#1:
03-05-2013, 08:18 PM
ok, gonna try over here. Hand brake issue.
Car: 97 black LGT 5spd wagon
Ok, so I'm not getting any love in the brakes section, I'll try over here. Don't let me down 2nd Gen. guys, lol... The handbrake on my 97 lgt wagon is all messed up. The button doesn't pop back out. For it to pop out, I have to pull it up several times and let it drop down for the button to kind of vibrate it's way out. Is there a way to fix this? I've searched for this issue and can't find a thread so I decided to post. Thanx in advance.
#2:
03-05-2013, 11:13 PM
Car: 96 Legacy L Postal, 94 L Postal
Mine does the same thing. I've been meaning to check it out but have more pressing issues to deal with... maybe someone already knows. It might be something simple like the spring getting dirty or something.
#3:
03-05-2013, 11:49 PM
Car: 95 BK, 93 SS!
Did you try spraying the button with silicone spray and pushing it in a few times?
When I get a chance and I'm at my computer I can post a diagram of the handbrake assembly from the fsm.
#4:
03-06-2013, 01:10 AM
Car: 99 Legacy 2.5GT Toyota Supra 2jz/R154
Remove the center console and inspect the hand brake assembly.
#5:
03-07-2013, 08:18 AM
When I originally bought the car, it looked as though it had been in a flood. So I pulled all the interior out except dash and ebrake. I did, however, spray simple green and hose down the ebrake assembly in place with no better results. So I guess next, I'll have to pull the ebrake out too. I hope its not as big a pita as my 66 bug.
#6:
03-07-2013, 09:00 AM
Car: 95 BK, 93 SS!
Maybe this will help.
#7:
03-07-2013, 09:35 AM
I encountered the same problem. removed the panel around the brake lever - spray lube at the mechanism and work it until it frees up.
#8:
03-09-2013, 01:46 PM
Well I pulled it all apart and cleaned it, sprayed white lithium grease in there, still no better. So now I think I'll just go to the wrecking yard.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
