Go Back   Subaru Legacy Forums > General Forums > Pre-purchase Questions
Reload this Page Need some impressions of this LGT...built motor...
#1: 03-01-2013, 01:09 PM
 careercadaver
careercadaver's Avatar
Car: 2005 SWP LGT 5MT
Send a private message to careercadaver Find all posts by careercadaver Reply With Quote
Been watching for an LGT for some time and came across this and wanted to get some impressions of the mods owner has performed. I have done quite a bit with the WRX platform but am a bit new to built engines...At his asking price I could still afford to throw a new shortblock in if need be.
Here are the details of his write up on the car...
The body and transmission has 110k miles. Limited package...He says the tune is at about 335whp, seems pretty conservative for the built block and that he did so for longevity. He said he is commuting more for work and wants something more fuel efficient. Block is warrantied by AZP Installs in NJ...
The motor was just recently rebuilt using :
- Wiseco forged pistons and rods
- ACL main and rod bearings
- Supertech valves
- Cylinder walls in the block resurfaced.
The motor has only 3k miles on it. The oil has been changed 3 times since the new motor was built. I also had a lot of other maintenance parts changed when I replaced the motor. Here is a list of what I put in. All of the following items also only have 3k miles on them.
- Blousch 380XT turbo,
- CNT downpipe and uppipe,
- Deatschworks 850cc injectors and fuel pump,
- Gates timing belt kit with water pump and thermostat,
- RacerX front mount inner cooler,
- Stainless turbo supply lines,
- KSTech 73mm intake,
- Perrin 3" turbo inlet,
- Perrin boost controller,
- Group N motor and transmission mounts,
- new oil pump and cooler,
- new cam gears,
- ACT HD clutch with single mass flywheel,
- NGK 1 step colder plugs
- Koni yellow adjustable sport struts
- Epic 3/4" drop springs.
I also have a cobb access port used for tuning the car, it has a state 4 tune by EFI Logic in CT.
Any impressions would be appreciated.
careercadaver
Find More Posts by careercadaver
#2: 03-01-2013, 01:12 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
AZP Installs knows their shit. If they did the install / build I wouldn't hesitate to pick up a car if you are looking for something modified.
I'm sure you could give them a call at the shop to discuss the specific build, especially if it was done relatively recently.
Who tuned it?
In stock and shipping now
BarManBean
Find More Posts by BarManBean
#3: 03-01-2013, 01:14 PM
 careercadaver
Stage 4 Tune on COBB Accessport... I'm more familiar with protunes...would you suggest I run the COBB or have it retuned?
I'm not necessarily looking for something that's modified but wont argue if things are done correctly...
careercadaver
#4: 03-01-2013, 01:17 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
There is no stage 4 off-the-shelf tune from Cobb that I'm aware of. He is just using the AP to log / flash the tunes, but someone out there made a custom tune for the car--need to find out who.
EDIT: Just to be clear, using an AP on a legacy doesn't imply that you don't have a custom tune. I think it is the same for WRXs. You can certainly use the OTS maps, but I believe those only cover you up to a basic stage 2 setup. Once you go past that you need a custom tune whether you are using an AP or opensource.
BarManBean
#5: 03-01-2013, 01:20 PM
 careercadaver
EFI Logic in CT did the tune.
careercadaver
#6: 03-01-2013, 01:21 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Others from up in that neck of the woods will likely chime in, but I'm pretty sure that a reputable tuner.
BarManBean
#7: 03-01-2013, 01:24 PM
 whitetiger
whitetiger's Avatar
Title: IDGAF
Send a private message to whitetiger Find all posts by whitetiger Reply With Quote
they are one of the most reputable tuners. I'm sure AZP will see this thread and chime in.
whitetiger
Find More Posts by whitetiger
#8: 03-01-2013, 01:37 PM
 careercadaver
Just spoke with a rep with AZP and he did remember the vehicle. Reading good things about the EFI Logics as well.
careercadaver
#9: 03-01-2013, 01:38 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Sounds like you may have found a winner.
Where are you located anyway?
BarManBean
#10: 03-01-2013, 01:39 PM
 careercadaver
I'm out of Kalamazoo, MI.
careercadaver
#11: 03-01-2013, 01:40 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
mmmm...good beer up there!
BarManBean
#12: 03-01-2013, 02:00 PM
 careercadaver
For Sure. Bells and Founders are both local. Lots of Microbrews...
Am I ignorant to think I could run a built engine as a dd and expect some longevity and reliability? I don't drive like a bat outta hell. In all honesty I'm pretty easy on my car. I like having the power when I want it but would say that I was in boost with my WRX maybe three times a week.
careercadaver
#13: 03-01-2013, 02:03 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
It's a bit silly to think that you can have a modified car like that and have zero issues IMO. It could very well be a great DD, but you should know how to turn a wrench or two or at least have a pretty friendly mechanic that can diagnose things for you.
Honestly, if you only hit boost that often that car would just be crazy overkill. Don't know that it would be worth it for you.
BarManBean
#14: 03-01-2013, 02:07 PM
 careercadaver
A buddy and I put my 2.0l WRX to stage 3 and I would say that I'm fairly savvy. Too, I have the cash and the know how to put this back to stock if need be. It sounds like this was put together well, or I probably wouldn't even consider it...
careercadaver
#15: 03-01-2013, 02:20 PM
 BarManBean
BarManBean's Avatar
Title: Hicksta V2.0
Car: '05 OBXT 5MT
Yeah, builder / tuner are top notch.
BarManBean
