Hi all,
I just bought this 1992 sybary loyale wagon 4x4 hi/lo 5 spd manual as of Jan 12, 2013. Working well until now March 7, 2013.
Went out to go to town, and the engine will turn over, but will not start. Was
starting fine until now with no problems. Attempted to kick in, but that is it.
The first time it happened I went out a couple hours later and the car started out normally. Thought I flooded it. Usually I don't have to depress the gas pedal and a few starting cranks and it starts up fine.
And today March 13 went out and the same thing happened. It cranks over good, but not starting up. Waited again 6 hours later and still won't start up normally.
I have no knowledge of this type of vehicle. Has a 1.8 liter engine, but no idea what type of engine I am looking at or anything about sensors, or the abbreviations of them.
Ignition switch seems to work, as the starter engages and engine turns over, but will not start. Seems the engine will not fire.
Was thinking if it could be a moisture problem or a coil problem.
Any suggestions?
Thanks in advance
Reason: add more information
