Reload this Page Rear wiper, on Wagon
#1: 06-14-2010, 01:11 PM
 Mendozer
Mendozer's Avatar
Car: 05 Legacy Wagon
Send a private message to Mendozer Find all posts by Mendozer Reply With Quote
The other day I went to use the rear wiper on my 05 Wagon, and only the sprayers are working. The arm no longer rotates.
I took a look at the cabin fuse box and the engine fuse box...no resolution.
Anyone have this happen before? Anyone know how to fix it? Is this a warranty item?
Any help (regarding this issue) is welcomed.
Karl
Mendozer
Find More Posts by Mendozer
#2: 06-14-2010, 01:25 PM
 c-lo
c-lo's Avatar
Car: 05 Atlantic Blue LGT Wagon,07 Civic EX
Send a private message to c-lo Find all posts by c-lo Reply With Quote
sounds like the motor crapped out??
c-lo
Find More Posts by c-lo
#3: 06-14-2010, 04:09 PM
 lofthouse_gt
lofthouse_gt's Avatar
Car: 05 LGT RBP "Stage 2"
Send a private message to lofthouse_gt Find all posts by lofthouse_gt Reply With Quote
I would lean to guess motor also
lofthouse_gt
Find More Posts by lofthouse_gt
#4: 06-14-2010, 07:22 PM
 Mendozer
Mendozer's Avatar
That's what I was thinking. Boo.
I had a quick look through the repair manual and doesn't look like a fun task to change.
Either the switch in the steering column or the damn motor.
I hate the damn dealer
Mendozer
#5: 06-15-2010, 12:30 PM
 ClimberD@HexMods
ClimberD@HexMods's Avatar
Title: 5EAT Performance Vendor
Car: 05 LGT 5EAT
Send a private message to ClimberD@HexMods Find all posts by ClimberD@HexMods Reply With Quote
Perhaps you can confirm the motor by feeding it 12V in the same way the relay would, or by switching the relay manually. I haven't checked the wiring diagrams on the rear wiper motor, but should be easy to look up. Or you can test continuity through the switch to see if the switch still works like it should per FSM.
I'm sure a generic mechanic with good reviews can change the motor. No need to pay a premium at the dealer if that is what the price quotes come back at.
Radically improve 05-07 5EAT shifting and power limits with the
HexMods F1 Valve Body
service! Read More
ClimberD@HexMods
Find More Posts by ClimberD@HexMods
#6: 06-15-2010, 04:13 PM
 mbcracken
mbcracken's Avatar
Car: 05 GT 5MT Leggy Wagon
Send a private message to mbcracken Find all posts by mbcracken Reply With Quote
I have had problems with my rear window wiper and have replaced both the motor and wiper switch/stalk on the steering column WITHOUT success. My problem is slightly different from yours. My wiper works normal in full on mode but not intermittent. The blade does not return back to the beginning position if I turn it off. The intermittent also comes up 7-8 inches short on each swipe and is most annoying for me.
The only possible solution lies somewhere in the wiring which can be suspect where the wiring leaves the car body and feeds into the rear hatch door. I've peeled back the rubber grommets and my wiring looks OK from there but some Outbacks have reported the problem. My next steps would be to tear into the interior which I really don't want to do. I did the rear wiper motor myself and it was not that bad of a job.
Not sure I helped but thought I might share of my rear wiper story to help you before spending a bunch of money. Definitely get the motor tested out before replacing as they are spendy.
Cheers,
Mike
mbcracken
Find More Posts by mbcracken
#7: 06-15-2010, 06:49 PM
 ClimberD@HexMods
Car: 05 LGT 5EAT
Cheers,
Mike
Perhaps test continuity of the wire(s) (if applicable) that control the intermittent? Have you checked the vacation pics?
service! Read More
ClimberD@HexMods
#8: 06-16-2010, 12:42 PM
 Mendozer
Mendozer's Avatar
WOW,
Thanks for the good advice. I called the dealer about warrranty and they told me they had no idea. So i'm going to look through my papers to see what are warrantyable items. If it comes up on the list, off to the dealer I go, otherwise i'll do as mentioned above and try to distinguish between whether its the motor or the steering column.
Thanks for the help.
Karl
Mendozer
#9: 06-16-2010, 10:39 PM
 pflo
pflo's Avatar
Car: 05 LGT ABP wagon
Send a private message to pflo Find all posts by pflo Reply With Quote
First pop off the black cover and see if the nut has come loose - ie. the motor still works but the arm is not moving.
pflo
Find More Posts by pflo
#10: 06-17-2010, 07:54 AM
 Mendozer
Mendozer's Avatar
LOL,
Thanks for the little tid-bit of advice. I'll take a look at that First then move on from there!
Didn't even think to look for that!
Mendozer
#11: 12-23-2012, 04:19 PM
 RustyShackleford
RustyShackleford's Avatar
Car: 2006 Outback 2.5i Ltd w/ '07 HU
Send a private message to RustyShackleford Find all posts by RustyShackleford Reply With Quote
My rear wiper also has stopped working. The rear washer still works.
I removed the lift-gate trim and unplugged the connector (which stumped me for awhile, it doesn't release the way many do, you have to pry up a plastic piece, with a sharp point, to pull the connector apart).
I hot wired 12v to the connector on the wiper motor, from the rear cigarette-lighter outlet, and the motor worked fine. (No need to hotwire GND, as the motor is still grounded even with the connector unplugged). There doesn't seem to be voltage on the corresponding pin in the wiring harness (that I unplugged). The fuse is fine.
So apparently I have a bad wiper stalk switch or a bad BIU, or possibly a bad wiring harness. I was kinda hoping it'd be the motor, as expensive as it is. (I'm not sure why people have mentioned a relay, the power for the motor seems to come straight from the BIU, per the wiring diagram, attached- unless it's a relay in the BIU). Not sure where to proceed from here. All the vacation pix stuff on how to diagnose the BIU requires the "Subaru Select Monitor" (an expensive special tool, presumably). Seems like the switch is likely the next most likely culprit - looks like to get to it, you've gotta remove the driver's airbag and the steering wheel - yikes !! The debug also mentions a "fusible link #6 in the main fuse box", but I don't see that in the circuit diagram.
Name:	Screen Shot 2012-12-23 at 6.18.55 PM.png
RustyShackleford
Find More Posts by RustyShackleford
#12: 12-23-2012, 05:10 PM
 Max Capacity
Max Capacity's Avatar
My issues were all fixed by having my buddies body shop fix 6 broken wires in the rubber grommet.
Max Capacity
#13: 12-23-2012, 06:07 PM
 c-lo
c-lo's Avatar
mine only works correctly when on full mode. i don't even want to get into the project to find out what's wrong.
224k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
c-lo
#14: 12-23-2012, 06:08 PM
 AkumaMax
AkumaMax's Avatar
Send a private message to AkumaMax Find all posts by AkumaMax Reply With Quote
C-lo it is the hatch wiring.
AkumaMax
Find More Posts by AkumaMax
#15: 12-24-2012, 07:33 AM
 dougall42
Send a private message to dougall42 Find all posts by dougall42 Reply With Quote
I've just repaired mine, the shaft had seized in the housing due to being corroded. I live in Ontario and they use a lot of salt during the winter, if Alberta is the same then it may be your problem.
It's an easy fix once you get it out of the tailgate, you have to use a lot of WD40 and a pair of vice grips to free up the shaft in the housing. I removed it completely, used emery cloth to smooth it and then filled everything with grease to keep the weather out.
dougall42
Find More Posts by dougall42
Similar Threads
BBK Brake Bias List praedet Suspension/Brakes 200 04-18-2011 07:22 AM
Suspension Tuning info robinlsb Suspension/Brakes 2 03-17-2008 03:38 PM
2005 USDM Legacy & Outback Info (Including Official Pric Tide Fourth Generation Legacy (2005 - 2009) 141 11-26-2007 02:22 PM
WTF were Subaru thinking: wagon rear wiper Scotty Exterior/Aesthetic 38 02-13-2007 05:47 AM
