Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Basic Operation & Maintenance
Reload this Page How To: Dis-Able Seatbelt Chime SERIOUSLY.
Search Forums
Search via Google
Go to Page...
Closed Thread
Page 1 of 9 1 23 > Last »
#1: 12-23-2004, 10:07 AM
 NonovUrbizniz
NonovUrbizniz's Avatar
Car: Intercooled 05 2.5i
Send a private message to NonovUrbizniz Find all posts by NonovUrbizniz
Ok... I read through the other thread like 30 times repeatedly tried what it said...
1. turn key to acc on
2. plug in seat belt (all the way till it clicks)/unplug seatbelt 20 times Rapidly
3. turn off key
4. Repeat 1-3
5. Start car...
By "plug in seat belt" I mean all the way so the light goes out and it clicks...
By "unplug seat belt" I mean push the release button and let the belt anchor pop out of the reciever.
Well, I noticed (after repeated tries the way it says) that the seat belt light went out after the initial bells/blinks after doing the sequence JUST ONCE...
Well... I spent some time playing with it last night and WITHOUT A DOUBT on my 05 Legacy 2.5i Wagon that if you do the full sequence 2 times like suggested it deactivates the bells the first time and reactivates them the second...
SO JUST FOR CLARIFICATION...
ON MY CAR WITH NO DOUBT WHAT SO EVER.
To dis-able the Seatbelt Chime...
1. turn key on to acc position (do not start car).
2. buckle and un-buckle the seatbelt 20 times (or more (could be less I didn't bother trying lower numbers... I will though.))
3. turn the key to the off position.
4. start the car...
You do NOT need to wait for the initial chimes to finish for ANY of the steps.
ALSO
KEEP IN MIND that this COMPLETELY ELIMINATES BOTH THE CHIME/BELL AND the CLUSTER REMINDER LIGHT.
After the initial bells/chimes and blinks of the reminder light, the light goes OUT and the bells do not chime again...
As far as the cold temperature reset... I don't know about that... it hasn't been that cold here since I disabled it.
NonovUrbizniz
Find More Posts by NonovUrbizniz
#2: 12-23-2004, 10:16 AM
 Kevskate99
Car: 05 LGT
Send a private message to Kevskate99 Find all posts by Kevskate99
Umm, yeah, we know you only do it once. Other wise you just re activate it.
Kevskate99
Find More Posts by Kevskate99
#3: 12-23-2004, 10:28 AM
 NonovUrbizniz
Originally Posted by mhelouin
I've got an 05 GT 5MT and the dealer can reprogram the chime--they did on mine, anyway.
Basically, the way it works--turn the car on. once the beeping starts, insert and take out the seat belt buckle 20 times quickly (like in 30 seconds). turn car off. repeat process.
I know it sounds odd, but it works. All i get now when i start the car without the seatbelt plugged in is 4 or 5 chimes.
Byers Subaru in Columbus Ohio (by the airport) is my dealership and they can explain it to you if I screwed it up.
But it works.
Best of luck.
--Marc
Originally Posted by Throttlejockey
1) Turn key to on position-don't start.
2) After first set of chimes click seat belt in and out 20 times within 30 seconds.
3) Turn off key.
4) Repeat 1, 2, 3 again
5) Turn key off and re-start
And that's off pages 5 and 6...
For people looking to do this this thread GREATLY simplifies finding the answer...
I didn't even realize that it got resolved in that thread.
NonovUrbizniz
#4: 12-23-2004, 10:34 AM
 RoundBoy
RoundBoy's Avatar
Car: 2005 LGT Garnet Red
Send a private message to RoundBoy Find all posts by RoundBoy
it was resolved like a couple pages in.
i remember mentioning the ONCE cycle.
but people still insist on doing it once x eleventy
RoundBoy
Visit RoundBoy's homepage!
Find More Posts by RoundBoy
#5: 12-23-2004, 10:45 AM
 fbi012
fbi012's Avatar
Car: Black 2.5i
Send a private message to fbi012 Find all posts by fbi012
man stop making new posting on same topics, there are like 5 posts already.
When I disabled mine I did it 2ice and it worked, if you cant get it to stop, try doing it once or twice, key in or key out, keep trying till u get it I guess.
fbi012
Visit fbi012's homepage!
Find More Posts by fbi012
#6: 12-23-2004, 11:28 AM
 Legacy05
Legacy05's Avatar
Title: In Zona
Car: Sapphire Black Metallic 335i
Send a private message to Legacy05 Find all posts by Legacy05
Okay ... I get the instructions .. but does it mean to buckle it in all the way ... and unbuckle it all the way .. or do you just put it in part way??? Just curious
Legacy05
Find More Posts by Legacy05
#7: 12-23-2004, 01:17 PM
 fbi012
fbi012's Avatar
Car: Black 2.5i
unbuckle it all the way. But you gota be fast.
fbi012
#8: 12-23-2004, 02:58 PM
*Jedimaster*
Title: Guest
Posts: n/a
I see no reason for this thread- the answer is already posted in the other thread. For those that don't know, stop doing the procedure more than once- the second time cancels the first one. And if you unplug your battery, you'll have to do it again.
*Jedimaster*
#9: 12-23-2004, 03:03 PM
 Drift Monkey
Drift Monkey's Avatar
Title: Banned
Car: Subaru Legacy 2.5GT 5MT
Find all posts by Drift Monkey
IBTL
Drift Monkey
Find More Posts by Drift Monkey
#10: 12-23-2004, 04:18 PM
*Jedimaster*
Title: Guest
Posts: n/a
I had some people get all butt hurt earlier in the week when a thread got locked, so I'll leave this one alone for now.
*Jedimaster*
#11: 12-23-2004, 05:26 PM
 NonovUrbizniz
How about someone just makes the instructions clear so it works for everyone... How about a thread that ISN'T 26 pages long...
just thought this would make is simple for new to find the answer fast instead of reading through 26 pages of posts' most of which don't even make sense or encourage the repeated trying of the incorrect steps.
This way people read the FIRST post in a thread and it simply and clearly gives the instructions.
The reason for the thread was the other one is REALLY confusing and you don't even get to the incorrect instructions till the 5th page much less the correct ones...
And if you go to the last page you have to go back at least 10 pages and the procedure is STILL not clearly outlined...
I made this thread so the directions are clear and correct on ONE page.
I tried the way it's spelled out in the first thread like 15 times before I figured out that it had to be done once... I figured I'd save someone else the headache...
Especially considering the posters in the other thread keep encouraging people to try the SAME thing over and over as if it will produce a different effect in the end.... RIGHHHT.
Originally Posted by brad21
"Repeat process, remove key from ignition again."
Then reinsert the key and start the engine. This is after the second buckle/unbuckle process. Worked for me... maybe I missed some odd thing I did in between? Try rubbing your tummy and patting the top of your head?
Don't give up, the effort is worth the silence.
Originally Posted by Decay
It worked for me, what an awesome thing this forum is, saves me so much headache!
Thanks guys!
Just thought this thread would make the process less of a treasure hunt.
The Following User Says Thank You to NonovUrbizniz For This Useful Post:
Oddnoggins (03-15-2013)
NonovUrbizniz
#12: 12-23-2004, 05:32 PM
 fbi012
fbi012's Avatar
Car: Black 2.5i
ok if thats what you wanted, maybe any admin should make a post that has concluded info only and no one can add comments to it, make it sticky too.
fbi012
#13: 12-23-2004, 06:05 PM
 NonovUrbizniz
Yeah yeah... that's a good idea...
A locked sticky with all the how to's or maybe just a series of locked how-to's with some sort of naming convention so they're easy to search out...
Just for some clarity... that's what always drives me nuts about forums... you have to read like 30 pages of unneccissary info to get what you want.
NonovUrbizniz
#14: 12-23-2004, 06:21 PM
 meier motor sports
meier motor sports's Avatar
Title: nice phone
Car: back in the wagon
Send a private message to meier motor sports Find all posts by meier motor sports
here is an idea. put this in the walk through area. one page explaining the instructions and telling u that doing it a second time undoes what u jsut did and removing the bat also restes it
meier motor sports
Find More Posts by meier motor sports
#15: 12-23-2004, 06:47 PM
 warnoldscu
warnoldscu's Avatar
Title: Contributing V.P.
Car: 05LGTw/PE1820&FMIC
Send a private message to warnoldscu Find all posts by warnoldscu
I know this has been discussed a whole lot, but for some reason I'm starting to think that everyone's car takes a different touch... on my car it definitely took 2 times to turn it off, but other people are claiming that the second try reactivated there, maybe we just need a post that posts different things to try, like "try this... and if that doesn't work, try this.... etc." Just my thoughts...
warnoldscu
Find More Posts by warnoldscu
Closed Thread
Thread Tools
Search this Thread
Similar Threads
Thread Thread Starter Forum Replies Last Post
Passenger Seatbelt Chime and Light.... icehousewvu Warranty Issues & Problems 4 04-06-2009 07:07 AM
Seatbelt Chime Th3Franz Interior/Audio 13 07-02-2008 01:29 PM
Passenger seatbelt chime dstrauss Fourth Generation Legacy (2005 - 2009) 13 04-07-2007 11:21 PM
Malfunctioning Idiot (Seatbelt) Chime sirhecubus42 Warranty Issues & Problems 21 01-21-2007 05:35 AM
Do the people who hate the seatbelt chime not wear their belts? akm3 Interior/Audio 24 02-02-2005 06:31 AM
