an old protune from 2007 and has a list of mods. Is the car simply readjusting fuel trims or did I screw up my plug install? Any insight would be much appreciated.
fly_navy
Find More Posts by fly_navy
#2: 04-14-2013, 03:59 PM
 Hemingway
Hemingway's Avatar
Title: For Whom the Bell Tolls
Car: 98 Legacy Wagon
Send a private message to Hemingway Find all posts by Hemingway Reply With Quote
All the vacuum lines plugged in? Any loose or cracked?
Hemingway
Find More Posts by Hemingway
#3: 04-14-2013, 05:12 PM
 urfsin
urfsin's Avatar
Title: 2x Rally X Champ
Car: Grocery Getter
Send a private message to urfsin Find all posts by urfsin Reply With Quote
Same thing happened to me after changing the clutch (My battery was out of the car for awhile) The ECU just needs to "re-learn" how to idle. Give it a few start / stop cycles and you should be fine.
Slide It Sideways
The Following User Says Thank You to urfsin For This Useful Post:
06silvarubiLGT (04-15-2013)
urfsin
Find More Posts by urfsin
#4: 04-14-2013, 06:40 PM
 fly_navy
fly_navy's Avatar
Car: 06 spec.B #64
All the hoses and lines have good connections and are in great shape. Take some datalogs and maybe have someone take a look?
fly_navy
#5: 04-14-2013, 07:12 PM
 Mr. Sinister
Car: 08 Spec. B/Supra 91T
Send a private message to Mr. Sinister Find all posts by Mr. Sinister Reply With Quote
How long have you driven it since the reset? As mentioned, it does take a while to settle in.
Mr. Sinister
Find More Posts by Mr. Sinister
#6: 04-15-2013, 07:35 AM
 cmpequeno
Car: red 05 legacy gt wagon/red 02 imprezaobs
Send a private message to cmpequeno Find all posts by cmpequeno Reply With Quote
PCV valve? Neutral Safety Switch?
I read that pcv valve sometimes causes rough idle and stalls the car.
On my 02 obs when I was coming to a stop and press the clutch pedal the car would shut down, it was the neutral safety swicth.
On my wife's 03 outback we were told it was the idle air control valve but we just cleaned the plugs and the valve and it's ok for now.
cmpequeno
Find More Posts by cmpequeno
#7: 04-15-2013, 08:50 AM
 rob-2
rob-2's Avatar
Car: 05 GT Limited 5EAT Stage 2
Send a private message to rob-2 Find all posts by rob-2 Reply With Quote
Are you sure you got the right plugs?
rob-2
Find More Posts by rob-2
#8: 04-15-2013, 09:05 AM
 06silvarubiLGT
06silvarubiLGT's Avatar
Send a private message to 06silvarubiLGT Find all posts by 06silvarubiLGT Reply With Quote
Id put money on ecu needing to re-learn idle and such, especially if plugs were right and there are no loose connections
06silvarubiLGT
Find More Posts by 06silvarubiLGT
#9: 04-15-2013, 03:21 PM
 StoplightAssassin
StoplightAssassin's Avatar
Title: Get some oppo
Car: 2012 Hammerhead-i Eagle Thrust
Send a private message to StoplightAssassin Find all posts by StoplightAssassin Reply With Quote
Did it once to me when I switched plugs too. Also hit fuel cut once.
If it keeps doing it, you'll have to pull the plugs and check the gaps.
South Jersey Region SCCA AutoX: http://legacygt.com/forums/showthread.php?t=120907
'10, '11 ESP Champ!
'12 2nd Place STX
Final Overall Pax: 3rd '11, 4th '12
StoplightAssassin
Find More Posts by StoplightAssassin
#10: 04-15-2013, 07:57 PM
 fly_navy
fly_navy's Avatar
Car: 06 spec.B #64
Pretty sure. I'm running the NGK-ILFR6B, exact ones I pulled out of the car.
I've only been driving it briefly for the past few days. I'll have to report back once more time elapses. It just seems strange because before I changed the plugs if I reset the ECU I never had this problem. Why does the idle take a while to settle in? Shouldn't the reset put the vehicle back to the flashed map parameters where idle should have been fine during the original tune?
fly_navy
#11: 04-15-2013, 08:38 PM
 Hemingway
Hemingway's Avatar
FYI. Out of curiosity, I went to NGK's home page and looked up your car. It listed OE Laser Iridium, SILFR6A, 7913, 0.030, as the OE replacement.
Don't know if there is a significant difference between yours and the 6A's listed by NGK. *shrugs*
Hemingway
#12: 04-16-2013, 06:21 AM
 StoplightAssassin
Those are not the OEM plugs
These are:
'10, '11 ESP Champ!
'12 2nd Place STX
StoplightAssassin
#13: 04-16-2013, 07:22 AM
 fly_navy
fly_navy's Avatar
Car: 06 spec.B #64
Looks like you are correct. I actually pulled out SILFR6A's. The manual reports the ILFR6B as the replacements but clearly the stock plugs are the 6A. The plugs seem nearly identical. I'll swap them out if the problem continues *sigh*
fly_navy
#14: 04-16-2013, 07:29 AM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Did you check the gap on the plugs you installed?
BarManBean
Find More Posts by BarManBean
#15: 04-19-2013, 08:46 AM
 fly_navy
fly_navy's Avatar
Car: 06 spec.B #64
I believe you all were right, the car just had to "relearn" how to idle thanks for the help! I haven't had any problems for the last two days. Out of curiosity, would a stock vehicle have to relearn how to idle if it were reset or do the mods have a direct impact?
fly_navy
