MWSOC Subaru Shootout 2012
Vehicle Specifications:
2005 Legacy GT Limited Garnet Red Pearl
463 WHP E85
405 WHP Pump 93
Engine:
EJ255 2.5 Liter, Flat 4 Cylinder
NGK Iridium Plugs (1 Step Colder)
Crawford V2 Air/Oil Separator
Amsoil Synthetic 5W-30
Turbocharger & Induction:
Blouch 20G XT (8cm Hotside)
AVCS Kit with VF Series Banjo
Vibrant 90 Degree Elbow
STI Intake Manifold
Grimmspeed Phenolic Spacer 3mm
Grimmspeed TGV to Engine Gaskets
Grimmspeed Intake Manifold to TGV Gaskets
TGV Deletes
RacerX FMIC with Custom Fabricated Piping
Tial Q BOV 50mm 12 PSI Spring
HOA 3 Port Boost Control Solenoid
Samco Inlet Hose
Short Ram Intake
Fuel & Tuning:
Walbro 255lph Fuel Pump
Top Feed Injectors Conversion with Fuel Regulator
Custom Fuel Rails with Steel Braided Lines
Deatschwerks 1300cc Top Feed Injectors
Cobb Access Port 2.0 Tuned by Junior
Exhaust:
Perrin Equal Length Headers
Grimmspeed EWG Up Pipe
Tial MVS 38mm VTA EWG (.9 Bar)
Perrin Catted Downpipe
Magna Flow Resonator
Magna Flow 3" Y Pipe
Magna Flow Mufflers
Drivetrain:
2004 STI 6 Speed Transmission
Exedy Stage 2 Clutch Kit
Braided SS Clutch Line
Kartboy 6 Speed Short Throw Shifter
Kartboy Shifter Bushings
STI Front Axles
Spec B Rear Axles
R180 Rear Differential
Brakes:
2004 STI Brembo Calipers Front
DBA 4000 Slotted Rotors Front
Hawk HPS Pads Front
2004 STI Brembo Calipers Rear
DBA 4000 Slotted Rotors Rear
Hawk HPS Pads Rear
SS Braided Brake Line Set
ATE Super Blue Brake Fluid
Suspension, Wheels, & Tires:
Perrin 25mm Front Sway Bar
Rallitek Front Endlinks
BC Racing BR Series Coilovers
18x8 +50 Enkei Imola
Hankook Ventus V12 EVO K110 225/40ZR18
Interior:
52mm Auto Meter Sport Comp II Boost Gauge
52mm Auto Meter Sport Comp II Oil Pressure Gauge
Dual Stealth Cubby Gauge Pod
LED Conversion Kit (Dome, License, Door)
Recaro ProRide Blaze Carseat
Exterior:
R-Rev Front Lip Painted GRP
R-Rev V2 Eyelids Painted GRP
Blacked Out Grill
DDM Hid Headlights 6000K
Cleared and Blacked Out Headlights
White/Amber Switchback LED Turn Signal Bulbs
Rear Windows Tinted
Debadged Emblems
