Reload this Page White smoke??? but has new heads and gaskets
#1: 03-01-2013, 11:37 PM
 Grocery-Getter
Grocery-Getter's Avatar
Send a private message to Grocery-Getter Find all posts by Grocery-Getter Reply With Quote
OK so my wagon is smoking white smoke on start up dies down at idle but is make when you give her gas. It has new head gaskets that was first, still smoked then put new heads on it. Still smoking . I'm thinking maybe cracked block. Any thoughts? I'm already collecting parts are a WRX swap. but it is driving me crazy not being able to figer it out. A friend said that if it had enough coolant in the cat IE" that it was soaked that that could cause it till it all burns out". Anyone head of this before? Thanks for any insight
Grocery-Getter
Find More Posts by Grocery-Getter
#2: 03-01-2013, 11:47 PM
 EthirtyM3
Car: 2001 LGT Wagon
Send a private message to EthirtyM3 Find all posts by EthirtyM3 Reply With Quote
Sounds like bad valve stem seals. Are you burning oil?
EthirtyM3
Find More Posts by EthirtyM3
#3: 03-02-2013, 07:00 AM
 Hemingway
Hemingway's Avatar
Title: For Whom the Bell Tolls
Car: 98 Legacy Wagon
Send a private message to Hemingway Find all posts by Hemingway Reply With Quote
White smoke means that you are burning coolant. Somewhere. Without more information (car, pics of smoke, engine, miles, etc) it is difficult for any of us to opine on the problem. Is your oil discolored (oil and coolant mix)?
Hemingway
Find More Posts by Hemingway
#4: 03-02-2013, 07:25 AM
 travgag
travgag's Avatar
Send a private message to travgag Find all posts by travgag Reply With Quote
It depends, I had a catastrophic failure and first Time I ran it I freaked out because of white smoke, but it was only left over coolant in the exhaust, good luck
travgag
Find More Posts by travgag
#5: 03-02-2013, 07:50 PM
 PINESMOKER
Car: 98 Legacy GT
Send a private message to PINESMOKER Find all posts by PINESMOKER Reply With Quote
Just did heads on a 98lgt and it smoked for a week plus. Do check to make sure you don't have bubbles in your radiator or coolant tank. If you do... You got problems good luck
PINESMOKER
Find More Posts by PINESMOKER
#6: 03-02-2013, 08:54 PM
 DOHCEJ22E1
DOHCEJ22E1's Avatar
Title: Contributing V.P.
Car: 1998 Subaru Legacy GT-L powered by EJ22D
Send a private message to DOHCEJ22E1 Find all posts by DOHCEJ22E1 Reply With Quote
Check your coolant for bubbles. If not, then check your PCV valve. A bad one will cause white smoke.
DOHCEJ22E1
Find More Posts by DOHCEJ22E1
#7: 03-03-2013, 01:37 AM
 spooln30
Car: 99 Legacy 2.5GT Toyota Supra 2jz/R154
Send a private message to spooln30 Find all posts by spooln30 Reply With Quote
How ling ago were the HG done? When you or whom ever did the head gaskets did you fully remove the exhaust header from the car or did you just unbolt it and let it hang? What probably happened is when the heads were pulled coolant poured into the exhaust and you just need to burn it off.
spooln30
Find More Posts by spooln30
#8: 03-03-2013, 09:16 AM
 Grocery-Getter
I didnt do the HG the guy I brought the car from did. He did them and it kept smoking so he just parked it. He didn't want to put any more money in it, that's how I just it for so cheap. I'm hopeing that's all it is as well, I dont have it home right now so I cant check if there are bubbles in the coolant. I'm bring it home Friday so I will be able to check so of these things out.
Grocery-Getter
#9: 03-06-2013, 01:40 AM
 spooln30
Well in my past experience it shouldn't take more than 30-40 miles to fully burn out the coolant from the exhaust. Hope he used the Subaru headgaskets and did the proper maching on the heads and blocks.
spooln30
#10: 03-06-2013, 01:27 PM
 Toallhisdoom
Toallhisdoom's Avatar
Car: 3000gt, 98 Legacy gt limited
Send a private message to Toallhisdoom Find all posts by Toallhisdoom Reply With Quote
Or like in my experience. I bought ebay head gaskets. It was overheating after i installed them still! thought it was a craked head, replaced the gaskets with OEM ones and it worked great.
Toallhisdoom
Find More Posts by Toallhisdoom
#11: 03-07-2013, 11:28 AM
 johnegg
johnegg's Avatar
Car: 98 obw, 97 GT w/ ej22, '01 H6 VDC
Send a private message to johnegg Find all posts by johnegg Reply With Quote
what he said.
smoker, what kind of head gaskets did you use??
johnegg
Find More Posts by johnegg
#12: 03-08-2013, 09:48 AM
 PINESMOKER
Car: 98 Legacy GT
I used the new FelPro MLS gaskets. I did a lot of research on the them. I know every one says to use OEM's, but I've got a 1000 miles down and no problems.
PINESMOKER
#13: 03-08-2013, 10:16 AM
 johnegg
johnegg's Avatar
i wonder what was used on the OP's car?
johnegg
#14: 03-09-2013, 08:28 AM
 Grocery-Getter
ok so got it home yesterday. smoke is blue tint dose not smell of cool and oil looks like it just came out of the bottle. i checked coolent to see if there was bubbles none not till i grabbed the upper rad hose. my wife followed me home see said it let up sfter a little bit but then went back out up started it to still lots of smoke. I guy didn't remember what kind of gaskets where used and said they let it idle for a day to see if it stopped but did not drive it around.( no plates for it ) I go Monday it do that. I pulled the PVC valve and put a new one on. It didn't look that bad. like I the first post I'm going to put a EJ20 in it but would like to know what is wrong with this on so i can sell it. This thing has me stumped.
Grocery-Getter
