Go Back   Subaru Legacy Forums > Technical Forums > Detailing, Maintenance, and Long-term care
Reload this Page seafoam? ok to use in lgts?
#1: 02-24-2013, 09:38 PM
 PaSprinter24
PaSprinter24's Avatar
Car: 08 LGT 5spd
Send a private message to PaSprinter24 Find all posts by PaSprinter24 Reply With Quote
hey guys I was just wondering if it was alright to put seafoam in our cars? Im thinking that it would be ok in the brake booster and the fuel but im not sure if its alright in the oil. any takes?
PaSprinter24
Find More Posts by PaSprinter24
#2: 02-24-2013, 10:09 PM
 Impulse
Impulse's Avatar
Title: what does this mean?
Car: '06 OBP LGT 5MT Faster-er
Send a private message to Impulse Find all posts by Impulse Reply With Quote
I sucked it into the intake via BPV return valve. Worked fine for me. I skipped the oil part as i wasn't due for an oil change for 2k more mi.
Impulse
Find More Posts by Impulse
#3: 02-25-2013, 05:52 PM
 PaSprinter24
Car: 08 LGT 5spd
bump for any opinions on seafoam!
PaSprinter24
#4: 02-27-2013, 05:52 AM
 quick4dr
quick4dr's Avatar
Title: Contributing V.P.
Car: 05GT BNR 16g, EWG,ELH,FMIC w/cdVB, EFI
Send a private message to quick4dr Find all posts by quick4dr Reply With Quote
love it! using it for years on all sorts of projects. The liquid and the spray version are fantastic. The GM 3800 crowd were i came from really uses this stuff like "duct tape" fixes anything.
Ive used it for everything from freeing seized RC motors, to regular fuel treatment for my families vehicles.
I also treated my LGT through the BPV line sucking it in slowly at approx 2k rpm. I find it best to pour the seafoam into a wide shallow tupper-ware so that i can dip the hose into it and meter exactly how much i suck up throughout the treatment.
quick4dr
Find More Posts by quick4dr
#5: 02-27-2013, 08:10 AM
 Max Capacity
Max Capacity's Avatar
Title: Gearhead
For the oil, just use the Subaru motor flush or Gunk motor flush, just don't drive the car when it's in there.
Warm up the engine for 5 minutes and change the oil.
I have dumped Seafoam in the gas tank, once too.
Max Capacity
#6: 02-27-2013, 03:46 PM
 PaSprinter24
Car: 08 LGT 5spd
oh cool I didn't know Subaru made a motor flush. ill have to grab some next time im at the dealership. I just didn't know if it would eat up the turbo seals if I put it in the oil. def don't have the money now for a turbo swap. thanks for the info guys really appreciate it
PaSprinter24
#7: 03-06-2013, 12:16 PM
 Max Capacity
Title: Gearhead
FWIW, on Jul 9 05 I used a can of Gunk motor flush when the car had 28,100 miles, then Nov 28 06 at 63,153 miles, then Aug 15 09 at 111,770 miles again on Oct 31 09 at 119,311 miles, then on Mar 17 11 at 141,800 after the P0011 and P0021 CEL.
I replaced the turbo at 142,200 miles
Used the Subaru flush at 144,300 Oct 1, 11
I haven't done it again. The new ej257 has about 16,000 miles on it. I replaced the short block because of oil usage, the bearings were quiet.
Max Capacity
#8: 03-06-2013, 03:30 PM
 No DRFT
No DRFT's Avatar
Title: Buy a shotgun
Send a private message to No DRFT Find all posts by No DRFT Reply With Quote
Dump a can of seafoam in the tank today.
"Americans used to roar like lions for liberty; now we bleat like sheep for security."
— Norman Vincent Peale
No DRFT
Find More Posts by No DRFT
