Reload this Page Does a VF52 'spool' slower than VF40? Take a look
#1: 09-10-2010, 05:14 PM
 dmp
dmp's Avatar
Title: spec.BILF
Car: Mazda or Ford - no more 'bru
Send a private message to dmp Find all posts by dmp Reply With Quote
Looks pretty darn close to me.
Screen capture of my dyno; when their machine prints, it skews the RPM range for some reason.
Standard caveat - this machine reads about/at least 5% lower than most other mustang dyno...and 15% lower than most dynojets.
SOLD | '06 spec.B - VF52/AVO/740cc/Up/Down | 238awhp | 50-80mph 3.1 seconds.
dmp
Find More Posts by dmp
#2: 09-10-2010, 07:42 PM
 Legend
Legend's Avatar
Car: '07 SC Shelby GT 11.58 @121.2 5900' alt
Send a private message to Legend Find all posts by Legend Reply With Quote
You don't have boost curves posted, but assuming that tq follows boost pretty closely it looks like the VF52 is spooling ~150rpm slower than the VF40 from 2k-3krpms. Not an insignificant difference really.. but the VF52 powerband is so much sweeter and that's why a VF52 upgrade has so little downside. Nice.
My '05 LGT
My '07 Supercharged Shelby
Legend
Find More Posts by Legend
#3: 09-11-2010, 09:19 AM
 GTTuner
GTTuner's Avatar
Title: Whut, who me?
Car: It runs 12's
Send a private message to GTTuner Find all posts by GTTuner Reply With Quote
What are your mods? You got 30hp and 25ftlb, looks nice.
GTTuner
Find More Posts by GTTuner
#4: 09-11-2010, 10:42 AM
 praedet
praedet's Avatar
Title: no room for anything good
Car: 05 LGT MT Lim. Wgn Stg. +
Send a private message to praedet Find all posts by praedet Reply With Quote
What gear...
150 in 3rd is 300 or more in 2nd, 4-600 in 1st...
I did lose my mind, but I finally have a mod direction
praedet
Find More Posts by praedet
#5: 09-11-2010, 05:14 PM
 dmp
dmp's Avatar
Title: spec.BILF
that was 3rd. First gear? I can tell no difference. 150rpm is nothing. Even 500rpm is nothing. The 52 is running +5 psi than the 40 was.
Will likely re-tune; tuner played it...VERY safe.
dmp
#6: 09-11-2010, 05:38 PM
 Legend
Legend's Avatar
That is a matter of opinion. At some point as you delay and continue to delay power it becomes intolerable. Everyone has their own tolerance. Yours is apparently way past 500rpms. 500rpms later than a VF40 in 3rd would be too late for me, personally. I'm at around ~400rpms later than a VF40 on my current setup.
Praedet and I each used to have VF52 so we know it's a great turbo, BTW.
My '05 LGT
Legend
#7: 09-11-2010, 05:48 PM
 dmp
dmp's Avatar
Title: spec.BILF
you can honestly tell a 100rpm difference? crazy!
dmp
#8: 09-11-2010, 06:18 PM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
on the road the difference is small, but in a autox event for example in a tight part of the couse where power in the 2000-3000 rpm band is needed, that small difference isnt so small anymore.
whitetiger
Find More Posts by whitetiger
#9: 09-11-2010, 08:20 PM
 LosAngelesLGT
Title: Banned
Car: 05 LGT 5mt 371hp on 91oct & 06 OBXT Stg1
Find all posts by LosAngelesLGT Reply With Quote
that was 3rd. First gear? I can tell no difference. 150rpm is nothing. Even 500rpm is nothing. .
Right and 1000rpm is nothing... 50,000rpm is nothing... one MILLION rpm is nothing.
I disagree! 500rpm is a LOT of difference in lag. It is a TITANIC difference in DD turbo for squirting around short, tight areas. Not really looking to wind my car out (hence no 20g). Indeed, it is apparent that the vf40 is not only spooling faster, it is hitting peak power faster. Is the vf40 making more power at the same rpm? Well no, of course not.
LosAngelesLGT
Find More Posts by LosAngelesLGT
#10: 09-12-2010, 09:16 AM
 rao
Title: Too Big to Fail
Car: 05 Legacy GT/98 BMW 540 w/Chevy Power
Send a private message to rao Find all posts by rao Reply With Quote
I agree with this. Spool, lag and throttle response are irrelevant.
Rob
This DISCLAIMER applies to this post.
IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT
rao
Find More Posts by rao
#11: 09-12-2010, 10:08 AM
 LittleBlueGT
LittleBlueGT's Avatar
Title: RS4 killer
Car: 05 Atlantic Blue non-limited GT MT
Send a private message to LittleBlueGT Find all posts by LittleBlueGT Reply With Quote
That graph looks about right to me.
Try logging a VF40 vs VF52 in 1st gear, the difference grows a bit.
Still a very good upgrade, with not much of a downside, although it DOES spool slower!
Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!!
LittleBlueGT
Find More Posts by LittleBlueGT
#12: 09-14-2010, 07:27 AM
 dmp
dmp's Avatar
Title: spec.BILF
are some of us confusing boost threshold with lag? 100rpm takes about .0001 seconds. (shrug)
dmp
#13: 09-14-2010, 08:30 AM
 LosAngelesLGT
Title: Banned
^You can go from zero to redline in first gear less than a hundredth of a second? My hero!
[/sarcasm]
I understand that you meant it as a matter of perspective but it is meaningless to claim 100rpm takes no time. 10,000rpm does NOT take .01 second. (It takes about 10x as long as 10rpm and about 10 times less long than 1000rpm assuming the same rate of acceleration.)
Even 10rpm takes time and you can bet your ass that IRL and Indy teams work out things like that with telemetry.
Is 100rpm noticeable in typical daily driving or even a dramatic change at the drag-strip? Definately no, however, a guy like WHITETIGER or Kief notice on a short tight course? I'm betting not only would they notice, they might even run some logs wondering why the car feels just a little off.
Im betting LBGT would notice something like that too (as would most of the LOGMAFIA)
EDIT: Op I am not picking on you, if you must know your 52 is spooling faster than my 39
LosAngelesLGT
#14: 09-14-2010, 12:19 PM
 dmp
dmp's Avatar
Title: spec.BILF
(sigh). Aight then.
dmp
#15: 09-15-2010, 08:28 AM
 BLKGT5
BLKGT5's Avatar
Car: BLK 05 LGT OBP 5-SPD VF52
Send a private message to BLKGT5 Find all posts by BLKGT5 Reply With Quote
Could be my tuning, but my VF52 spools up slower than my VF40 did for sure or maybe I'm feeling so much more power flood in than before on/off effect. No logs with me at work, but here's my two cents.
Off the top of my head and butt dyno, here the power band I've noticed.
VF40 3200 - 5300 range
VF52 3800 - 6000 range
BLKGT5
Find More Posts by BLKGT5
Similar Threads
VF40 or VF52 bighaus90 Want to buy 1 09-06-2010 10:35 PM
Wanted: VF40 or VF52 Turbo Hawabenn Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 2 05-03-2010 10:21 PM
Wtb vf40, vf46, vf52 vaccaroja Want to buy 3 09-24-2009 01:52 PM
Replacing Dead VF40 with VF52.. wyllder Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 15 05-15-2009 10:23 AM
Pictures: VF52 next to VF40 collegemt Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 52 04-14-2009 01:39 PM
