Reload this Page Rear fender well rust repair
#1: 04-15-2013, 07:17 PM
 gergeek
gergeek's Avatar
Car: Legacy GT 98
Send a private message to gergeek Find all posts by gergeek Reply With Quote
Well today i decided to grind done the rust and the metal was rotted all the way through.
So fair i completely replaced a door to avoid the rust.....and the repair.
But now i cant really replace this.....I plan on using fiberglass to fill the hole after using rust be gone (or something like that).\
Any suggestions on a fix that doesn't require welding? What have you guys tried?
gergeek
Find More Posts by gergeek
#2: 04-15-2013, 08:22 PM
 Sludgeroo
Sludgeroo's Avatar
Car: 1999 Lesbian Moving Van
Send a private message to Sludgeroo Find all posts by Sludgeroo Reply With Quote
I mean as far as stopping rust, you have to cut it out. Otherwise, no edge primers/rust converters/rust neutralizers will stop it... it will always come back.
But if you are crafty and daring if you cut out the rust and use duraglass and fibreglass mat/mesh you could remake the part.
It may be more work than its worth.
Bondo holds water, that's why it is considered a body filler, to smooth out contours, rather than fixing rusty holes.
Sludgeroo
Find More Posts by Sludgeroo
#3: 04-15-2013, 08:24 PM
 Zues Marine
Zues Marine's Avatar
Title: This Guy..
Car: 98 SF5, 95 BK6, 91 VW Fox
Send a private message to Zues Marine Find all posts by Zues Marine Reply With Quote
what? youre taking this opportunity to go widebody? good idea bro!
Zues Marine
Find More Posts by Zues Marine
#4: 04-15-2013, 08:25 PM
 Sludgeroo
Sludgeroo's Avatar
Hella flush or GTFO lol.
But really, welding (despite cost) is the only way to go.
Sludgeroo
#5: 04-16-2013, 07:01 AM
 burnfirewalls
Car: Booger, the 1999 Subaru Legacy Outback
Send a private message to burnfirewalls Find all posts by burnfirewalls Reply With Quote
If it's on the rear fender, be sure that it hasn't allow rust/corrosion to spread further up into the strut tower. I'm not sure how similar the rear fenders are between my wagon and the sedans, but for what it's worth: http://legacygt.com/forums/showthrea...is-205615.html
From what I've discovered, rear fender rust is cosmetic til it ain't. Good luck, and here's hoping it's just superficial!
The Following User Says Thank You to burnfirewalls For This Useful Post:
gergeek (04-16-2013)
burnfirewalls
Find More Posts by burnfirewalls
#6: 04-16-2013, 06:47 PM
 gergeek
gergeek's Avatar
Car: Legacy GT 98
well luckily my neighbor used to repair cars so he is going to teach me and help me out. thanks
gergeek
#7: 04-17-2013, 01:54 AM
 spooln30
Car: 99 Legacy 2.5GT Toyota Supra 2jz/R154
Send a private message to spooln30 Find all posts by spooln30 Reply With Quote
This may sound weird but it works great. If you grind out the metal and there's nothing behind it to lay the bondo over you can use that expanding spray foam in a can they sell at Home Depot. Just spray in the hole and let it expand and dry then grind it down below the actual surface about a 1/16" then lay the bondo over. I've done this in the past for a quick fix and it works good but in the end it will come back. GL.
spooln30
Find More Posts by spooln30
