Reload this Page downpipe and exhaust Q?
#1: 03-11-2013, 08:23 PM
 adosdrummer
Car: 06 lgt, 01 mr2 spyder
Send a private message to adosdrummer Find all posts by adosdrummer Reply With Quote
I installed my perrin header and downpipe, as was going to install my downpipe at the same time.
The previous owner welded a piece of pipe between the stock downpipe and the rest of the exhaust and deleted the flanges between. My welder is broke, and In my frustration I forgot to look. Is there another flange before the mufflers I can just remove that section and drive to a muffler shop with the aftermarket DP installed?
adosdrummer
Find More Posts by adosdrummer
#2: 03-12-2013, 03:06 PM
 Max Capacity
Max Capacity's Avatar
Yes you can drive the car with a open DP
The flanges are turbo to DP, DP to Mid Pipe, Mid Pipe to Y pipe, Y pipe to mufflers. If I remember right.
adosdrummer (03-12-2013)
Max Capacity
#3: 03-12-2013, 03:25 PM
 sigmafour
sigmafour's Avatar
Title: Delta Machine
Car: BSM05
Send a private message to sigmafour Find all posts by sigmafour Reply With Quote
no cat? Don't boost it too hard. big flame, underside of car on fire. LOL should be a fun ride.
sigmafour
Find More Posts by sigmafour
#4: 03-12-2013, 03:56 PM
 adosdrummer
Thanks, that's what I was wanting to know.
adosdrummer
