Go Back   Subaru Legacy Forums > Technical Forums > Intake and Exhaust
Reload this Page 2006 lgt manual highest rated up pipes!?
#1: 03-26-2013, 08:06 PM
 mike2006legacygt
Send a private message to mike2006legacygt Find all posts by mike2006legacygt Reply With Quote
All- What brands works best with a cobb downpipe? i will be running ap stage 2 with a stock air box. Is this a difficult install? Thanks.
mike2006legacygt
Find More Posts by mike2006legacygt
#2: 03-26-2013, 08:09 PM
 NWSPECB
NWSPECB's Avatar
Title: ------------------------
Car: Spinach Powered Ship
Send a private message to NWSPECB Find all posts by NWSPECB Reply With Quote
Search around. Grimmspeed seem's to be a common one that comes to mind at the moment. Or an STI UP.
NWSPECB
Find More Posts by NWSPECB
#3: 03-26-2013, 08:09 PM
 NWSPECB
NWSPECB's Avatar
Also, welcome to the forum!
NWSPECB
#4: 03-26-2013, 08:12 PM
 Brprs
Brprs's Avatar
Car: UGM 2007 FSXT
Send a private message to Brprs Find all posts by Brprs Reply With Quote
Invidia ftw..sti ups and some others do not have an egt and you will need to have that turned off or you can put a 22k ohm resistor in the plug ins place.
Brprs
Find More Posts by Brprs
#5: 03-26-2013, 08:30 PM
 Brett
Brett's Avatar
Title: Subaru Fanboy
Car: 2011 STI
Send a private message to Brett Find all posts by Brett Reply With Quote
easy. just make sure you buy the gaskets for all the pipes
Brett
Find More Posts by Brett
#6: 03-26-2013, 08:35 PM
 doccrowley
doccrowley's Avatar
Title: Sleeper
Car: 2016 VW Golf R w/stuff, '08 Outback
Send a private message to doccrowley Find all posts by doccrowley Reply With Quote
I like the fitment of my coated Grimmspeed UP w/ flex section better than the STi UP, COBB UP, much better than the generic ebay UP that was a very, very poor copy of the Grimmspeed UP.
The flex section eventually gave up on my first Grimmspeed UP (I purchased used the first time). I went through all the others and went back to a new, coated Grimmspeed UP and am very happy.
All the other UP's leaked or didn't seal properly for me.
Good luck!
doccrowley
Find More Posts by doccrowley
#7: 03-26-2013, 08:45 PM
Is a new uppipe required?
 mike2006legacygt
Guys- this seems like a pain to worry about replacing my up pipe now. Can I run my stock up pipe on my 06 lgt manual with a Cobb dp, running ap stg 2 with a stock air box?
Is an up pipe change required to run this set up? Trying to decide if its worth the extra time, money...but trying to also evaluate my risk running with the stock up pipe as well. Help?! Thanks.
mike2006legacygt
#8: 03-26-2013, 08:57 PM
 doccrowley
doccrowley's Avatar
Title: Sleeper
If your budget allows to purchase the UP, with all the other goodies you listed, do it! Labor to install an UP requires removal of the DP. So you'll save on the install labor if you do both at once.
Turbo will spool faster if you ditch the stock UP, upgrade to go with the other things you listed. Yes you can go without (with one worry that the CAT in the stock UP is a possible issue to fail with age and take out your turbo).
Hope that helps.
doccrowley
#9: 03-28-2013, 10:54 AM
 iNVAR
iNVAR's Avatar
Title: Nerd^2
Car: 05 LGT 5MT Stg2 custom
Send a private message to iNVAR Find all posts by iNVAR Reply With Quote
Replace the UP. You'd be a fool to replace the DP and not do the UP while you're in there.
Get a used STI UP and swap it in. Make sure you have your car tuned, you'll be stage 2 now. Do NOT get on the throttle hard until you tune it! The tune will take care of any CEL that may be thrown due to lack of the EGT sensor.
The Following User Says Thank You to iNVAR For This Useful Post:
Brprs (03-28-2013)
iNVAR
Find More Posts by iNVAR
#10: 03-29-2013, 02:09 AM
 adosdrummer
Car: 06 lgt, 01 mr2 spyder
Send a private message to adosdrummer Find all posts by adosdrummer Reply With Quote
I liked the grimspeed.. came with good gaskets, and a good part. I did have to port it some to match to the perrin header.
adosdrummer
Find More Posts by adosdrummer
#11: 04-01-2013, 09:35 PM
 O.C.D.
Send a private message to O.C.D. Find all posts by O.C.D. Reply With Quote
Grimm doesn't come with gaskets. You have to buy separately.
Add another grim speed UP owner. Best pipe on the market IMO. Get all new gaskets and have at it. My only recommendation is do yourself a favor and loosen your passenger side motor mount and raise the engine enough to clear the stock UP. All the damn heat shields make it a bear to get out.
And for the love of Pete don't pay someone to do it. It is two pipes with some gaskets. Remove 20 bolts and swap away.
O.C.D.
Find More Posts by O.C.D.
#12: 04-02-2013, 11:58 AM
 .:Catalyst:.
.:Catalyst:.'s Avatar
Title: AllWheelsDriven
Car: 2006 spec.B #163 stage.2 .:CryoTuned:.
Send a private message to .:Catalyst:. Find all posts by .:Catalyst:. Reply With Quote
I believe with the UP revision (change in flanges etc.) they actually do come with the gaskets now.
My spec.B [#163] Project Thread with Pictures
Get CryoTuned!
.:Catalyst:.
Find More Posts by .:Catalyst:.
#13: 04-02-2013, 12:01 PM
 .:Catalyst:.
Confirmed my belief from GS website (pricing change reflects this as well - it's $219.99 now)... http://www.grimmspeed.com/catalog/pr...products_id=79
Quick Specs
Gaskets Included - Heavy Duty GrimmSpeed Gaskets
Flex Joint - 321 Stainless Steel "Tuned-Bellow" w/ Interlocking Liner
Tubing - 14 Gauge 304 Stainless Steel Piping w/ Brushed Finish - 33% thicker than most competitors
Pipe to Flange Connection - Cut-Back flange allows much smoother connection. Piping is flush with flange so there is no step into the pipe.
Flanges - 1/2" 304 Stainless Steel CNC Milled - All 3 sides are milled for precise tolerances in manufacturing
Optional ceramic coating
Increased HP by ~10hp
Reduce turbo lag
Get CryoTuned!
.:Catalyst:.
#14: 04-02-2013, 12:13 PM
 DeltaNu1142
DeltaNu1142's Avatar
Title: Subarooster
Car: 2009 QSM LGT VF52 STi 6MT
Send a private message to DeltaNu1142 Find all posts by DeltaNu1142 Reply With Quote
I have the OEM UP on my '09. It's rated a 7.
Originally Posted by RooTBeeR View Post
Tits mcgee
The Following User Says Thank You to DeltaNu1142 For This Useful Post:
korpsepatrol (04-03-2013)
DeltaNu1142
Find More Posts by DeltaNu1142
#15: 04-03-2013, 01:07 PM
 O.C.D.
Game set and match - oh well. I guess I can only report on the first gen UP I have where I did have to buy the gaskets, lol.
O.C.D.
