Reload this Page 1998 Legacy GT front bumper cover
#1: 02-28-2013, 10:20 PM
 penrod
Send a private message to penrod Find all posts by penrod Reply With Quote
Sorry if I offend by not looking thru lots of your site's specifics but my son has just bought a 1998 Legacy GT. It needs a new front bumper cover.
1) Are 1998 Legacy and Legacy GT front bumpers the same?
2) What other years of Legacy's have the same bumper as a 1998 Legacy GT?
I would appreciate your help as I seem to get conflicting information from the internet otherwise.
Thanks
penrod
Find More Posts by penrod
#2: 02-28-2013, 10:38 PM
 spooln30
Car: 99 Legacy 2.5GT Toyota Supra 2jz/R154
Send a private message to spooln30 Find all posts by spooln30 Reply With Quote
No the Legacy and LGT front bumpers are different. I think all 96-99 LGT and LGT limited bumpers are the same. Just the limited ones are fully painted and the LGT lip is black.
spooln30
Find More Posts by spooln30
#3: 03-01-2013, 02:02 AM
 r3v_v3ng3
Car: 98 legacy gt
Send a private message to r3v_v3ng3 Find all posts by r3v_v3ng3 Reply With Quote
1)Yes the 98-99 legacy bumpers are the same gt or not with the exception of the outbacks
2)The 97 GT have the same bumper
r3v_v3ng3
Find More Posts by r3v_v3ng3
#4: 03-01-2013, 05:04 AM
 Sludgeroo
Sludgeroo's Avatar
Car: 1999 Lesbian Moving Van
Send a private message to Sludgeroo Find all posts by Sludgeroo Reply With Quote
Any second gen Legacy GT bumper will fit over your bumper cover. So will an outback, you just wont have mounting points for the fogs on the bumper beam.
If you get a Legacy L or Ts bumper, it will fit no problem, but the grille is shorter and will need the accommodating grille, as the outback/gt grille height wont allow it.
But you can put an L grille on a GT.
If you can find a Legacy Brighton, it will have the same bumper.
Like I said, all look similar and fit just need to switch some simple stuff around to fit.
Good luck, and let us know what you find.
Sludgeroo
Find More Posts by Sludgeroo
#5: 03-01-2013, 09:21 AM
 r3v_v3ng3
Car: 98 legacy gt
^The OP is asking for the same bumper as the 98 GT
r3v_v3ng3
#6: 03-01-2013, 03:16 PM
 Zues Marine
Zues Marine's Avatar
Title: This Guy..
Car: 98 SF5, 95 BK6, 91 VW Fox
Send a private message to Zues Marine Find all posts by Zues Marine Reply With Quote
and now he's got options^
The Following User Says Thank You to Zues Marine For This Useful Post:
Sludgeroo (03-01-2013)
Zues Marine
Find More Posts by Zues Marine
#7: 03-01-2013, 04:59 PM
 johnegg
johnegg's Avatar
Send a private message to johnegg Find all posts by johnegg Reply With Quote
all lego, GT, LSi, outback, bumpers 95 - 99 will swap. with limitations.
the outback and the GT grilles are taller, they hang down lower, so the bumpers are shaped different to accommodate. but the bumper / grille combination will swap onto any of the cars listed above.
fyi: rumor has it that the outback grille and the GT grille will swap with no other changes.
johnegg
Find More Posts by johnegg
#8: 03-01-2013, 10:06 PM
 Bandit240
Bandit240's Avatar
Car: 1995 Legacy Postal, 1995 Legacy L wagon
Send a private message to Bandit240 Find all posts by Bandit240 Reply With Quote
I found that with my 1995 L I had to also change the metal and plastic core of the bumper to change to the GT bumper skin. As has been said, the grille is taller and requires the cut out that the inner bumper has in order to work. The inner bumper was easy to remove, just 4 big bolts on the frame rail once the skin is removed. Or just undo the skin from the fenders and unbolt the bumper and it all comes out as a unit. Didn't find that out until I already removed the skin.
Bandit240
Find More Posts by Bandit240
#9: 03-02-2013, 12:41 AM
 Kennyfvholla
Kennyfvholla's Avatar
Car: 99 OBL, 04 Accord EX 6MT coupe
Send a private message to Kennyfvholla Find all posts by Kennyfvholla Reply With Quote
Okay....
ONLY 97 to 99 GT bumper covers are the same as the one on the car now.
You can replace it with any 96 to 99 Outback bumper cover as they use the same support bar and grille type.
If you're looking for the same one as on the car, your best bet is to just buy a brand new one from the dealer. Finding one used and paying for the shipping isn't worth the cost.
Kennyfvholla
Find More Posts by Kennyfvholla
