- V.2.5 RacerX front mount intercooler kit
My car is a stage 2+ DD on the stock turbo so I really have no need for a FMIC. I swapped it out for a PW TMIC. I call it a "v.2.5" since it is a V.2 kit but with the v.3 two piece cold side pipe so no need to remove your bumper to change the battery (makes for an easier install as well). I bought the kit new and has been on the car just over 2 years. The v.3 cold side pipe has been on for maybe a year.
Great working order, there are scrapes/scratches on the piping and core (a few minor bent fins on the core as well) due to install and uninstall and use. Pipes and such are dirty from use.
The only piece of piping with any damage beyond scratches/slight discoloration from install and use, is the hot side pipe coming off the core. I must have hit a parking block as the bottom of the pipe is dented. Farther up is a spot where a bolt rubbed on it (see pics). Both areas area are just cosmetically damaged, nothing punctured and no holes in the piping.
Includes all clamps and couplers as well as a Mr.Gasket 738G turbo->IC gasket. Also the extra coupler that's used if you want to run an STI fitment turbo.
$430 cash firm, pick up only SOLD
The following two parts are also for sale as they would not fit with the PW TMIC and splitter.
- Cobb XLE BPV
Purchased new a couple years ago and is in perfect shape. Can be set to full recirc, 50/50, or VTA. Includes gasket and hardware.
$190 shipped/paypalled firm Con.US only
Cusco front strut tower bar
In good shape. Has been on the car for a few years and has some marks/scratches/some blue paint coming off the ends.
Blue end pieces are still on the car right now as I realized too late that the bar would have to go with the new top mount (doh!
). Car was already on ramps from removing the FMIC and you must jack the car up slightly with the strut top bolts off to pull the plates out. Due to me not wanting to ship this, and its average condition, I'll let it go for:
$65 cash firm, pick up only
Located in central VA.
Only trades I would consider for anything: VF52, HexMods F1 Valve body, or a set of 18x8 or 18x8.5 wheels.
