Go Back   Subaru Legacy Forums > Model Specific Forums > First Generation Legacy (1989 - 1993)
Reload this Page Battery Draining Rapidly - Any Insight?
#1: 04-05-2013, 02:10 PM
 JoeStrummer
Car: '92 Legacy Wagon
Send a private message to JoeStrummer Find all posts by JoeStrummer Reply With Quote
My '92wagon with 160K miles is acting up again....the battery (replaced on 10/2012) is draining within 30 miles of driving.
I replaced the alternator in 12/2012 so I need to pull it and get it tested...but assuming it's OK, is there something else I should check?
Thanks for your input...I'm mechanical but admittedly, crappy at diagnosing electrical bugs.
JoeStrummer
Find More Posts by JoeStrummer
#2: 04-05-2013, 06:52 PM
 monkeyposeur
monkeyposeur's Avatar
Car: 93 SS, 03 WRX 205/22T
Send a private message to monkeyposeur Find all posts by monkeyposeur Reply With Quote
Maybe you got a bad alternator or battery. Ive heard of a few people getting a crappy alternator that didn't last. I'd also check your ground lines and clean your terminals. It only helps to add a few more ground lines and it helps the car run smoother believe it or not. That's all that I can think of.
monkeyposeur
Find More Posts by monkeyposeur
#3: 04-06-2013, 02:02 AM
 USLiberty
USLiberty's Avatar
Car: 93 L sedan w/SS swap(Jdm20g,ems)
Send a private message to USLiberty Find all posts by USLiberty Reply With Quote
Yeah I got 2 bad alternators in a row out of autozone, first one died quickly, second one didnt die but only charged at 12.2 volts. The duralast alternators are made in eithec china or mexico. In mexico they can't solder, in china they use cheap bearings.luckily they have warranty
USLiberty
Find More Posts by USLiberty
#4: 04-06-2013, 05:07 PM
 GEORGEROV
Car: Legacy Outback
Send a private message to GEORGEROV Find all posts by GEORGEROV Reply With Quote
Measure the voltage reading across the battery terminals with the engine running . Should be about 13.5 volts . If that is correct then the alternator is charging ok . Problem might be a current drain from battery when engine switched off . Disconnect positive lead from battery and connect ammeter between disconnected positive lead and +ve battery terminal . Current draw should be no larger than say 50 mAmps . If you are drawing in the Amps range then go to fusebox and disconnect each fuse in turn until you find which circuit is causing the drain .
GEORGEROV
Find More Posts by GEORGEROV
#5: 04-06-2013, 06:44 PM
 mnstrmech
mnstrmech's Avatar
Car: 1993 legacy wagon
Send a private message to mnstrmech Find all posts by mnstrmech Reply With Quote
measuring voltage at terminal ends while the vehicle running is only half checking the alternator..... one of the diodes could be bad and it may be putting out low amps...... thats why when i test an alternator i ALWAYS put the amp lead on the main wire coming from the alternator....
mnstrmech
Find More Posts by mnstrmech
#6: 04-06-2013, 07:00 PM
 JoeStrummer
Thanks for the direction and good advice. I suspected that the cheapo auto zone alternator may well be the culprit, but I'll definitely try the suggested tests as well.
This will be good practice to start developing my knowledge of electrical systems.
Again, thanks for taking the time to reply to my question.
JoeStrummer
#7: 04-06-2013, 09:05 PM
 USLiberty
USLiberty's Avatar
A good alternator will read 14.2- 14.4v while running no matter where u check it on the positive wire or battery, anything less and its suspect. As far as amperage output you could run the lights and heater and your 14.4 volts should keep up close (within a volt). Those bad alternators go bad fast when heavy amperage is used. a good charged battery will be about 12.8v not running.
USLiberty
