#1:
02-05-2013, 11:32 PM
New black vs blue oil filters
Car: 2011 Legacy GT
Evening guys,
I've been seeing some people looking into the new '12 Forester filters. I've been doing a ton of research and cross checking and it seems like it's the same as the blues but a bit longer and larger diameter. Also, I cross referenced the oil pump performance specs for our LGT and the new forester and they are identical. The black filters aren't listed for turbos but I don't think that matters seeing that one site is selling them for wrx/sti/LGT also. Lastly, these black filters are starting to be discontinued already so i may be jumping on it sooner then later. Wondering the communities opinion on the crossover. Thanks
Honeywell/Subaru 152208AA12A (for 10+ LGT and more)
Specs:
OD: 68.3mm
Length: 67mm
Thread: M20x1.5, Roll-formed
Spring type: Stamped leaf
Bypass Valve: 23 PSID, Plastic, located in the stamped spring, positioned at the end cap on the dome end
Anti Drain Back Valve: Yes, Nitrile
Media type: Paper
Media Surface area: 473.7cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Gasket style: "P" ring
Oil inlet hole/s area: Ten 5mm holes. 196.34mm2.
End caps: Engineered media
Can side thickness: .37mm
Tokyo Roki 15208AA160
Specs:
OD: 86.25mm
Length: 70.18mm
Bypass Valve: 23 PSID, Metal valve integrated into the end cap on the dome end.
Media type: Paper
Media Surface area: 1,092cm2
Beta Ratio: Unknown
Flow Rate: Unknown
Oil inlet hole/s area: Six 6.25mm holes. 184.07mm2 total area.
End caps: Metal
Can side thickness: .44mm
#2:
02-05-2013, 11:43 PM
Car: 2011 Legacy GT
Edit: from what I read and understood, the black is actually the same diameter and above could possibly be a misprint. Read " The Tokyo Roki made Subaru 15208AA160 is the same diameter as the blue Honeywell, just a bit longer. I use this on my 2008 LGT."
#3:
02-05-2013, 11:47 PM
Car: 2010 Stg.II RRP LGT 2005 Stg.II OBP LGT
Another filter thread...
Get Purolator's PureOne and change your oil no longer than 3,750 miles.
I use Shell's Rotella T6 5w40, others prefer German Castrol's 0w-30.
www.BITOG.com also has a lot of good threads on oil and filters.
02-06-2013, 12:00 AM
Car: 2011 Legacy GT
I already run T6 but this is what I don't want... Bypass pressure is low
#5:
02-06-2013, 12:05 AM
Car: 08 spec.B - 91 3000GT VR-4
Originally Posted by Austin2334
Wix/Napa filters do claim the correct bypass pressure, so if you don't buy OEM i'd buy those.
#6:
02-06-2013, 01:27 AM
I read a test a while back about that on BITOG, it's not an issue at all.
02-06-2013, 06:25 AM
Title: Whut, who me?
Car: It runs 12's
Specs:
OD: 68.3mm
Length: 67mm
Media type: Paper
Beta Ratio: Unknown
Flow Rate: Unknown
Specs:
OD: 86.25mm
Length: 70.18mm
Media type: Paper
Beta Ratio: Unknown
Flow Rate: Unknown
End caps: Metal
The bold print is really what you should be concerned with. FLOW!!!!
#8:
02-06-2013, 06:28 AM
Car: It runs 12's
I'd be more concerned about those tiny feed holes than the pressure relief.
#9:
02-06-2013, 07:51 AM
Car: 2011 Legacy GT
This was takin from Uncle Scotty over at NASIOC..."i guss a LOT of you have NO IDEA why using a filter with the proper by-pass valve presure is ESSENTIAL
here it is....with the wrong filter...your oil is NOT BEING FILTERED!!! IT IS BY=PASSING THE FILTER
THAT IS WHAT THE BY-PASS VALVE DOES....IT ALLOWS OIL TO BY-PASS THE FILTER WHEN THE DIFFERENTIAL PRESSURE IS MET AND SUBARUS ARE DIFFERENT AND HAVE A 23.2PSI REQUIREMENT FOR THE FILTER BY-PASS
WAKE THE **** UP CHILDREN AND SMELL THE BLOWN MOTORS HERE....
THIS IS A BIG DEAL"
He's a little extreme but I do believe that it does create a situation where the valve is opening and oil isnt getting filter considering subarus have a high required pressure. With cold oil at idle, the system flows about 4 gpm, if you have a relief valve at lets say 15 psi that means your filtering about 3 gpm so 1 gpm isnt being filtered. It magnifies at higher rpms. Also, I don't think that oil inlet hole number is bad. Below is the AA100 black filters from years ago that have that same hole layout and is approved for our cars in the lubrication specs.
Tokyo Roki 15208AA100
Provided by: SuperRu
Specs:
OD: 68mm
Length: 64mm
Media type: Paper
Media Surface area: 470.9668cm2
Beta Ratio: Unknown
Flow Rate: Unknown
End caps: Metal
Can side thickness: .48mm
#10:
02-06-2013, 09:21 AM
Title: Teaser of the G
Car: 2012 Legacy GT
I use Wix.
#11:
02-06-2013, 09:50 AM
Car: 2011 Legacy GT
Gt, is it the 57712?
#12:
02-06-2013, 09:57 AM
Title: I ride Kharon
Car: '12 LGT BNR18G
As I have looked into this too.... The Blues are just fine for our cars. Some people have an issue with honeywell or what not. Others run the class fav the Puros - great filter. But its not like its doing a "better" job. People just FEEL better by having it. I don't know of one case where the Blues were found to be less than adequate. This is sorta like an intake on our cars. Our stock intake is actually very good and a CAI really doesn't do anything outside give you stickers - hence why no real big name even makes one for the GT. Now you making BIG boost, changing turbos and fortifying your engine cause youre pushing 400hp - ok, new filter makes sense.
Unless you want the "sticker" idea - meaning you feel different cause you run the "blacks" do it. Of course this is all IMO and everyone has one... but with my build, people tell me the blues are just fine. Each his own i guess.
#13:
02-06-2013, 10:03 AM
Car: 2012 Legacy GT
Yes.
#14:
02-06-2013, 10:11 AM
Car: 2011 Legacy GT
If GTTuner is worried about flow then don't get the Pureone 612 filter....Oil inlet hole/s area: Eight 4.5mm holes. 127.24mm2
#15:
02-06-2013, 10:37 AM
Car: It runs 12's
Exactly. I had a thread where I disected a bunch of filters. The inlet holes were a major concern in my findings. I prefer to use the blue Subaru filters.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
