Go Back   Subaru Legacy Forums > Technical Forums > Turbo Powertrains (2.0GT, 2.5GT, 2.5XT)
Reload this Page Gates stretchfit AC belt
#1: 03-05-2011, 09:46 AM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
Car: 2005 Garnet Red Legacy GT Sedan, 5MT
Send a private message to Th3Franz Find all posts by Th3Franz Reply With Quote
I see Gates recently released their Micro-V stretchfit belt for the newer 2008+ Subarus. These cars do not use an AC belt tensioner, since the OEM belt they come with is a stretchfit and self-tensions. The AC belt tensioner on the LGT is made of plastic and already broke once on my car. Right now I'm driving with no AC because I removed the belt and tensioner temporarily. I am wondering if the Gates stretchfit belt would fit the 05-09 LGT if we got rid of our tensioner.
Has anyone tried the stretchfit belt on their LGT and removed the tensioner?
If not, I'm going to try and find an 08+ WRX to measure the distance between the crank and the AC pulley and compare with my car. If it's close I'll give the stretchfit belt a shot.
-Franz
http://www.youtube.com/th3franz
Th3Franz
Visit Th3Franz's homepage!
Find More Posts by Th3Franz
#2: 03-05-2011, 10:39 AM
 AShoe
AShoe's Avatar
Car: 2005 lgt, 1996 240sx
Send a private message to AShoe Find all posts by AShoe Reply With Quote
Subscribed for results. That plastic tensioner is stupid. I was planning to buy a new one whenever I change the belts.
AShoe
Find More Posts by AShoe
#3: 03-05-2011, 02:52 PM
 integroid
integroid's Avatar
Car: 05 LGT Wagon 6MT Limited 580WHP
Send a private message to integroid Find all posts by integroid Reply With Quote
I believe it will....there were people that converted back with the tensioner and regular belt. How much is the belt? $10-$15? If it doesnt fit, just return it
integroid
Find More Posts by integroid
#4: 03-05-2011, 04:31 PM
 BAC5.2
BAC5.2's Avatar
Title: Admⅰnⅰstrator
Car: 2009 SWP Grandma XT-B (5MT)
Send a private message to BAC5.2 Find all posts by BAC5.2 Reply With Quote
Gates makes a TON of belts, so I'm sure there are other sizes for whatever our rib count is. I'd definitely be interested in removing that tensioner.
BAC5.2
Find More Posts by BAC5.2
#5: 03-15-2011, 09:53 PM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
I measured it and the LGT's distance around the pulleys is 5mm longer than the belt for the 08's. So, I pulled the trigger and ordered the belt and install tool. Will post up with results either way.
-Franz
Th3Franz
#6: 03-16-2011, 03:18 AM
 BAC5.2
BAC5.2's Avatar
That belt requires an install tool!?
BAC5.2
#7: 03-16-2011, 04:35 AM
 underground000
underground000's Avatar
Title: Bus Wanker!
Car: 08 LGT
Send a private message to underground000 Find all posts by underground000 Reply With Quote
Yes because the belt is smaller and needs to be rotated onto the pulleys. The tool helps hold the belt on one of the pulleys during install
5eat downshift rev match
Powder coated wheels: completed
underground000
Find More Posts by underground000
#8: 03-16-2011, 05:34 AM
 BAC5.2
BAC5.2's Avatar
That's right. I was thinking of the alternator having a tensioner on the bracket. The A/C belt tensioner is on the idler.
One thing I would be concerned about is excessive load on the bearings of the compressor. If the belt is much tighter than the tensioned belt with the traditional setup, I would not use it and instead find a gates stretch belt that is slightly longer than the WRX one.
Post part numbers once it works!
BAC5.2
#9: 03-16-2011, 12:19 PM
 integroid
integroid's Avatar
You didnt need a tool for my Wife's MPV....Just a tie strap. They have install instructions on Gate's website using a tie strap.
integroid
#10: 03-16-2011, 08:01 PM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
It varies by make as to which ones need a tool and which ones don't. They have a tool for the Subarus. Other makes can just use a zip tie. I think it might fight me a little bit but the tool should help.
The belt is designed to stretch.. I have a hard time believing it would load the bearings of the compressor excessively.
My fear was finding one that's too long and is too loose. +5mm for a 820mm belt doesn't seem like a big deal to me.
-Franz
Th3Franz
#11: 03-27-2011, 09:09 PM
 Th3Franz
Th3Franz's Avatar
Title: GRP > *
I installed the stretch fit belt today. Took me a little while to figure out how to secure the tool to guide the belt properly. Once I got past that, I used a ratchet to rotate the crank and guide the belt. It went on pretty smoothly and the tension feels about right. My AC works again. I figure my chances are better running this than putting on a plastic idler tensioner again.
Belt PN: K040317SF
Installation Tool: Part - #91031
-Franz
Th3Franz
#12: 03-28-2011, 04:15 AM
 BAC5.2
BAC5.2's Avatar
Fantastic. Good news!
BAC5.2
#13: 03-28-2011, 10:00 AM
 integroid
integroid's Avatar
Thanks Franz for the part numbers!
integroid
#14: 03-31-2011, 12:14 PM
 sumfoo1
sumfoo1's Avatar
Car: 2005 OBP LGT 5MT Unlimited
Send a private message to sumfoo1 Find all posts by sumfoo1 Reply With Quote
My idler tensioner is metal... i'm wondering how....
sumfoo1
Find More Posts by sumfoo1
#15: 02-18-2013, 12:41 PM
 ricepapertiger
ricepapertiger's Avatar
Car: 09 WRX, 05 LGT, 88 GL (fwd, 3EAT!)
Send a private message to ricepapertiger Find all posts by ricepapertiger Reply With Quote
I'm bringing this one back, since I just cracked my tensioner when I installed my Cobb pulley.
Th3Franz, how are is your AC belt holding up?
ricepapertiger
Find More Posts by ricepapertiger
Similar Threads
Replacing the Alternator/PS Belt, MY2005 2.5L Turbo AndrewZ Walkthroughs :: Basic Operation & Maintenance 38 12-11-2011 11:00 AM
New: Gates Racing Subaru Timing Kit - With Kevlar Racing Timing Belt FredBeansParts FredBeansParts 0 01-28-2011 10:23 AM
New Gates Timing Belt $60 shipped/pay pal'd croll326 Member Classifieds (2005 - 2009) 2 08-28-2010 09:42 PM
FS: Gates Timing Belt $65 croll326 Member Classifieds (2005 - 2009) 0 05-31-2010 11:21 AM
GI: Gates timing belt - New croll326 Member Classifieds (2005 - 2009) 4 05-30-2010 03:29 PM
