Reload this Page My turbo is whining and there is no POWER.
#1: 01-29-2013, 08:38 AM
 huntzmax
Car: 2005 Legacy GT
Send a private message to huntzmax Find all posts by huntzmax Reply With Quote
This morning while driving to work my 05 LGT was driving normal. Normal power normal whistle from the turbo. I was almost to work and then I pushed on the gas and I got nothing from the turbo but a whine and no power. There is nothing knocking around inside, it still sounds smooth but there just isnt any power. Now I live in Utah and I was just on a cruise this last week and I let it sit the entire time. Last night I cleaned it off and turned it on for at least 20-30 minutes to let it warm up and get everything circulating. It seemed fine this morning.
2005
GT
110K
105K replaced timing, belts, pulleys and water pump.
Any suggestions???
Thanks in Advance.
Dustin
huntzmax
Find More Posts by huntzmax
#2: 01-29-2013, 10:21 AM
 06silvarubiLGT
06silvarubiLGT's Avatar
Send a private message to 06silvarubiLGT Find all posts by 06silvarubiLGT Reply With Quote
Stop driving. Tow to reputable Subaru shop. Be sitting down when they give you the diagnosis. Minimum Turbo needs replace remove the banjo bolts, Oil cooler and engine flush.
In the meantime check the oil? Is it low?
Are you tuned, any mods? vehicle history will help
post location people can give insight on shops to go too
The Following User Says Thank You to 06silvarubiLGT For This Useful Post:
Catalyst (02-10-2013)
06silvarubiLGT
Find More Posts by 06silvarubiLGT
#3: 01-29-2013, 10:23 AM
 alegend90
alegend90's Avatar
Car: 2010 Legacy GT
Send a private message to alegend90 Find all posts by alegend90 Reply With Quote
research the stories people on the site have posted regarding bad turbos, and them failing. lots of advice, and things you can do to diagnose it. as said above, first stop driving because if it is the turbo you're asking for trouble if its still onthe road.
alegend90
Find More Posts by alegend90
#4: 01-29-2013, 10:26 AM
 06silvarubiLGT
^this.. but quick run through, if your mechanically inclined pull the DP and look for oil and then feel for shaft play..
06silvarubiLGT
#5: 01-29-2013, 10:37 AM
 Max Capacity
Max Capacity's Avatar
Why did you let it idle for 20-30 minutes ?
Start it up and drive the car, you don't need to let it warm up. That just allows gas to dilute the oil for a longer period of time.
The car will warm up faster if you drive it.
My wagon sat over the weekend in single digit's. When I started Monday for the drive the work. I start it, clean off the frost on the windows and drive it.
The Spec sit's all week, we load it on Friday evening, start it and drive to VT.
You'll want to remove the banjo filter when you replace the turbo if not sooner.
You'll want a catless up pipe too.
Check the oil level, top it off as needed.
Look for a vacuum line that may have fallen off.
The turbo should not whistle. Its more of a rush of air. Whistle is not good.
Your going to have to remove the down pipe (dp) and check for shaft play on the turbo.
Max Capacity
#6: 01-29-2013, 08:34 PM
 specialB
specialB's Avatar
Car: GT Spec.B #449, VF52 cornfed
Send a private message to specialB Find all posts by specialB Reply With Quote
^what he said. do as much as you possibly can within your own mechanical limits before you take it anywhere.
specialB
Find More Posts by specialB
#7: 01-30-2013, 12:27 PM
 huntzmax
Car: 2005 Legacy GT
Thanks for all the input. I havent driven it since it happened. It is just sitting. I am driving my jeep for now until i get some time to look at it. I built my jeep so I have a little mechanically inclined. I just dont have a place to put the car to work on it. It might sit for a little before I can get to it. Ill do my research.
Max capacity~ I just warm it up because I hate the cold and to clear up the windows. Ill get a catless up pipe. If I am correct, I heard there is a "kit" for replacing the turbo, oil cooler, etc. Is that right?!
If i do have to get a new turbo, should I go with the one that is from the 2009-2013 WRX? I heard it would be a good replacement? along with the catless up.. Anything else while I am in there I should look into replacing?
Thanks again guys, I really appreciate it.
huntzmax
#8: 01-30-2013, 12:32 PM
 Max Capacity
Yes the vf52 is the popular choice.
Contact Mike at www.AZPinstalls.com tell him I sent you. Send him a email and ask him for advice and help.
I bought a lot of my parts from him.
When it comes time fora tune, give this Mike a email http://legacygt.com/forums/forumdisp...iance-121.html
and have him help you out.
He's keeps both my cars happy.
Here's my rebuild thread, lots of good info and pictures.
http://legacygt.com/forums/showthrea...-r-184106.html
Max Capacity
#9: 01-30-2013, 02:45 PM
 gear_monkey
Send a private message to gear_monkey Find all posts by gear_monkey Reply With Quote
A catless dp will sure allow the turbo whistle to be audible. But I agree a pure stock car should have no whistle.
gear_monkey
Find More Posts by gear_monkey
#10: 01-30-2013, 03:23 PM
 Max Capacity
My catless up/dp allows me to hear the whoossh of the turbo. You should not have a turbo that whistles.
Max Capacity
#11: 01-31-2013, 10:10 AM
 huntzmax
Car: 2005 Legacy GT
Thanks guys. I just checked my oil, and its way low. Below the "L". I never let something like this happen. Im usually pretty caution about watching it and I never expected it to go this fast. The next scheduled oil change was still 1000 miles away. it has been a daily driver and I'm not gunning it hardly at all. Do I add oil in it and fill it up, and see what happens or what?
huntzmax
#12: 01-31-2013, 10:41 AM
 RabidWombat
Car: 09 DGM LGT Stage 0, 08 DGM Impreza
Send a private message to RabidWombat Find all posts by RabidWombat Reply With Quote
A sudden change in oil consumption points to something broken, like say a blown turbo.
First thing would be pull the downpipe and check the turbo. You can add oil but continuing to drive the car before investigating will likely just make things significantly more expensive.
RabidWombat
Find More Posts by RabidWombat
#13: 01-31-2013, 12:05 PM
 huntzmax
Car: 2005 Legacy GT
thank you.
huntzmax
#14: 01-31-2013, 12:10 PM
 Max Capacity
Yes, See my sig.
Never let these engine get low on oil, alway's keep it topped off. A little over is not a bad thing.
Before the new EJ257 I was topping off the oil every 2/3 day's. All I added was maybe .1 or .2 qt at a time sometimes nothing.
Max Capacity
#15: 01-31-2013, 03:46 PM
 scoobycoupe
scoobycoupe's Avatar
Car: 06 Legacy GT
Send a private message to scoobycoupe Find all posts by scoobycoupe Reply With Quote
The last time I heard anything like that was with my 97 eclipse gst, and that was after I did a sweet burn out and blew the turbo but when it happened to mine i did not completely lose power, it was just very very loud.
Unfortunately that is probably what you are hearing, check the turbo for shaft play, in and out = no bueno.
scoobycoupe
Find More Posts by scoobycoupe
