Reload this Page Should I sell or keep ?
Page 1 of 3 1 23 >
#1: 02-08-2013, 09:00 PM
 krishk24
Car: 2011 LGT
Send a private message to krishk24 Find all posts by krishk24 Reply With Quote
I have a 2011 LGT. love its look and the turbo engine, comfortable and safe for my 2 kids !. The one thing i cannot overlook is the wobbbly shifter and the clutch response of the car. The shifter is wobbly and the throttle response slow when going from 1-2. I think LGT really delivers its keynote speech in the higher gears. I am really debating since the shifter is not at all satisfying. I have Group N transmission mount, crossmember bushing and tranny fluid changed. Should I try the STI short throw before I give up on the car ? having driven a manual Honda was really sweet and gratifying even though it was just a FWD and had no turbo engine. Having gone through this experience I have come to realize more than the power itself, its how the power is put down or used. Like the BRZ - its just not about brute force power !
will the short throw help ? any other suggestions to make the drive a little bit more gratifying ?
by the way i loved this car - drove 500 miles in about 6.5 hrs not counting the breaks during a recent road trip and the sure footedness during rain was amazing !
as you can already tell I have mixed feelings about this car
krishk24
Find More Posts by krishk24
#2: 02-08-2013, 09:10 PM
 exbagboy
exbagboy's Avatar
Car: 2010 LGT
Send a private message to exbagboy Find all posts by exbagboy Reply With Quote
The short throw will feel a little shorter but I was dissapointed. I have the bushings and transmission mount as well. The shifter is not gonna change your mind about the car. Going from 1st gear to 2nd still kind of sucks, the rest of the gears feel better and crisper but also a little stiffer. Will wait to change to S fluid before I make any final conclusions.
exbagboy
Find More Posts by exbagboy
#3: 02-08-2013, 09:22 PM
 SurlyOldManMN
SurlyOldManMN's Avatar
Car: 2010 LGTL & 91 Angry Turbo Legacy
Send a private message to SurlyOldManMN Find all posts by SurlyOldManMN Reply With Quote
The throttle can (and IMO should) be remapped. Look into a clutch damper delete to improve response of the clutch pedal. Expect a kit to become available for that shortly.
The shifter is what it is once you've gone through the bushing + fluid swap. It's never going to feel "nice".
The Following User Says Thank You to SurlyOldManMN For This Useful Post:
GTEASER (02-11-2013)
SurlyOldManMN
Find More Posts by SurlyOldManMN
#4: 02-08-2013, 09:26 PM
 Byll
Byll's Avatar
Car: '12 2.5i 6MT, '97 GT & '95 L wagons
Send a private message to Byll Find all posts by Byll Reply With Quote
For me personally, our Legacies have always been much more than simply their gear shift mechanism. The Hondas I have driven have their idiosyncrasies, also. If your Legacy's credit/debit sheet works out in your car's favor, you might consider keeping it. There is no perfect car...
Good luck in your decision.
Byll
Byll
Find More Posts by Byll
#5: 02-08-2013, 09:38 PM
 SurlyOldManMN
Byll
This.
The fact is the shifter just isn't sexy and never will be barring a vendor with cable linkage experience stepping in with something aftermarket. It can be done, but it's unlikely. The forum has collectively tried to engage a few companies before.
That said, these cars shine in other ways. For example, you don't NEED to shift due to having torque all over the map. It took me a while to realize she doesn't need nor want to be run hot. The joy of this car comes from judicious application of the other two pedals... Get comfortable with how the weight shifts along with a new ECU map and it's a whole new ballgame.
SurlyOldManMN
#6: 02-09-2013, 02:17 PM
 Bunky23
Car: 2010 LGT Stage 1
Send a private message to Bunky23 Find all posts by Bunky23 Reply With Quote
And remember, there were only, what, 200 or so LGT's built in 2011? (My search option not working right now for some reason) I'd keep it just for that fact alone.
The Following User Says Thank You to Bunky23 For This Useful Post:
nightspeed98 (02-09-2013)
Bunky23
Find More Posts by Bunky23
#7: 02-09-2013, 02:32 PM
 DeltaSniper
DeltaSniper's Avatar
Title: ¯\(°_o)/¯
Car: 2012 LGT
Send a private message to DeltaSniper Find all posts by DeltaSniper Reply With Quote
Just do a STI 6 speed swap with DCCD.
DeltaSniper
Find More Posts by DeltaSniper
#8: 02-09-2013, 02:48 PM
 minuccims
minuccims's Avatar
Car: 2010 LGT Stage II, 2007 Outback 2.5i
Send a private message to minuccims Find all posts by minuccims Reply With Quote
Stage I makes a huge difference. The first two gears severely limited stock and come alive. Throttle control is also greatly improved. The car is transformed. Have you changed the 6MT and rear diff fluid with either ExtraS or synthetic? This will greatly improve the notchyness. Maybe give that a go first?
minuccims
Find More Posts by minuccims
#9: 02-09-2013, 03:41 PM
 DrD123
Car: 2012 LGT
Send a private message to DrD123 Find all posts by DrD123 Reply With Quote
I thought the STi shifter really improved the shifting feel - it has less floppiness to it (the spring for lateral motion is definitely stronger), but the shifts aren't a whole lot shorter (somewhere on here there's a thread where they measured - I want to say something like 20-30%) - it definitely improved things for me. The downside is it's pretty expensive for what you get (well - on par with other Subaru OEM shifters, but a lot more expensive than the many aftermarket solutions available for the linkage-based 5 and 6spd transmissions.
I'd try getting the shifter and see how that feels - it's cheaper than selling the car!
DrD123
Find More Posts by DrD123
#10: 02-09-2013, 04:26 PM
 CL21376
CL21376's Avatar
Car: 10 LGT Stage1; 94 Pontiac Firehawk #251
Send a private message to CL21376 Find all posts by CL21376 Reply With Quote
Are you Stage 1? That should really improve the throttle response and make it like a different car.
I don't think the STi shifter made the gearbox much better, just shorter. It was at least "ok" You're never going to mistake it for an S2000.
Between the shifter, stock suspension, and flat seats, I think it's going to be hard to make the driving experience more gratifying. More boost helps though
CL21376
Find More Posts by CL21376
#11: 02-10-2013, 11:31 PM
 HwnLGT2o11
Car: 2011 Legacy GT
Send a private message to HwnLGT2o11 Find all posts by HwnLGT2o11 Reply With Quote
I also have a 2011 LGT. Clutch is really heavy compared to the WRx or STi. That is the only thing that bothers me. Other than that I just love my car. I say keep it
HwnLGT2o11
Find More Posts by HwnLGT2o11
#12: 02-11-2013, 09:22 AM
 TwoTone
Car: 11 2.5i Premium 6sp w/ Leather
Send a private message to TwoTone Find all posts by TwoTone Reply With Quote
To bad someone on here doesn't have a machine shop and time. The Diesel Geek short shifter kits for VW cable shifters are literally just new shifter levers at the trans.
http://www.dieselgeek.com/6_Speed_VW.../ss-sigma6.htm
I haven't seen how ours are mounted, but I can't see it being much different.
TwoTone
Find More Posts by TwoTone
#13: 02-11-2013, 12:02 PM
 krishk24
Car: 2011 LGT
Nope not on Stage 1. how much more torque/HP are we talking about when I goto Stage 1 ? Could you point me to the cost and link to the kit ? How much MPGs are you getting with a stage 1 ?
krishk24
#14: 02-11-2013, 01:11 PM
 SurlyOldManMN
A lot. 60-80 wtq.
You're in the wrong car to be worrying about MPG's...
Theoretically you get better mileage due to optimal AFR. Actual mileage depends on how heavy your foot is.
SurlyOldManMN
#15: 02-11-2013, 02:37 PM
 exbagboy
exbagboy's Avatar
Car: 2010 LGT
Go stage 1 before you even think of selling. Also full boost is unlocked in first 2 gears so even with 91 octane map there is a world of difference.
p.s. I love my KW V3s
The Following 2 Users Say Thank You to exbagboy For This Useful Post:
Nadal4Hand (02-11-2013), SurlyOldManMN (02-11-2013)
exbagboy
Page 1 of 3 1 23 >
