Go Back   Subaru Legacy Forums > Technical Forums > Suspension/Brakes
Reload this Page Anyone seen rotors like this?
#1: 10-19-2012, 06:36 PM
 ryspec06
ryspec06's Avatar
Car: 2006 Legacy GT spec. B
Send a private message to ryspec06 Find all posts by ryspec06 Reply With Quote
Anyone know what can make a rotor look like a record player?
I have an hour drive home so you can understand my concern when I started to hear a roar then a vibration in the steering wheel. It got so bad that I could swear that a tire had blown and was coming off the rim. I pulled over to a safe spot but couldn't find anything wrong. Full pressure in the tires and they appeared fine. So I limped it home and immediately put the front end in the air. I checked all the linkage, bushings, and drive shafts and everything is tight. Then I noticed the rotor on the drivers side. It has deep grooves and what looks like hot spots of discoloration. The pads and calipers came off effortlessly so I don't think anything was binding up. These are stock rotors with stoptech pads. I'm not sure where to go from here. Has anyone else had similar issues?
ryspec06
Find More Posts by ryspec06
#2: 10-22-2012, 01:24 PM
 RedLeg97
RedLeg97's Avatar
Car: 97 Legacy GT 5sp Swap
Send a private message to RedLeg97 Find all posts by RedLeg97 Reply With Quote
What do the pads look like?
RedLeg97
Find More Posts by RedLeg97
#3: 10-22-2012, 01:50 PM
 700watts
700watts's Avatar
Title: Contributing V.P.
Car: racer-x is faster + 00 4Runner (dogs)
Send a private message to 700watts Find all posts by 700watts Reply With Quote
that be either no pads and or locked piston
700watts
Find More Posts by 700watts
#4: 10-22-2012, 05:41 PM
 Drew888
Drew888's Avatar
Car: 2008 Spec-B, Infamous Tuned!!!
Send a private message to Drew888 Find all posts by Drew888 Reply With Quote
Looks like really bad glazing to me. I'd find a shop to do a very light resurface if the thickness is good (otherwise replace them) and bed your pads in again (if there is still life on them).
VbGallery
Drew888
Find More Posts by Drew888
#5: 10-22-2012, 07:40 PM
 rps13de
rps13de's Avatar
Car: 05 GRP LGT 5MT STG 2.5
Send a private message to rps13de Find all posts by rps13de Reply With Quote
Yeah, I'd also say a sicky caliper piston. Check the pads too.
rps13de
Find More Posts by rps13de
#6: 10-24-2012, 09:05 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
I would not reuse the pads. With grooving like that, the pads are very likely grooved themselves already and will transfer those grooves back onto a new/resurfaced rotor.
I would just get a new set of rotors and pads and check the caliper pistons prior to going out to rebed everything.
iNVAR
Find More Posts by iNVAR
#7: 10-24-2012, 10:03 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner Reply With Quote
You need a caliper and/or the slides on the adapter bracket are frozen.
GTTuner
Find More Posts by GTTuner
#8: 10-26-2012, 04:35 AM
 ryspec06
ryspec06's Avatar
I figured I would replace both pads and rotors. I don't want to take a chance that I would ruin the rotors with the old pads and this gives me an excuse to tell my wife I need to upgrade the rotors with slotted. The strange thing is that when I pulled the calipers apart they came off so easily. Could a clog in the brake line or a malfunction in the traction controls do this?
ryspec06
#9: 10-26-2012, 04:08 PM
 halwith
Car: 2011 legacy 2.5i premium
Send a private message to halwith Find all posts by halwith Reply With Quote
maybe your wheel bearing took a shit.
halwith
Find More Posts by halwith
#10: 10-26-2012, 04:31 PM
 LegacyDan
LegacyDan's Avatar
Car: Jdm spec 2.0GT VF36 twin scroll
Send a private message to LegacyDan Find all posts by LegacyDan Reply With Quote
I had similar lookinv rotor when one of my pistons seized, except when I pulled over to check the rotor as glowing red! Perfect opportunity to upgrade to a "safer bbk" that's how you sell it to widely!
LegacyDan
Find More Posts by LegacyDan
#11: 10-26-2012, 05:40 PM
 ryspec06
ryspec06's Avatar
I thought of that. I know it's not always easy to tell, but there isn't any play at all. Ill get a chance this weekend to get further into it.
ryspec06
