03-03-2013, 08:05 PM
No blinkers
My blinkers don't work, however my hazards do.
Think I'm just looking at a bad switch?
-broknindarkagain
COME AND TAKE IT
"The only thing necessary for the triumph of evil is for good men to do nothing."
"When governments fear the people, there is liberty. When the people fear the government, there is tyranny.
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government."
"Never Forget, even for an instant, that the one and only reason anybody has for taking your gun away is to
make you weaker than he is, so he can do something to you that you wouldn't allow him to do if you were equipped
to prevent it. This goes for burglars, muggers, and rapists, and even more so for policemen, bureaucrats, and politicians."
03-03-2013, 08:23 PM
Car: 05 LGT 5EAT
Probably bad switch since the hazards work.
03-03-2013, 08:53 PM
Title: For Whom the Bell Tolls
Car: 98 Legacy Wagon
Blown fuse, faulty flasher unit, or, like you said, turn signal switch. Does the flasher unit make a sound when you activate either of the turn signals? Also, keep in mind that when the hazard switch is 'activated,' it disables both turn signals. Food for thought.
03-03-2013, 09:04 PM
Car: 95 Legacy LS and 2000 Mazda Protege LX
Double check the hazard switch. I had to use mine not too long ago and afterwards my turn signals did not work at all. I pushed the hazard button and they came on so I turned it off then just like that the signals worked again. My switch was loose and caused that issue so maybe its worth looking at.
03-03-2013, 09:23 PM
When I turn the blinkers on left or right, I get no flashing arrow on teh dash, no noise, and the lights outside don't do anything. However if I turn on the hazards, both green arrows in the dash blink, I get the noise, and all 4 corners outside flash.
-broknindarkagain
COME AND TAKE IT
03-03-2013, 10:16 PM
Car: 1998 subaru legacy gt
did you check the blinker fluid resevoir? ive heard that for some reason these subarus like to eat it if not properly maintained.
The Following 3 Users Say Thank You to Dufek125 For This Useful Post:
03-04-2013, 09:45 AM
Car: 1998 Subaru Legacy Outback Limited
This.
In fact, check the fluid line running from the reservoir to the front, passenger turn signal. I've found that on some cars, one of the plastic clips securing it to the firewall tends to come loose (or break, in my case) and allow the line to droop down low enough to rub against the steering shaft. You can rub a hole in it really easily because the line is very thin.
03-04-2013, 08:57 PM
Car: 1999 Legacy "L" 5MT, 1997 Jeep Wrangler
Try eyedrops until your eyelids grow back.
They call the "turn signal switch" your "multifunction switch"
Check fuses, check turn signal relay, check multifunction switch. I had an MFS go out on another car and same thing happened but only on one side.
