Go Back   Subaru Legacy Forums > Walkthroughs > Walkthroughs :: Performance Modifications
Reload this Page New Hog-zawst System!!! The sound of power! *with patented washer technology*
Page 11 of 164 « First < 910 11 12132161111 > Last »
#151: 06-04-2006, 11:06 AM
 hogmeat
hogmeat's Avatar
Title: I'm tardcore!!!
Car: 2001 Ford F150
Send a private message to hogmeat Find all posts by hogmeat Reply With Quote
Originally Posted by fatbastard
OK...just did this mod with some skepticism and wass pleasantly surprised. Nice tone when teh car turns over, but still fairly quite at idle. Get on it and you hear that boxer rumble. For the 30 minutes it took (including run to local hardware store) and the $1 in parts, even if I decide later it drones n the highway I am out nothing really.
hogmeat: you mentioned that most of the air seems to be going through the muffler @ 3k but what about at idle? I did this alone so couldn't check @ 3k but at idle most air was coming out of hte flange. But I guess that makes sense since at higher rpms the velocity is higher and is more likely to travel along in the pipe.
Thanks hogmeat...fun mod
Yes! Another convert! Whooo Whoooo!
Anyways, I think the whole "air velocity" thing is right. There may be more coming out the flanges at idle, as the air doesnt have enough momentum to work it's way through the muffler - but there is still significant flow out the tips.
When your pushing 3x, 5x, 10x (under boost) the amount of air, it has way more pressure, and can make it through the muffler better.
Think of this - there has to be airflow through the mufflers - because it's significantly quieter than if you took the mufflers off altogether!!
hogmeat
Find More Posts by hogmeat
#152: 06-04-2006, 11:09 AM
 hogmeat
hogmeat's Avatar
Car: 2001 Ford F150
All you converts - if you have a digicam - we'd all love to see your own videos! Just take a movie with your camera - compress it with Windows Movie Maker (so easy grandma can figure it out) to a 1.0MB bitrate, and uploadit for FREE on www.putfile.com. Max file size is 25MB.
hogmeat
#153: 06-04-2006, 11:26 AM
 LittleBlueGT
LittleBlueGT's Avatar
Title: RS4 killer
Car: 05 Atlantic Blue non-limited GT MT
Send a private message to LittleBlueGT Find all posts by LittleBlueGT Reply With Quote
Originally Posted by KTM 525
Here you go http://www.autospeedperformance.com/...su-legctbk.htm
I'm not sure about the hangers but for the extra grand i'd skip the hangers but thats just me. IMO there is not an exhuast system on the face of this earth worth 2K. I've always thought this was one of the nicest systems out there for the money.
That TBE exhaust is about $1500.
It comes with a ceramic cat -$100
It has a Bellmouth WG -$150
It bolts up to stock system if required which means 2.5" or less at DP flange
Does not include its own 3 inch donut connection -$75
Does not have flex section in DP -$100
Besids IMO iON quality is unparalleled and their USD price would be about $1875 for the system I want.
If you add up the extras they have vs the Autospeed then it pretty much makes sense.
Not that the Autospeed system is bad, but you get what you pay for.
One big plus for the iON system is it is customizeable.
Big plus for the Autospeed system is it is available now!
I may swap turbos in the future so I want a TBE that really works for whatever I amy do to the car.
LittleBlueGT
Find More Posts by LittleBlueGT
#154: 06-04-2006, 11:37 AM
 Boostjunkie
Boostjunkie's Avatar
Title: Megan Racing and KW Pimp
Car: 05 Legacy GT, 06 Tribeca, 07 Outback
Send a private message to Boostjunkie Find all posts by Boostjunkie Reply With Quote
Originally Posted by LittleBlueGT
$1000 for a TBE?
3 inch divorced waste-gate?
3 inch donut for proper flex but no restriction at the DP flange?
with 3 inch high-flow metalic cat?
with resonator?
dual mufflers
all T304 Tigg welded
DP TIGG welded inside and out?
hangers and flanges T304?
If that is the case I am in!!!!!!!!!!!!!!
FWIW I asked my welder about those specs and he says the raw material alone is worth about $1000, plus you need a welder, etc..........
Prove me wrong, please prove me wrong!
MRSP will likely be around $1000, with a street price a couple hundred lower. Yes to everything on your list except the cat, and the donut gasket. I believe the DP will have a flex section instead of a donut gasket to give it some flex, but allow better fitment with other aftermarket catbacks, if one so chooses. They are still deciding between going with a bellmouth or divorced on the DP, but both designs work equally well. If you want a cat, take all the money you saved and buy any of the metallic substrate cats out there for $150 and have it welded in for $50. Voila, catted TBE for $1000.
Boostjunkie
Find More Posts by Boostjunkie
#155: 06-04-2006, 12:46 PM
 LittleBlueGT
Title: RS4 killer
Is it customizeable?
Divorced WG will give better response in partial boost situations, not necessarily make more power at WOT. The further down the tube goes the better (Hopefully further then Perrin's)
Does it chock down to less then 3 inches at the DP flange?
One other thing I forgot. iONs system had it pipes mandrel bent by one of only a couple of benders that allow much sharper turns then most. What this means is no loss in ground clearance at the Y-pipe. Almost all aftermarket exhuasts lose a little bit of clearance there. To most it might not matter, to me living in Canada it matters for the winter.
If you are right about the price (I think there will be compromises for that price) then that is awesome and will sell very very well!!!!
LittleBlueGT
#156: 06-04-2006, 01:03 PM
 LittleBlueGT
Title: RS4 killer
High flow random tech metalic cat is over $200.
LittleBlueGT
#157: 06-04-2006, 02:20 PM
 mwiener2
mwiener2's Avatar
Title: Level 48 Hunter
Car: Rocketback
Send a private message to mwiener2 Find all posts by mwiener2 Reply With Quote
so i just spent the 68 cents and did the mod. The sound is ok, it's not performance muffler sound, but it also only cost 68 cents.
I've only got two real concerns.
1. That open flange is gonna get water in it and salt in the winter which is gonna tear apart the insides of the muffler.
2. How ever much flow you think is actually going through the muffler, alot isn't. No idea how hot things around that open flange are gonna get, but i hope nothing melts.
My Mods List
(Updated 1/21/10)
I've only snapped 1 axle
mwiener2
Find More Posts by mwiener2
#158: 06-04-2006, 03:20 PM
 relhok
relhok's Avatar
Car: 70 Ghia vert 2110cc, SWP GTltd 5EAT
Send a private message to relhok Find all posts by relhok Reply With Quote
Did it. Bought a pack of 15 washers at Wal Mart. I started with a pair on each bolt. I like the sound. Not bad for 83 cents and ten minutes work.
Now all I need is a Hogmeat Exhaust sticker!
relhok
Find More Posts by relhok
#159: 06-04-2006, 04:29 PM
 Boostjunkie
You really do like to spend too much money, don't cha? With Random you are buying the name. There are a plethora of other metallic substrate cats on the market that are priced much better and are functionally identical.
With regards to the other questions, the debate of whether a divorced DP or bellmouth DP is better is an old one, in which no one has ever really proven any substantive differences. IMHO, in sum they are equivilent.
As to customizing. No. This is a production piece, not a one-off. I've told Megan Racing what I believe the vast majority of LGT owners would want in an exhaust and that's what they are building. With homogeneous production comes lower costs. You can't have your cake and eat it too.
The MR system is 100% 304 stainless and 100% mandrel bent, fully 3" throughout till the y-pipe when it splits to 2.5" pipes. Ground clearance is very good. My car is lowered and I did not scrape the bottom of the car with the stock catback, and I still do not scrape anything with the MR exhaust. BTW, even though I live in Sunny SoCal now, I grew up in Toronto, so I know about winters.
In the end, I think people will buy what they like best. While I think the MR parts are the best value on the market, I can't get on people for buying other more expensive brands because they want to. Some people find value in a $300 pair of jeans, when you can get jeans from a lesser brand for $30. Is one 10x better than the other? No, but if there is something about them that you find worthwhile, then go right ahead. Same goes for car parts.
Boostjunkie
#160: 06-04-2006, 05:00 PM
 hogmeat
hogmeat's Avatar
Car: 2001 Ford F150
1. If your worried about corrosion - how is getting a little bit inside (which will be heated up and evaporated out) any different then getting it on the OUTSIDE? If your point holds true, why don't mufflers die after 2 or 3 years with all that steamy moist exhaust gas? I mean, it used to drip off my grand prix.
2. Doesn't get much hotter than your exhaust tips - because it's so far back and the the flanges aren't even close to anything at all. The tips are 1" from the plastic bumper, and are OK.
As for flow through the mufflers - it's MUCH MUCH quieter than when I had muffler deletes - explain that.
hogmeat
#161: 06-04-2006, 05:07 PM
 JohnG
JohnG's Avatar
Car: 2006 Spec B #237
Send a private message to JohnG Find all posts by JohnG Reply With Quote
Click image for larger version
Name:	Hogmeat Exhaust.jpg
JohnG
Find More Posts by JohnG
#162: 06-04-2006, 06:14 PM
 hogmeat
hogmeat's Avatar
Car: 2001 Ford F150
I LOVE IT!!!
hogmeat
#163: 06-04-2006, 06:47 PM
 mwiener2
mwiener2's Avatar
Car: Rocketback
becasue the outside of the cans are polished and treated and the inside has been exposed to hundreds of hours of sulfluric acid.
usually by the time you park your car the cans are hot enough to evaporate any water that got in them, but if you drive through a puddle and ingest some water then park your car...you got water sitting in the can. Salt also never gets inside the can....unless it's got an opening
My Mods List
(Updated 1/21/10)
mwiener2
#164: 06-04-2006, 06:52 PM
 LittleBlueGT
Title: RS4 killer
Anxiuosly awaiting the release of the MR kit. I just am a bit skeptical, because if it meets all of those requirements at less then a grand I will jump on it. If it is closer to $1400 then I will wait for iON and pay the price diff.
I think the iON is worth $600 more, but I don't think it is worth $1000 more.
LittleBlueGT
#165: 06-05-2006, 10:20 AM
 CasopoliS
CasopoliS's Avatar
Title: Vendor I
Car: Yes.
Send a private message to CasopoliS Find all posts by CasopoliS Reply With Quote
Can you download putfile files? it is taking forever to buffer.
CasopoliS
Visit CasopoliS's homepage!
Find More Posts by CasopoliS
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tear Down Manual for 2005 Legacy GT NoblePrawn Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 193 01-10-2009 05:02 PM
2005 USDM Legacy & Outback Info (Including Official Pric Tide Fourth Generation Legacy (2004 - 2009) 141 11-26-2007 03:22 PM
Subaru 2006 Impreza Press Release gfxdave99 Other cars & Other cars vs. the Legacy 15 07-24-2005 06:28 PM
TECH REFERENCE SUBE555 Naturally Aspirated Powertrains (2.5i, 3.0R) 3 04-18-2004 02:00 AM
TECH REFERENCE SUBE555 Turbo Powertrains (2.0GT, 2.5GT, 2.5XT) 2 04-15-2004 05:56 PM
